Old 03-09-2008, 08:44 PM   #91
PackRat
Huey Guns
PackRat's Avatar
Oddometer: 1,455
Originally Posted by torags
Hey packrat... those are sweet....
Thank you, Sir!
"Packrat" IBA# 11205, AARP, ATP, CFI, A&P, USMC
__________________________________________
Rigor Mortis will be the first indication that I've grown up!!
Yungas Rd.-Bolivia, Alaska '08 - Labrador '10 -
PackRat is offline   Reply With Quote
Old 03-10-2008, 06:08 AM   #92
pfestus1
Slasher
pfestus1's Avatar
Oddometer: 612
Headlight And Oil Cooler Protection
Here's shot of my home made headlight and oil cooler protector:
The headlight cover is a scrap piece of Lexan, I have changed the white plastic bolts to black. The oil cooler screen closeup:
The screen was sourced from a mesh letter tray from Wal Mart
Attached the pieces to the frame tube with these little clamps:
Hank Pfister
Copper Hill, VA
2007 R1200GS, 1973 R75/5/Dnepr, 1984 R100RS/Motovation,
Gotta get my post count up
pfestus1 is offline   Reply With Quote
Old 03-10-2008, 07:31 AM   #93
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,912
Originally Posted by GS N RVN
I used 3/4" shrink tubing with rubber o rings to cover the machined aluminum shifter tip. Now I have a rubber tip, almost like the stock shifter.
I did the same with mine, except no O-rings. It works well, but I think I need two layers.
Jim
Old 03-11-2008, 04:51 PM   #94
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
Not as fancy as Packrat's dash, but here's what I did two weekends back.
Took the Jet 4 Power, a Datel meter, and a $3 Hobby box from Radio Shack and made this completely sealed gizmo.
I joined the pos and neg wires for the J4P, and Datel and routed them to the centech, then ran the wire to the O2 Sensor. Pretty clean install.
I trust the datel a bit better than that all in one thermometer/voltmeter/clock/timer non-waterproof piece of crap Aerostich sells.
Now, ditch this box and make another box that holds all three if I can find a nifty digital thermometer to include.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-13-2008, 10:42 PM   #95
kodiakfrank
Gloria's Cheerleader
kodiakfrank's Avatar
Oddometer: 9,624
Laugh Penny Tech on my DRZ.
I hand fabricated the lower mount for the RAM ball to fit on the cross bar for my E-Trex. Also added a mountain bike pump with two settings (high pressure or high volume).
I fabricated a tool tube from 3" PVC pipe (DWV sch 40), pressure plug and 3/16" x 1" aluminium flatstock. The tube also holds my soft bags out from under the rear fender.
Forward tube plug is rubber. Tube holds tire repair stuff including irons, allen set, electrical tape, zip ties, rachet and sockets. Wing nut is safetied with a clevis pin. Very robust and absolutely waterproof.
Heat shield to protect soft bags made from .030 aluminum with 1/4" stand off from pipe.
Project in progress... Kolpin 1.5 gallon fuel (or water... depending need) can mount will replace stock fender bag; combined with IMS tank this will allow at least 5.5 gallons of total fuel onboard if needed.
kodiakfrank screwed with this post 03-13-2008 at 11:16 PM
kodiakfrank is offline   Reply With Quote
Old 03-13-2008, 11:01 PM   #96
kodiakfrank
Oddometer: 9,624
Penny Tech on my 1150 GS Adv.
Self fabricated light bar (1/4" x 1 1/8 aluminum) with 6" hella 500 spots and forward mounted turn signals. The front also has self fabricated oil cooler protection made from very small steel mesh and 3/16" Lexan headlight and driving light covers with Velcro attachments.
MSR bottle holder for engine oil.
Ram ball mounted below the left windscreen stand off; used for GPS unit.
Hand protector extentions made from 4" rubber floor moulding and secured with two screws with self locking nuts.
kodiakfrank screwed with this post 03-13-2008 at 11:11 PM
Old 03-14-2008, 05:05 AM   #97
josjor
Location: The largest geological formation in the U.S.A.
Oddometer: 2,919
I looked but didn't find any pictures after the final tweaks were out but you get the idea.
This is a dash shelf I made out of a piece of aluminum angle I found at the local recycler. Cut to shape, added modified u-bolts, and later coated the top with velcro. I have corresponding velcro on the back of my GPS, 12v multi-plug, and Sirius radio. I've ridden some rough terrain and everything has held just fine.
I guess I should add that I also trimmed that 2" of bolt you see sticking out towards the dash!
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is online now   Reply With Quote
Old 03-14-2008, 06:48 AM   #98
JimVonBaden
"Cool" Aid!
Oddometer: 53,912
Great job on those light bars. Excellent design, and a sweet way to protect your turn signals , though, of course, the light might be a little less protected!
Jim
Old 03-14-2008, 10:14 AM   #99
ducwad
Livin' the dash
ducwad's Avatar
Oddometer: 339
Is that a little bell hanging from the light bar near the fork tube?
- Ducwad
2012 Moto Guzzi Norge
1995 Ducati 900 SS/SP
1992 Ducati 900 Superlight
ducwad is offline   Reply With Quote
Old 03-14-2008, 10:46 AM   #100
torags
torags's Avatar
Oddometer: 2,469
Hmmm... The light bar has two swival joints. How do you keep them from swivaling?
Rags
'02 BMW R1150R now
'04 BMW R1150RS/// Gone, but not forgotten
'07 HD XR 883R Sportster "Widow Maker"///Gone!
IBA #17225
torags is offline   Reply With Quote
Old 03-14-2008, 12:12 PM   #101
JimVonBaden
"Cool" Aid!
Oddometer: 53,912
It's a good luck bell. It has to be given to you for luck. You see them mostly on HD, but lots of others have them too.
Jim
Old 03-14-2008, 01:32 PM   #102
Squeaky
A Few Loose Screws...
Squeaky's Avatar
Oddometer: 1,610
Jim
I've always heard it called a Gremlin bell - to ward off the bike gremlins. I was given one last year by a friend and it's got a rose and "Lady Biker" on it. One of the coolest gifts you can get.
Rebecca
Houston, TX
'03 VStrom 1k "Wilbur"
'98 XR400R "Templeton"
Squeaky is offline   Reply With Quote
Old 03-14-2008, 03:53 PM   #103
ducwad
Livin' the dash
ducwad's Avatar
Oddometer: 339
Jim
We put bells on our horses and mtn bikes out here to warn the cougars & bears we are coming. Being kodiakfrank I thought it might be something more interesting. Oh well.
- Ducwad
Old 03-14-2008, 04:32 PM   #104
kodiakfrank
Oddometer: 9,624
That's a gremlin bell givin to me by my neice. I guess the ringing drives the gremlins crazy so they fall off the bike... thereby protecting you from harm.
Old 03-14-2008, 04:42 PM   #105
kodiakfrank
Oddometer: 9,624
Those are not swivel joints, they are support tie-ins for the actual light bar. The light bar itself is a one piece unit (welded at the angles) the entire width.
I made the extra supports because I didn't feel the bolts under the beak were sufficent to stop movement or prevent failure. The aft bolt of the tie-ins attach to the frame where the turn signals normally attach.
The bar was designed to hold four lights of similar size (top driving lights/bottom fog lights). I found that I really don't need the fogs so I may trim the bar accordingly... or maybe I'll move the turnsignals and put the fogs on anyway.
Times are GMT -7.   It's 05:57 AM.
