Old 09-19-2010, 12:46 PM   #106
plumber mike
Born again
plumber mike's Avatar
Oddometer: 1,077
Originally Posted by Glowplug
I've had an Ohlins in the rear since last winter, and threw in some Hyperpro progressives in the front for the heck of it with 15w. I'm back to the stock springs but what has been really great is the addition of 5W oil! With 10 and 15 the forks seemed harsh and to "freeze" up, now the forks finally feel like they are working. Heavier springs might be good for riders heavier than me or loading their bikes up with gear and extra fuel...
5w--do it!
Just for a reference, what is your weight geared up? And maybe a dumb question, but isn't a progessive spring soft until it gets closer to full compression where you need stiffness?
09 Xcountry-the money pit
75 CB400F Supersport-close to stock and for sale
79 CB400T2- so I don't cut up the 400F
Why do I want a CBR250R so bad?
www.dakotadualsportriders.com
plumber mike is offline   Reply With Quote
Old 09-22-2010, 06:00 PM   #107
Glowplug
Glowplug's Avatar
Oddometer: 103
Send a message via AIM to Glowplug
5w Oil--Do it!
Good questions Mike--I tip the scales around 200 pounds + gear. I think I have the rebound on full soft and the compression around 3/4 to full soft.
As for progressive springs, the answer is yes. I think the idea is that they will give you plushness over small bumps but still be able to handle the big ones. The spring rate on the Hyperpro is supposed to be firmer than stock. I can't say if they are better or worse. They are worse with 15w oil. Stock springs are bad with 15w in my experience as well.
Glowplug is offline   Reply With Quote
Old 09-23-2010, 01:52 AM   #108
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,559
Originally Posted by tbarstow
They respring and revalve the forks. The OEM valves are crimped on (or so I'm told). TrailTricks has the set up to crimp the new valves in. I don't know which valves got put in, but its an incredible difference afterwards.
Trailtricks have replied to my e-mail with a quote of $500 plus postage.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Cruz is offline   Reply With Quote
Old 09-23-2010, 10:24 PM   #109
tee bee
Oddometer: 166
I,ve recently bought a pair of 45mm factory shivers off ebay for £290 they fit straight in the yolks. All i need to do now is strip them down change the wheel ,caliper mountings ,get the bm ones machined out for the rebound mechanism. Then apart from setting them up to my riding style the jobs done.
Wish me luck !!
tee bee is offline   Reply With Quote
Old 10-03-2010, 10:01 PM   #110
Dukehunt
Dukehunt's Avatar
Oddometer: 727
About to start the WP conversion to XC
KTM Front wheel (in transit)
EMIG racing conversion kit (in transit)
KTM Disk rotor
04 KTM WP forks, re-sprung with stiffer springs, new 5w oil and seals (need to test)
KTM Front Brake Caliper (hopefully the XC brake lines and master Cylinder will be adequate)
Go to go to the Moto GP at Phillip Island so I will start when I return later in October
Any know if any thing in particular to lookout for ?
2010 BMW R1200GS
FE390 Berg
1976 Suzuki GT250
Dukehunt is offline   Reply With Quote
Old 10-04-2010, 12:49 AM   #111
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 211
Cruz is that $500 USD. heard that there is a suspension shop in Sydney OZ going to make some cartridge for the forks about $800 AUS.
dale
dirty boar is offline   Reply With Quote
Old 10-04-2010, 02:57 AM   #112
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,559
Yeah $500usd plus postage.
Here is his reply.
Yes ,we do it few times a year ,we cut the cartidge and put a new one after modified the valving and crimp it ,i got the crip tool last year and cartidges are avaible from marzochi italy
cost is around $500
Old 10-04-2010, 04:08 AM   #113
Dukehunt
Dukehunt's Avatar
Oddometer: 727
Here is his reply.
cost is around $500
Hey Cruz that is getting expensive to modify the existing forks
Swap to WP's isn't chap either, glad the Aussie dollar is doing well
My total so far is:
Forks $380
Front Wheel $290
Brake Caliper $80
EMIG Triple clamp and kit $680
So far $1430 and I haven't put it together yet
2010 BMW R1200GS
FE390 Berg
1976 Suzuki GT250
Old 10-04-2010, 01:57 PM   #114
Deco
Deco's Avatar
Oddometer: 240
Ditto
I am on the same track as Duckhunt.
