Thread Tools Search this Thread Rating: Thread Rating: 243 votes, 5.00 average. Display Modes
Old 12-01-2007, 07:16 PM   #16
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
Have over 500 miles on it off-road on my 610 works great,
I can see the screen so much better than the smaller screen units and it does not take up that much space.
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf is offline   Reply With Quote
Old 12-02-2007, 02:55 PM   #17
Neil E.
Neil E.'s Avatar
Oddometer: 299
Very nicely done, I'll have some questions once I get a hands on look at one of these.
Neil E. is offline   Reply With Quote
Old 12-11-2007, 09:39 PM   #18
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
Sat Images
I downloaded an area that I plan on riding next year to do some exploring out here in NV
So far,very impressed with the downloaded images, going to be like having Google earth with you
You can zoom in and see great detail @ 200' scale
The photos do not do it justice, as I can't seem to match the scanning rate of the screen, they are much sharper in person
Robert
rwamf homepage
Old 12-12-2007, 05:07 PM   #19
ISDTBower
ISDTBower's Avatar
Oddometer: 213
WOW! I can remember a couple trips to Colorado where that would have been real handy. Once we took at trail to a mountain top and remembered a dozer road about half way down the other side. We started down to where we couldn't come back up...and then to a 2000ft cliff. The dozer road ended about 1/2mile north. Took us a few hours to get there... Got back wayyyy after dark!
Also "forgotten trails" NEAT!
ISDTBower is offline   Reply With Quote
Old 12-27-2007, 08:14 PM   #20
WRThumper
WRThumper's Avatar
Oddometer: 48
rwamf GPF Mount
rwamf, what mount are you using for your XOG? I'm looking to pull the trigger on one and I'm looking for mount ideas.
"We're surrounded ...
that simplifies our problem." Lewis B. Puller
WRThumper is offline   Reply With Quote
Old 12-27-2007, 08:49 PM   #21
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
I am using the stock mount bolted to an old footpeg bracket that I had laying around. I did put a lanyard on it just in case it did pop out of the mount. I also modified my rubber flap with a tight sealing hole that the USB cable goes through thus retaining some of it's splash proof rating, The USB cable looks as if they anticipated this as it has a longer shaft than a standard usb cord. It is also held in much tighter.
Hopefully Ram will get there mount out soon.
Robert
rwamf homepage
Old 12-28-2007, 07:07 AM   #22
canadaler
canadaler's Avatar
Oddometer: 339
I'm looking at the XOG as well...also was considering a Magellan CrossoverGPS...but (and somebody correct me if I'm wrong here)...the Crossover does not have as much capacity to store as many waypoints and tracks as the XOG. I like the ability to download satellite views into the XOG...but as of yet...none are available for Canada...at least that I can find. Actually the XOG is not available through Lowrance dealers up here yet...I've been told "end of January...hopefully."
Being a complete noob at waypoint and track downloading into units...I am a little apprehensive as all events I am likely to use the XOG in are based on Garmin files...although "translating" them can't be that big of a deal...I hope.
Rwamf:...have you put a screen protector over your unit...and if so what type?...I see there are at least a couple of different types available.
PS:...maybe none of my "bees wax"...but it looks from your photos that to the right of your GPS you have a clamp on your bars with the bolt ends protruding about 3/4" and sticking up. (Or are they toggle switches????) If they're bolts they might tear a real nice gash in the front of your thigh if you take an unexpected trip over the bars!
canadaler screwed with this post 12-28-2007 at 08:05 AM
canadaler is offline   Reply With Quote
Old 12-28-2007, 08:14 AM   #23
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
PS:...maybe none of my "bees wax"...but it looks from your photos that to the right of your GPS you have a clamp on your bars with the bolt ends protruding about 3/4" and sticking up. (Or are they toggle switches????) If they're bolts they'll tear a real nice gash in the front of your thigh if you take an unexpected trip over the bars!
Magellan Crossover does not allow you to import tracks!
Garmin Mapsource will save a track file as a "gpx" the default is "gpd" and tracks listed here @ ADVRIDER are "gpx" files, You can load a "gpx" file into the XOG it will read it, I have done it. It loads into the unit much slower but it works with only some of the "track only" files I have tried. I just tried it with " Jeff@TheQuadShop's White rim file and it was fine.
