Thread Tools Rating: Thread Rating: 1743 votes, 4.99 average. Display Modes
Old 03-03-2009, 12:54 PM   #7531
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Originally Posted by LowandSlo
Came across this rare bird:
Bigass 210?
Maybe modded for sky diving?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 03-03-2009, 01:06 PM   #7532
LowandSlo
YMMV
LowandSlo's Avatar
Oddometer: 234
Well technically it's a 210-5, but called a C-205, N205CL and probably 205.
Now back to the regular broadcast.
Eschew Obsfucation.
LowandSlo is offline   Reply With Quote
Old 03-03-2009, 02:53 PM   #7533
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,734
Shouldn't this be in Shiny Things?
Old 03-03-2009, 04:34 PM   #7534
Heymarz
Gaily Retarded
Heymarz's Avatar
Oddometer: 3,236
What if it's camouflaged, does that count as a "shiny thing"?
Heymarz is offline   Reply With Quote
Old 03-03-2009, 04:37 PM   #7535
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,734
That reminds me of the Kriegsmarine camouflage schemes:
Here's the Missouri:
http://pro.corbis.com/images/BE03494...B81C82358A4%7D
Klay screwed with this post 03-03-2009 at 04:42 PM
Old 03-03-2009, 05:12 PM   #7536
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Got one out in our hangar.
I want to fly it badly.
Old 03-03-2009, 06:16 PM   #7537
AK Bear
AK Bear's Avatar
Oddometer: 1,614
Don't know if I 've seen one of those before, it doesn't look like a 210. My 206 has aft doors on the right side, but it's a U206. I know they made a 205 that was configured differently with two doors up front but haden't known of aft doors on the left.
AK Bear is offline   Reply With Quote
Old 03-03-2009, 07:00 PM   #7538
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
We have a turbo'd 210 out in the hangar. Looks almost exactly like that except the cowling maybe a little bigger.
Old 03-03-2009, 08:45 PM   #7539
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,844
A C210 has a cantilever wing (no struts) and retractable gear. Hard to confuse with a 206.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 03-03-2009, 08:52 PM   #7540
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,734
When I google the tail number, though, I find this:
http://www.airport-data.com/aircraft/N205CL.html
Old 03-03-2009, 09:01 PM   #7541
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,844
Apparently its a C205 which was built for only two years and was derived from the 210 although it bears much more resemblance to the 206 and 207 Stationaires. It had the 260 hp Continental IO-470 motor.
Rick, Chapleau, ON
Honda Trail CT90
Old 03-03-2009, 10:46 PM   #7542
AK Bear
AK Bear's Avatar
Oddometer: 1,614
Here is my 206. http://www.airport-data.com/aircraft/photo/110896.html
I searched for it on the site and the photo came up. I have no idea how it came to be photographed or who Doug Robinson is. Kind of wonder what's up. Maybe some kind of plane spotting, like train spotting was like in the 50's.
Notice the length of the flaps and that the alerons are extended as well. This is part of the Robertson kit that allow it to take off at below at 40 mph and climb like a mother! The radical leading edge palys a part as well. I've really only put it through max climb once just to see what the book stats looked like in reality. Pretty fn scary/amazing. 300 ft take off in calm wind with a clilmb over a 50 foot object at 54mph, not knots, mph. Clears the 50 ft object in 589 ft. Now that's a nose up position,but absolutely stablewith a leg of right rudder pushed in. It's a real climber but it looks pretty reckless when you do it. We put a set of GAMIs in and an instrument that reads each cylender head temp and exhost gas temp so we can lean below peak. We've been consistantly runnng at 11 gallens/hour where as befor the GAMIs we used 15 and tried to be rich of peak. We have way coller engine temps and save about fifteen or twenty dollars per hour on fuel.
We can, and have, carried 4 large adults, a 100lb golden retrevier. a zodic raft and motor, all our gear and 3 ice chests filled with food and drink for 4 days. That sucker can hold a ton in the floats which are in the perfect weight and ballance place for heavy items leaving the rest for sleeping bags, dogs, gourmet food and a boat. Try putting all that in your jessies!
nofate, you have some very nice radios in that panal, but did you really pull the mixture during the runup? What's up with that? We usually just check the mags, fuel flow and cycle the prop. Pull the the rudders up clear left and right and go, of course after Hood Tower lets us go.
AK Bear screwed with this post 03-03-2009 at 11:49 PM
Old 03-04-2009, 06:56 AM   #7543
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,844
Thats a nice 206 you got there with the Robertson STOL.
I confirm function of the mixture control during runup by pulling it briefly until the motor just starts to die. After a long warm up taxi to my takeoff area I think it also helps to clear the plugs of any carbon buildup during extended low rpm, rich mixture operation. Taxi at 1,000 rpm unless the prop is picking up water. This proceedure is taught at the flight schools around here.
Rick, Chapleau, ON
Honda Trail CT90
Old 03-04-2009, 09:48 AM   #7544
flanga
Delusions of Adequacy
flanga's Avatar
Oddometer: 2,806
Why wouldn't you want to fly it well?
2005 GL1800
2005 KLR 650
fredlanga.blogspot.com
flanga is offline   Reply With Quote
Old 03-04-2009, 09:49 AM   #7545
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,734
Mitsubishi Mu-2
Thread Tools
Times are GMT -7.   It's 11:22 AM.
