09-16-2008, 06:04 AM
#136 |
message in a bottle
Oddometer: 8,744
It seems like it would be fairly simple for anyone with minimal electronics skills to make a hardwire power supply for anything with a USB connector (cell phone, GPS, iPod etc), since they are all 5V.
It irks me that everywhere we turn vendors are hammering us for upwards of $30 for what is basically a $2.99 part. You can buy USB cables on Fleabay for a couple of bucks all day long. I have seen the same cigarette lighter to USB adapter for sale from $2.99 to $29.99. Can you say markup? A 5V regulator is about this simple ![]() wire a USB lead to the output side and its done. |
09-23-2008, 10:16 AM
#137 |
Keeper of Useful Sarcasms
I used my XOG this weekend to run the Arkansas section of the TAT. Functionally it worked great, easy enough to create the route in MapSelect, easy to download and use while on the road.
I had originally planned to use the non-turn by turn mode of navigation, but at a whim gave the TbT mode a try with the route. It worked great, never did it try to route me around anything, it just followed right along the planned route. Now for the bad news. I ride a 990 Adventure, have the XOG mounted on the dash with the RAM cradle. I use a 12" Powerlet to mini-usb cable plugged in to the stock Powerlet port on the bike. Everything has worked pretty well for the last 6 months. This weekend was the 1st long duration offroad ride I've taken. By the end of day 1 the power connection was getting to be a problem. I thought the connections (USB) were getting dirty and causing failure, after cleaning everything with no improvement I started looking at how snug the connection was. I could wobble around the plug and get the power to fail.. so i tried to tighten up the connection. no real help. By the time I finished Day 2 of offroad the power connection was very hit and miss. I was having to stop, hold the connection still until I could determine the next few turns of the route. The entire trip I was thinking the problem was the Powerlet cable, but once home and plugging the XOG into another cable I realized the problem was on the unit itself. Luckily I live in the same town as Lowrance, they want me to bring the unit in for testing. I'll report how that goes. So after that long story, does anyone found any better options for keeping the unit powered up in more harsh environments?
Smugmug $5 off coupon code q8wOGo0Dzq06c |
09-23-2008, 10:33 AM
#138 | |
Follow me
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE Robert rwamf homepage |
09-23-2008, 12:33 PM
#139 |
I remember seeing the pic of your 90 degree connector and think that would help by itself because it can be secured easier than the straight style on the powerlet cable I'm running.
I think I'll give that a try next. do you have a pic of the power side of your XOG with the power removed? thanks
09-24-2008, 01:56 PM
#140 |
Montana Adventurer
Oddometer: 278
I have the right angle usb power connection and..
With the RAM mount, the usb end doesn't seem quite long enough to engage fully even with the rubber peeled back. I haven't ridden it in a bad vibration situation yet. Maybe a light silicone will help hold it in.
JB |
09-24-2008, 02:06 PM
#141 | |
Follow me
09-25-2008, 09:49 AM
#142 |
Montana Adventurer
Oddometer: 278
Thanks for the suggestion. I will look into that tonight. Also,
I loaded a 2GB card into the GPS and tried to register the GPS at Mapselect. I got the windows prompt recognizing the device and providing a drive but when I hit the go to MapSelect it comes back that MapSelect can't be found.
I suspect a card error, what do you think? I could always buy a 1GB card and try it. They are a little sensitive to this it would appear. 2 of the same card side by side and one will work and one won't.
JB |
09-25-2008, 02:20 PM
#143 | |
Can't complain about that level of service!!!
09-29-2008, 08:17 PM
#144 |
Montana Adventurer
Oddometer: 278
Mixed review for the new GPS-Robert are you out there?
Robert:
I did a 300 mile dirt trip this weekend. I drove 50 miles before turning the XOG on. I have not added any maps. I turned on the GPS and then headed up a dirt road for 30 miles and it did not acquire. I stopped facing south and just got a blinking of the last place it acquired-back at home. I tried for another 10 minutes. I stopped up on the top of a mountain next and tried again. It acquired quickly and stayed pretty locked in until I turned it off. Later that day when I fired it back up it would not acquire. I drove 60 mile on the interstate and watched the satelitte screen and it just blinked. There were 10 satelites on the grid but all white on the bar graph vs blue showing its trying to acquire. I stopped out in the big sky twice and nothing. I gave up and shut her down and 12 hours later I fired it up and it acquired in 2 minutes at the house. I have the 1.6 version. I will install the update soon. Do you know any acquiring tricks with this machine? Do you know if there is any difference between the version I have and the new ones aside from the 1.7 programing change? It was kind of frustrating driving home on the freeway at night with a blinking position and a map of where I was last time it acquired. I called lowrance and spoke with a tech rep who knew less about it than i did but assured me if I wanted to send it back she would replace it. That is why i am wondering if there is a difference between the 1.6 vintage and the 1.7 aside from the new download. My buddies say you get what you pay for, Jon. I say I am not satisfied that I know all the tricks and I haven't given it a chance. So, let me know if you have any acquireing tricks please and thanks for any info you have on the productions of this model. Thanks.
JB |
09-30-2008, 08:28 AM
#145 | |
message in a bottle
Oddometer: 8,744
I am happy with the unit but underwhelmed by the support. |
09-30-2008, 08:36 AM
#146 | |
message in a bottle
Oddometer: 8,744
![]() I have only ever had one acquisition issue - a couple of days ago in Yosemite, the XOG kept my position calculated but not my ground speed. Since I had to have a chat with a Park Ranger about that very issue, the timing could have been better ... He let me slide and as soon as I got a bit more sky the speed was back on screen. Other than that, it pulled five satellites from my downstairs motel room.
09-30-2008, 09:55 AM
#147 |
Oddometer: 3
Xog
10-21-2008, 11:44 PM
#148 | |
Dfrag y0ur BrAin
Now I get about a month to learn it before heading into Central America. (Yes I don't expect the base maps to help too much BUT at least it can tell me where I am *LOL*) |
10-25-2008, 06:23 PM
#149 |
Adv Wannabe
Oddometer: 6
Amazon Has Them
Amazon has two left at $169.99 with free supersaver shipping.
http://www.amazon.com/Lowrance-000-0.../dp/B000Y1X4EO |
11-09-2008, 01:51 PM
#150 | |
Follow me
