Old 01-18-2008, 09:38 PM   #46
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,502
Good Job! I did the same job, just a bit more inspiration from Kildala
xdbx is offline   Reply With Quote
Old 01-19-2008, 07:26 PM   #47
zzr pilot
Oddometer: 30
I have some PIAAs on homemade brackets coming off my mirror bases.....
zzr pilot is offline   Reply With Quote
Old 01-19-2008, 07:59 PM   #48
torags
torags's Avatar
Oddometer: 2,468
Lighting bracket off frame.. HIDs over PIAA fogs
Finished product
Rags
'02 BMW R1150R now
'04 BMW R1150RS/// Gone, but not forgotten
'07 HD XR 883R Sportster "Widow Maker"///Gone!
IBA #17225
torags is offline   Reply With Quote
Old 01-20-2008, 07:00 AM   #49
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,653
The rear rack on the GSAdv breaks if there is a lot of weight behind the rear mounting point.
I made a very simple rack support out of some 1/8" (I think) steel. Turns out that there are some holes on the mounting rack for the Jesse bags that are in just the right spot to bolt up the support. I mounted the support with a little upward tension.
Cheap and so far, effective.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 01-21-2008, 07:39 AM   #50
QfactorSV
Oddometer: 67
Custom rack for Ducati monster. Not ADV tested yet, but beer run tested!
actual rack is 6061, the mounting tabs are 7075, it also rests on the pass seat when fully loaded (~110Lbs).
I'll have aux light brackets and GPS mounts done by Feb.
Q
06 Duc S2R 800, black & tang.
99 Laverda 750S, Zane.(SOLD)
QfactorSV is offline   Reply With Quote
Old 01-21-2008, 07:47 AM   #51
torags
torags's Avatar
Oddometer: 2,468
Q... Where is your third mounting point on the rack (behind the seat? frame?)
Rags
'02 BMW R1150R now
IBA #17225
Old 01-21-2008, 08:35 AM   #52
Bruce Caldwell
Bruce Caldwell's Avatar
Oddometer: 1,016
Home Made Luggage Rack Support
[IMG][/IMG]
I made this luggage rack support recently from 1/2" square tubing purchased from the local hardware store for around $5. There's a Pelican case mounted on top of the homemade alum. plate that's mounted on the stock rack.
late-braker
Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa
Bruce Caldwell is offline   Reply With Quote
Old 01-21-2008, 08:39 AM   #53
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,900
Some of mine:
Here are a couple other mods I have completed thus far.
For $2.50 in Lexan, and $1 in Duel Lock I now have a decent looking cover for my headlight, too late for a small rock chip, but hopefully good for protection.
GPS Mount with $1 home made sun screen. I used a plastic folder from Staples and a few inches of black velcro. It works better than the aftermarket ones because it is twice as deep, and blocks more sun.
From this thread: http://www.advrider.com/forums/showthread.php?t=101181
Jim
Old 01-21-2008, 11:20 AM   #54
torags
torags's Avatar
Oddometer: 2,468
Recognizing my gps had a hard drive I put a foam pad under ram mount on a BMW shelf. The other ram mount is my V1 platform
In front of my saddle bag, I installed a photo tripod quiver
Rags
'02 BMW R1150R now
IBA #17225
Old 01-22-2008, 09:20 PM   #55
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,518
I have a few...
This is just the stuff I put together, not farkles I bought...
Raising a Tiger seat above the highest factory setting
(if your inseam is less than 36 inches, you can skip this one)...
http://www.advrider.com/forums/showthread.php?t=219994
Buell Ulysses footpegs on a Tiger (an inch lower than stock, for a bit more legroom)...
http://www.advrider.com/forums/showthread.php?t=221497
SW-Motech mounts on a Tiger tank bag...
http://www.advrider.com/forums/showthread.php?t=223516
FrankenJesses: R1150GS bags on a Tiger (I'm quite proud of these)...
http://www.advrider.com/forums/showthread.php?t=251153
The Stretchatech skidplate...
http://www.advrider.com/forums/showthread.php?t=257270
Foldaway highway pegs...
http://www.advrider.com/forums/showthread.php?t=260256
High-mount front fender... (these are available as a complete bolt-on kit. PM me.)
http://www.advrider.com/forums/showthread.php?t=266677
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 01-22-2008 at 09:45 PM
Stretch67 is offline   Reply With Quote
Old 01-23-2008, 05:15 AM   #56
JimVonBaden
"Cool" Aid!
