Old 08-25-2013, 04:19 PM   #1216
Jnich77
Jnich77's Avatar
Oddometer: 669
Originally Posted by bwringer View Post
Hockey puck.
Just ordered a puck off Ebay for 3.99, you are my hero!!!!!
Jnich77 is offline   Reply With Quote
Old 08-25-2013, 07:40 PM   #1217
majorpayne
majorpayne's Avatar
Oddometer: 254
Finally got my rack system finished up, sort of. Gotta clean it up a bit and paint it but this is pretty much it. I'm pleased with how it turned out for being made with scrap metal and put together hastily with my mig welder. I could've been patient and taken it and tig'd it up but I'm not good with patience.
majorpayne is offline   Reply With Quote
Old 08-26-2013, 04:19 PM   #1218
majorpayne
majorpayne's Avatar
Oddometer: 254
Old 08-29-2013, 01:44 PM   #1219
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
F800GS Pelican Storm Top case
I decided to replace my soft tail pack that was my camp cooking kit with a larger Pelican case. I wanted to be able to remove it easily so the entire kit could be carried to where ever it was needed, or be quickly removed when not needed/wanted on the bike.
I have the Touratech stainless luggage plate which has a large tube frame on the edges. I fabricated a mounting system that takes advantage of that and the plates trapezoid shape. Basically, two side blocks that wedge tight on the sides and a third on the back with a securing plate to hold it on. Just two thumb screws to remove it. I used a plastic cutting board cut to fit the bottom of the case to add stiffness and to fill the gap between the case and luggage plate. I rabbeted the edges so it fits flush to the bottom of the case and allows the mounting blocks to fit flush as well.
Luggage plate
Top case mounted
Bottom view mounted
and from the back
Bottom of the box
side block
rear block and securing plate
securing plate and thumb screws removed
reinforcing plates inside
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS screwed with this post 08-29-2013 at 01:44 PM Reason: added bike model to title
MCMXCIVRS is offline   Reply With Quote
Old 08-30-2013, 12:08 PM   #1220
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,781
That looks great, nice job!
89 Transalp-98 FXDWG
AMA member
BOBaloo22 is offline   Reply With Quote
Old 08-30-2013, 08:10 PM   #1221
fhfr436
Thirsting for ADV
fhfr436's Avatar
Oddometer: 128
Luggage plate
This is a really great job. How did you fabricate the aluminum clips?
Never Forget Septermber 11th, 2001
fhfr436 is offline   Reply With Quote
Old 08-31-2013, 08:22 AM   #1222
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
I machined them out of solid aluminum pieces using my milling machine and lathe.
Sent from my Nexus 7 using Tapatalk 4
Ed
Old 09-01-2013, 08:22 PM   #1223
fhfr436
Thirsting for ADV
fhfr436's Avatar
Oddometer: 128
Well, sure ... if you have that kind of horsepower!
I'm working with hacksaws, hand files and cordless drills.
Old 09-01-2013, 10:19 PM   #1224
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,359
lol
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 09-02-2013, 02:00 AM   #1225
majorpayne
majorpayne's Avatar
Oddometer: 254
Did the KLR-ish fairing mod and fit a Honda XR650 tank
Old 09-02-2013, 09:30 PM   #1226
FloorPoor
Oddometer: 710
^ That's turning into the coolest S.S. ever. ^
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor is offline   Reply With Quote
Old 09-02-2013, 10:37 PM   #1227
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
I do consider myself fortunate to have nice toys, I mean tools to work with. I bought the benchtop mill about a year ago and have used it for a few bike related projects.
Ed
Old 09-03-2013, 08:14 AM   #1228
Plaka
Brevis illi vita est
Oddometer: 4,586
google: street of the gunsmiths.
Old 09-03-2013, 08:23 AM   #1229
Plaka
Oddometer: 4,586
Throttle lock.
Used for high idle warmup. using for riding a bad idea. machine work with a drill press and a file. up is locked.
Old 09-03-2013, 11:24 AM   #1230
ewmccraw
Oddometer: 2
Originally Posted by DYNOBOB View Post
Borrowed Newner's idea but did drop $25 on a new pr of coveralls. Tent in one leg. Jetboil, Helinox, Exped mat, food, axe in other leg. Sleeping bag across the top. Was on the verge of buying a GreatBasin or NomadRider when I ran across this. Thank you Newner!
You guys ever think about using a pair of fishing waders? They'd be waterproof then!
ewmccraw is offline   Reply With Quote
Times are GMT -7.   It's 03:30 AM.