I have a terrible head shake at around 65-70mph on asphalt. Dirt is fine. I have progressive spring in front and OEM air shock in rear.
My thinking is the EMIG stabalizer will help with the head shake and will allowing me to up garde to the 48mm WP forks, as funds become available, making for a much better front end. I am about half way through the install, so I have no report other than the install has been fairly easy to this point.
Any suggestions on replacing the rear shock? Ohlins, Hyper Pro, etc.
Deco is offline   Reply With Quote
Old 10-05-2010, 04:29 AM   #115
Dukehunt
Dukehunt's Avatar
Oddometer: 727
Hey Deco
Running an Ohlins rear, so far so good, to me it feels much better than the air shock as it behaves like a normal bike, but I am sure all will change when the front suspension is sorted and it will be back to the drawing board on all the settings.
One thing though, it is bloody tall with the Ohlins fitted, I am only 5'8" and it is a real stretch to touch the ground , I can only get one tip toe on the ground at a time and have to mount the bike from the right hand side as it makes it easier to get on.
I have the forks with only the top 2 lines showing above the top triple clamp as I agree that the front is nervous at speed and don't want to steepen the rake unnecessarily. I tried them further through but it was unstable.
2010 BMW R1200GS
FE390 Berg
1976 Suzuki GT250
Old 10-05-2010, 10:19 AM   #116
Rone
Rone's Avatar
Oddometer: 58
I am 1m74cm. I have an Ohlins too. It is modified. There is a spacer (6mm) inside so the bike is +/- 2cm lower in the back.
R 1200 GS '08 en G 650 X Challenge '08
My RTW XChallenge
Rone is offline   Reply With Quote
Old 10-13-2010, 01:36 AM   #117
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,206
Send a message via MSN to Max Kool Send a message via Skype™ to Max Kool
Not sure if a steering stabilizer will help you. Most headshakes that I know of are "low speed" oscillations (low speed as in "quite slow left to right movement", 1 Hz or even lower, with a low amplitude). You need to tighten up the steering damper quite some to ease these. Steering stabilizers are mostly efficient in damping high speed shakes from ruts and rocks that would normally shake the bars out of your hands.
I know from first hand that the Xchallenge is quite susceptible to tire choice. On Michelin Enduro III and IV this bike behaves very bad at higher speeds on tarmac at any speed over 65 mph. On Michelin Baja this bike is much better.
Consider different tires first before you invest in a steering damper, otherwise you might end up with a bike that is stable, but will hardly go round tight corners imho, or otherwise is excellent in thed desert but still shakes its head.
(don't get me wrong, I'm not against steering dampers, I'm just doubting if it's the most efficient way to solve your particular problem)
Max Kool is offline   Reply With Quote
Old 10-13-2010, 01:48 AM   #118
D K
Oddometer: 308
I'm doing the same mod..
One question for you: why not use the KTM triples?? That's what I did. Much cheaper.
D
My total so far is:
Forks $380
Front Wheel $290
Brake Caliper $80
Seriously, a nutless monkey can do your job..
Husaberg FE570
Husky TE610
KTM SE 950R
D K is online now   Reply With Quote
Old 10-13-2010, 06:14 AM   #119
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,559
Trying to find some to buy in the first place is the hardest bit here in Australia.
Old 10-13-2010, 09:35 AM   #120
Deco
Deco's Avatar
Oddometer: 240
Hey Deco
Thanks for the comments. I am planning on either the Ohlins or HyperPro. I''m 6' so I have a slight advantag...:)
Let me know how the install goes and I'll do the same.
Times are GMT -7.   It's 10:43 PM.
