Old 12-27-2011, 02:29 PM   #256
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
The can does tend to stick out further...especially towards the back. Some of you may recall that I had the Highwaydirtbike.com rear LED blinkers. Although they were VERY nice, very well tucked in and protected, and very bright...having the only option to mount them flush next to the LED tail light rendered their visibility quite weak, so I had to go with the R&G ones that came with the tidy tail. That said, these guys perform great, and are made out of metal, so should withstand some beating...
If I had the HDB.com ones still, I guess I would have gone with a 1" spacer and the tip of the can would have "come in" a couple of inches...
I usually mount my Great Basin right in front of the TT large rack, which is good in this case as it will be closest to the mounting bolt, and make use of the heat shields (I do plan on buying an exhaust slider to put even more space between the plastic/bag and the can).
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 12-27-2011, 02:31 PM   #257
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Last picture...again keeping in mind the Great Basin mounting...I plan on having the 1" webbing travel right at the bulge of the rear heat protector and down towards the footpeg...so it should be good...
Old 03-25-2012, 11:48 AM   #258
LangKat
LangKat's Avatar
Oddometer: 68
Noticed when mounting my SR exhaust that it touches the subframe (still the aluminium one). So I moved it around a bit but I can only get it about 0.5cm from the frame.
Any material geniuses out there who can tell me if this a problem?
LangKat is offline   Reply With Quote
Old 07-15-2012, 02:18 PM   #259
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
Originally Posted by snooker View Post
Leo Vince 20% off sale for now.. at SierraBMW so that makes it $303.
Their sale is on again, same price as before.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 08-20-2012, 11:53 AM   #260
vrinteractive
Oddometer: 10
I'm looking for a stock exhaust if anyone has one laying around.
vrinteractive is offline   Reply With Quote
Old 01-22-2013, 08:55 PM   #261
TurbStLCards
Doesn't Like Stuff
TurbStLCards's Avatar
Oddometer: 60
Here is a scratched up one.
http://www.ebay.com/itm/BMW-G650-X-C...06113a&vxp=mtr
I would love a used Leo Vince or Remus (or anything aftermarket really) if anyone has one they would like to part with.
TurbStLCards is offline   Reply With Quote
Old 01-24-2013, 03:57 PM   #262
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 460
I have a Remus titanium that will work with a stock header. It had a slight scratch and I just polished it out. I popped the end can off last month to check packing and install a 2nd sound baffle ( from a Staintune pipe). It is still too loud for me so I put the stock can back on. I'm open to offers. If you want to reopen it to remove the internal baffle, you would just drill out 6 rivets remove one screw and reassemble.
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 01-24-2013, 04:02 PM   #263
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 460
I swapped the stock header for a remus header. The stock header shrinks from 42mm to 40mm as it heads back to the muffler while the Remus starts small at 39mm and grows in diameter to 45 (use without the stock pipe gasket). I need to ride it to see if top speed increases, but theoretically, the hot gas expanding in the stock header - going from big to small - would have set up some shock waves (like in a 2 stroke expansion chamber) and without a dyno I will never know if the stock header helped or hindered scavenging from the cylinder - so it will be a seat of the pants dyno conclusion when the roads are clear.
aprilian screwed with this post 01-26-2013 at 10:58 AM Reason: added measurements - all ID
Old 01-24-2013, 04:10 PM   #264
mixmasa
what it is?
mixmasa's Avatar
Oddometer: 31
I have a Remus on mine as well. I think it is too loud. Is there anything out there that is quieter? I know the SR is said to be quiet, but I can't find a place that sells it.
2005 KTM 950 Adventure...awesome!
2007 BMW XChallenge(gone)
2002 Aprilia Caponord(gone)
2002 Honda RC-51(gone)
1996 Ducati 900ss sp(gone)
mixmasa is offline   Reply With Quote
Old 01-24-2013, 04:15 PM   #265
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,564
The Leo Vince is slightly louder than stock, but not much different. I swapped to the LV pipe to save some weight and hopefully lose the heat under my left leg. However, after switching I think most of the heat under my leg is coming from the engine itself and the oil reservoir.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-31-2013, 12:51 PM   #266
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,972
Scheffelmeier sells it. I guess he sells it 20% less to export customers. But cant guarantee that.
Cant remember if I posted this earlier in this thread or not. I know I meant to ... A comparison between a stock exhaust and the SR Racing number. As you will see, its not dramatically louder than stock. And much quieter than the remus I used to use.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 02-01-2013, 02:23 AM   #267
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 924
Thumb time to consider the options...
At least on the video I like it better than stock, I might just have to get that upgrade for my X...
jonnyc21 is offline   Reply With Quote
Old 02-01-2013, 02:50 AM   #268
Johnnyboxer
Oddometer: 1,034
I've returned to the stock exhaust
I've found the bike to be about 10mph faster and has more torque, than with the Remus I had before
Apart from th weight, I reckon the stock exhaust is better in all areas
Sometimes aftermarket exhaust gains are a myth and in a lot of cases you actually lose bhp and torque
Some of my friends have found the same with Remus and BOS cans on their G650X series bike and have returned to stock can
I guess BMW got it right
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 02-01-2013, 08:24 AM   #269
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,972
You're totally right there.
http://www.motorradonline.de/sixcms/..._r1200gs_1.pdf
A big detailed test of 15 aftermarket exhausts for the 1200 GS with all the big brands ...
Only 2 of the 15 increased power ... SR Racing and AC Schnitzer. All tested models of Leo Vince and Remus, Arrow, Laser etc, decreased power.
Of the 15, the SR Racing was also the closest to stock noise levels.
So for my money, there are only two exhausts in the race.
The factory BMW one, which is the quietest and 3rd out of 16 in terms of power, and the SR racing which is the most powerful and second quietest - it will also save you about 3 kgs over stock.
I had a Remus for the first 60,000 km on the bike. It was loud and it split open.
Old 02-01-2013, 09:59 AM   #270
Johnnyboxer
Oddometer: 1,034
How much are the SR ones?
Times are GMT -7.   It's 06:48 PM.
