Old 10-24-2007, 04:32 PM   #16
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
Originally Posted by Gramps
Is that something on the newer bikes? I know my R90 doesn't have it, but things must change in 33 years..
My 93 and 95 both have it. Wow, I didn't know the older bikes were different.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 10-24-2007, 05:53 PM   #17
Country Doc
Wanderer
Oddometer: 2,702
The post-81 clutch assemblies make way more "neutral rattle" than the earlier versions.
My /6 was almost silent, as is almost every other /6 and /5 I've ridden, my R100GS and my buddies R100RT sound like a washing machine full of bolts at idle with the clutch out.
For me, this noise on the R100 never went away, no matter what state of rebuild the clutch and transmission was in, and no matter how well the carbs were synced.
dc
Country Doc is online now   Reply With Quote
Old 10-24-2007, 07:47 PM   #18
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
Maybe the pushrod for the clutch changed? I'm going to pull the rod out of my 95 (tranny is laying on the bench) and check the felt condition. I can't find the felt on the parts fiche so maybe it's gone.
Old 10-24-2007, 07:57 PM   #19
myblubeemer OP
JWAT
myblubeemer's Avatar
Oddometer: 470
dc
Well....guess I will check the throw out bearing per the instructions in the thread and see if it makes a difference.....
myblubeemer is offline   Reply With Quote
Old 10-24-2007, 07:57 PM   #20
Suppermotodd
Tag Thief
Suppermotodd's Avatar
Oddometer: 1,023
Felt
No felt on the late model gearbox.
Man I'm broke as a stick! NoPC-Lance
http://www.motocompound.com
Suppermotodd is offline   Reply With Quote
Old 10-25-2007, 07:33 AM   #21
myblubeemer OP
JWAT
Oddometer: 470
I don't buy that "they all do that" because my '81 sure doesn't....
Old 10-25-2007, 07:49 AM   #22
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,897
Maybe the problem is the '81!
Have you checked with Perry on this? I admire your desire to sort it out yourself but I would make the call.
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 10-25-2007, 08:07 AM   #23
RocketJ
Oddometer: 674
Here are the differences
A close comparision will show why the later models "all do that" to some degree
[IMG]
For some reason the second one did not come up. darn firewalls
R60/5
R90/6s
R100GS (sold)
R100RS (for sale)
XR650L
RocketJ screwed with this post 10-25-2007 at 10:49 AM
RocketJ is offline   Reply With Quote
Old 10-25-2007, 08:22 AM   #24
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,512
Balancing and adjusting the carbs goes a long way towards eliminating the rattle at tickover. My 87 G/s used to rattle quite badly with the carbs out of sync until I rebuilt the gearbox. The roller bearing on the input shaft seems to be the culprit, since replacing the bearing there isn't a sound from my gearbox even when the carbs are out of balance.
My 91 Paralever GS has the same rattle even though it's only got 30k on it. I'm going to rebuild the gearbox over the winter, it will be interesting to see if it disappears on that bike as well.
Rob Farmer is online now   Reply With Quote
Old 10-27-2007, 04:26 AM   #25
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
They all do that sir.
Nature of the beast.
Don't worry about it.
Don't waste time mucking about with throwout bearings.
If you want to minimise the rattle, careful carb synching helps as Rob says above, and adjust the idle speed to where it is quietest, in the specified range of about 800 to 1100 rpm. The 1000-1100 range works better on the 81 and onwards light flywheel models, I have found.
Putting molylube gearbox additiive or colloidal graphite additive into the gearbox oil can help too. Seems to thicken up the gearbox oil and stops the gears and things rattling about inside quite so much.
If your cam chain is warn enough to be creating a ghost image when you strobe the timing marks, this is probably contributing to uneven idle and bouncing things around too.
Either way, it is nothing to be worried about.
Be more worried about loud whining noises coming from the gearbox under laod in the lower gears, indicating worn bearing or gears.
And be very very afraid if you find rough, abrasive, sandy feeling grinding paste stuck to the magnetic gearbox drain plug at oil change time. It is normal to have a light, feathery fluff stuck to it, but not the gritty bits that indicate gears or bearings inside coming apart.
Y0ur gearbox is the achilles heel of the Airhead, so change the oil with every engine oil change, not at every second change like the manual says.
And make sure that where the speedo cable goes into the gearbox, the rubber cover is in good condition, sealed up with Silastic and a cable tie. Water runs down the cable, past a perished or loose rubber and gets into the gearbox oil and breaks it down. This is a major cause of rapid wear.
A lot of Airhead riders swear by full synthetic gearbox oil and say it doubles the life of the box. I have no experience with it over long mileage, but have found that it is a bit "thin" - even the 90wt, and increases the rattle you are suffering.
HTH, and enjoy your great old bike.
Redryder
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 10-27-2007, 07:19 AM   #26
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,419
Is that really in the manual?
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 10-27-2007, 08:39 PM   #27
myblubeemer OP
JWAT
Oddometer: 470
Thanks for all the good advice! Makes sense as the rattling is not nearly as bad at 1100 rpm as it is at 800.....carb work and synching is also in order.
jwat
Old 10-27-2007, 10:26 PM   #28
Mr. G
Normal Dude
Mr. G's Avatar
Oddometer: 1,709
jwat
My Airhead has it .... exactly as you describe it. It's louder when the bike and trans are cold which rules out trans oil thickness and the noise being in the trans. It's loud at 800 RPM and gone by 1200 RPM. I keep the idle at 1000 RPM. Can't hear it with earplugs ..
Other BMW's I've had with dry cluthces also had clutch noise to some extent. I've experienced clutch noise with several bikes but never had a clutch failure over ten's of thousands of miles.
LATER...........Gregg
Then, while at WFO on my way up a dune, I understood. It was like the heavens opened up and I heard the voices of Angels.
Shortly afterward, I heard the voice of God. He said, and I quote, "Dumbass."
Mr. G is offline   Reply With Quote
Old 10-28-2007, 12:16 AM   #29
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,650
Pre 1981, the flywheel was actually a flywheel with some serious heft. I imagine it did a lot to smooth the engine pulses at idle. The stamped steel thing with a ring gear on the '81 and later makes shifting lighter and helps the engine acceleration but allows those pulses to rattle things unless things are synched really well.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 10-28-2007, 02:52 AM   #30
Reryder
Reryder's Avatar
Oddometer: 1,399
Yep. For the Airheads, the BM owners manual specifies 7,500km engine oil change and 15,000km gearbox/shaft/bevel oil changes. Most old bikes with separate gearbox oil were like that.
But with the gearbox being the Airheads weak link, I reckon it is worth changing the gearbox oil at the same time as the engine. It allows you to keep an eye on the metal fragments on the gearbox drain magnet too. It can mean the difference between having to replace $300 worth of bearings and seals and having to replace $1200 worth of gears as well if excessive wear is detected early enough.
I change the engine/gearbox/shaft/bevel oils every 5,000km, which is once or twice a year for me, just to be safe.
Oil is cheap. BM gearbox parts and the special tools to install them are painfully expensive.
81 BMWR100RS
01 HONDA VFR800
99 SV650
Times are GMT -7.   It's 10:14 AM.
