Old 11-14-2007, 05:11 PM   #16
BBriggs OP
El Noobo
BBriggs's Avatar
Oddometer: 161
Swampy PM sent.
BBriggs is offline   Reply With Quote
Old 11-15-2007, 06:32 AM   #17
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
How is this not an infringement on dirt Bagz products..
Or are you working with him?
alpiv is offline   Reply With Quote
Old 11-15-2007, 09:51 AM   #18
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,562
Dirtbagz doesn't make a set of pannier racks for the 04-07 EXCs, only 03 and below. If it helps dirtbagz sell more bagz, why not?
I'm pumped for these, will be orderingin the spring.
sailah is online now   Reply With Quote
Old 11-16-2007, 07:54 AM   #19
BBriggs OP
El Noobo
BBriggs's Avatar
Oddometer: 161
Alpiv
Yes I have talked it over with Ed at Dirtbagz and he is ok with it. Ed is not interested in making racks for the 04-07 ktm exc. I fact if you were to call
Dirtbagz to order a set of racks for the 04-07 exc's Ed would give you my number.
I'M NOT IN ANY WAY A PART OF DIRTBAGZ just some one who needed some luggage for my 06 450 XC for a baja trip so I made my own racks.
I hope this clears things up.
Berg Briggs
Old 12-05-2007, 06:33 AM   #20
Stu
Buffo Maximus
Oddometer: 931
Originally Posted by reconsmr
36,000 miles of all street on a 04 450 MXC motard conversion, valves adjusted twice, still runs like new. Just needed a CS seal/o ring and sprocket bolt, bulletproof otherwise. I'll check back when it crosses 40k,,,
Wow. I want to know more! What kind of oil are you running, for example? Your mileage beats Dirt Rider's RFS of 30,000 miles. When you put in the seal get the inner race as well. It grooves and will ruin a new seal if not replaced.
BBriggs -- you tear your seat installing your bags? Can you post a pix of the mount you made for the rear of the sub frame? (You can see mine back on about page 12.) How is the rear mount holding up to the usual crashes?
Stu
Stu is offline   Reply With Quote
Old 12-05-2007, 07:46 AM   #21
BBriggs OP
El Noobo
BBriggs's Avatar
Oddometer: 161
Stu
I bend channal out of 4130 to go around the rear sub frame so the bolt dosent take all the abuse. I also mount in three places so it will help stiffin
the sub fram a bit more.
No I did not tear my seat instailing the racks I hooked a branch.
With out the stock under fender I make some bushings but it works best with the stock under fender.
Berg
Old 12-05-2007, 09:33 AM   #22
Stu
Buffo Maximus
Oddometer: 931
Underseat Hookup
That is an excellent setup that gives lots of support to the sub frame. Thanks! When I trash my setup I will make one like yours.
Stu
Old 12-05-2007, 10:10 AM   #23
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Posts moved/merged...
Berg, no more commercial posts outside of our Vendor Forum, please.
Arch
Arch is offline   Reply With Quote
Old 12-10-2007, 01:46 PM   #24
tn-steve
Addicted
Oddometer: 1,584
Originally Posted by BBriggs
...I will be working on a dirtbagz only rack for the 950 adv, the rack will move the bags forward about 6" and be around 6lbs lighter than the stock gobi racks...
Hello,
Are you selling the dirtbagz only rack for the 950 yet??
tn-steve is offline   Reply With Quote
Old 12-10-2007, 06:17 PM   #25
BBriggs OP
El Noobo
BBriggs's Avatar
Oddometer: 161
950 Racks
I don't have the 950 racks ready yet I have not had a lot of interest in them so other projects have come first. I do still plan on making at least one run of racks. Hopefully after the new year I will have a better idea of when the racks would be ready.
Berg
Old 12-14-2007, 08:04 AM   #26
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
Groovie, not trying to bust your balls or nothing.
I just know how hard it is to keep a business up and going with all the competition around.
See a need, fill a need.
Alpiv
Berg Briggs
Old 03-16-2008, 12:49 AM   #27
allengt
allengt's Avatar
Oddometer: 62
Dirt Bagz Rack For 950 SE
By any chance do you have a rack set-up for a KTM 950 SE. I have the CJ Rack on the back and was thinking that might be a good place to attach also.
Thanks,
14 KTM 1190 R
13 KTM 350EXC
09 KTM 690 R
08 KTM 530 EXC-R (now AWD)
allengt is offline   Reply With Quote
Old 06-13-2008, 07:49 AM   #28
advjackass
orange crusher
advjackass's Avatar
Oddometer: 925
thanks for the 530 racks and the se racks, both look great.
advjackass is offline   Reply With Quote
Old 10-14-2008, 03:54 PM   #29
Hyakian
Oddometer: 7
05 Mxc
BBriggs - PM sent...
Hyakian is offline   Reply With Quote
Old 01-28-2009, 09:48 PM   #30
lancethemotoman
Location: International Falls, MN - the icebox of the nation
Oddometer: 27
Berg
It sounds like you have made racks for the 950 Super Enduro for soft luggage. If so, can you post pic's and prices or PM me if you would like the opportunity to make/sell another set?
Thanks,
Lance
lancethemotoman is offline   Reply With Quote
Times are GMT -7.   It's 02:30 PM.