Translating the Garmin files( gpd or gpx ) to the "usr" format is very easy, The best is to get the raw unfiltered files from whoever, as most Garmins will only allow you to import up to twenty 500 point tracks (Color units, B&W units only 250 point tracks) With the Lowrance track files can be up to 9,999 points in each track, ( and each saved "usr" file can have up to 100 tracks in it)which gives you better resolution. I use GPSBABEL as it is very easy, But most Dual Sport rides only supply Garmin files so I always carry my small Laptop, and I have a small USB/SD card reader/writer that they can transfer the file to.
I have not put a screen protector on it. Don't like them, I do carry a soft rag and a small can of Plexus
The bolts sticking up are from a RAM mount ball, it is hard to see but the Ram Ball sticks up between the two bolts
Robert
rwamf homepage
rwamf screwed with this post 12-29-2007 at 11:22 PM
Old 12-28-2007, 09:13 AM   #24
canadaler
canadaler's Avatar
Oddometer: 339
Whew....good thing I got outbid on e-bay last night
'10 Gas Gas EC300
'08 Husaberg FE550
'09 Husqvarna TXC250
'84 Honda VT500FT Ascot
Tuareg Rally 2009
Old 01-09-2008, 10:59 PM   #25
VelvtRide
i can haz a motrsykle?
VelvtRide's Avatar
Oddometer: 25,605
Nice write up, Robert.
Ninja Skillz... I haz dem.
Eat to live, don't live to eat. - VelvtRide, 2011
VelvtRide is offline   Reply With Quote
Old 01-10-2008, 12:21 PM   #26
Heath3n
Oddometer: 15
So I have a question. I'm pretty much strictly a pavement rider (I'm just here for the ride reports! ) How would this compare to the Zumo 450 as far as practicality and costs go? Also....how is the accuracy for streetmaps and such? Thanks!
Heath3n is offline   Reply With Quote
Old 01-10-2008, 03:05 PM   #27
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
Can't speak too much about the Zumo but from what I know about it is a great Street GPS, The way it handles tracks is my main complaint, It has to convert a track to a route and that way you can not display a multiple of tracks at the same time, but if you are street rider that may not be important. The Lowrance XOG has the 07 Nav-teq data and is very accurate. The screen is not as bright as the one on the Zumo. But the Data displays on the Lowrance are the best,(IMO) and for the money it is a very good deal, but as of right now there is no Motorcycle mount for it, RAM is still a couple months away. I modified my stock mount and it works okay and have taken it on some very rough rides and all as worked as it should.
I do not use the MP3 player but I did try it and it worked, but I have a very small 1Gig player I put in my coat pocket with some very comfortable earplugs when I have to burn some slab and want some tunes. I do not think I would like a wire going to my bike.
Robert
rwamf homepage
Old 01-10-2008, 10:12 PM   #28
MotoJim
MotoJim's Avatar
Oddometer: 222
Maximum SD Card Size
Robert,
Do you know what the maximum SD card size the XOG can handle is? Seems like I read somewhere that it couldn't handle sizes greater than 2GB.
The XOG might be the value leader right now.
Garmin is really missing out by having their silly saved track log limits.
Jim
MotoJim is offline   Reply With Quote
Old 01-11-2008, 11:42 AM   #29
postaldave
gone postal
postaldave's Avatar
Oddometer: 796
it's not the size it is the TYPE of SD card.
read this
http://en.wikipedia.org/wiki/Secure_Digital_card
basically you are general safe up to around 2 gigs but anything bigger
will likely be SDHC instead of SD.
lowrance says the hardware can't handle it but it really is just a software problem.
the answer is
you can get as large an SD as you like but make sure it really isn't a SDHC.
postaldave.com
5united.net
facebook.com/slash5
1972 BMW R75/5 toaster
1995 BMW GS 1100
2001 yamaha kodiak 400
2002 HONDA VFR interceptor
no one is promised a tomorrow but one more ride would be nice.
postaldave is offline   Reply With Quote
Old 01-11-2008, 01:14 PM   #30
VStromNC
DNS/DNF
VStromNC's Avatar
Oddometer: 852
I had the same problem but found a 4GB non SDHC card from Buy.com. I think 4 GB is about max you can go without going to SDHC format.
The 4GB non SDHC card is from a company called Transcend. Part# TS4GSDC. No problems so far and it's taken a beating on my V-Strom 1000.
14 TR650 (Terra)
06 DL1000K6 (Vee)
VStromNC is offline   Reply With Quote
Times are GMT -7.   It's 01:03 PM.