Oddometer: 52,900
I have always disliked my old GPS mount. It was not very stable, and the GPS was partially covering the Tach. So, instead of a Migsel mount like Kermits that cost $150+ (beautiful workmanship and nice unit by the way), I decided to copy the idea, but do it on the cheap!
So, old mount:
So, instead of spending big bucks, I am running out after my recent home purchase, I decided to make my own. Perusing the hardware store I cam acriss this 3/8" thick shelf bracket.
This is a piece of what was left. I cut the one side to length (5"), and the short end to just long enough to thread safely, 3/4" from the bend outside radius. I drilled and tapped out the short end to fit a standard $7 Ram Mount I had lying around, then covered it all in liquid rubber to prevent rust, and scratches on the framework of the bike. Were I to do it again, I would paint it, and cover the lower parts in foam tape for protection. It would look a little better.
I used my TT cockpit cover and longer bolts to secure it under the cover.
Here you can see it peek out of the bottom under the TT cover. You could easily use a U-bolt, or a smaller flat piece of metal to hold it in place.
A few other angles of it:
I intend to reroute the wires, but it will have to wait for the tank to come off again since the wires are secured under the tank.
The yellow arrows show the two mounting bolts through the TT cover, and the blue arrow shows where I formarly had the GPS bracket mounted (it is designed for a Powerlet Plug).
This is my view of it. Right in my line of sight, without blocking any of the instruments, or the road. IMHO the perfect GPS position.
Total cost, $15 more than I already spent. From scratch, with the 2XXX garmin locking mount, wiring kit, and RAM components, about $70.
Jim
Old 01-23-2008, 06:59 AM   #57
Stanza
R1200GS Mmmmm
Stanza's Avatar
Oddometer: 156
I like to think outside the box
here is a couple of mine
http://www.advrider.com/forums/showp...&postcount=389
http://www.advrider.com/forums/showp...&postcount=390
http://www.advrider.com/forums/showp...&postcount=391
http://www.advrider.com/forums/showp...&postcount=392
http://www.advrider.com/forums/showp...&postcount=394
Stanza - Tony
Well-trained reflexes are quicker than luck.
Never be afraid to slow down.
Riding faster than everyone else only guarantees you'll ride alone.
Stanza is offline   Reply With Quote
Old 01-23-2008, 02:23 PM   #58
yelostn78
Have GS will Travel
yelostn78's Avatar
Oddometer: 598
I know many folks have put bottle openers on the bike somewhere- anyone know where advrider could get some made up with fyyff cast instead of coke or whatever, or even have advrider cast into them?
Fact- black bears like Beets
yelostn78 is offline   Reply With Quote
Old 01-23-2008, 04:08 PM   #59
ownst1100
BLUES TRAVELER 04'GSA
ownst1100's Avatar
Oddometer: 994
Here the combonation GPS,XM,and radar detector mount I made for my 04' GSA. It all attaches to the top/backside of the Ricky Risers on my bike.
Working aircraft assembly I have access to material and trick fasteners. I hate having to deal with nuts and washers so I use rivnuts and nutplates whenever possible. Everything else is riveted together aircraft style with solid AD rivets. Here you cane see how the Radar detector mount is fastened to the backside of the XM mount. I was getting a little more flex than I wanted, look close and you can see a composite doubler/stiffener running fromthe center mount over to the XM mount, did the trick.
Assembled and powered up. The idiot lights are sort of behind the GPS but can be seen by leaning forword a couple of inches. I've learned to deal with it. I've alway's ran with my high beams on during the day so not seeing that light isn't a problem, its alway's on. Remembering to turn off the blickers is my biggest problem, id do forget at times. The window/cuttout in the Radar detector mount is for a view of the temp. and fuel gauge. The knob below the XM is the controler for my Gerbings.
Keith Rosendahl
Sun City, So,Cal
"Blues Traveler"
04' BMW GS Adventurer with Alumigo trailer
05' GoldWing with Trekker trailer
http://community.webshots.com/user/ownst1100
ownst1100 is offline   Reply With Quote
Old 01-23-2008, 05:49 PM   #60
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,490
Talking keep them coming!!!
Thanks fellas! I have a few new projects for the next few weekend!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Times are GMT -7.   It's 12:08 AM.
