Thread Tools Search this Thread Rating: Thread Rating: 150 votes, 4.99 average. Display Modes
Old 12-31-2012, 06:20 AM   #3286
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,237
Originally Posted by MedicineBow View Post
I do the same thing with my SPOT-1, run it with high-capacity NiMH rechargeables, but carry a set of Lithiums for just-in-case. An advantage of the '1' is it takes larger AA size, and I have run it for a week tracking 12-14 hrs/day, on a single charge of (2) 2000mAh NiMH batteries. The battery indicator turns red after 24-48 hrs, but I believe that just reflects the 1.2v operating voltage of NiMH. No apparent drop-off of tracking rate - it was consistently 70-80% the entire time.
I believe the 'Lithium-only' is just lawyerly CYA from SPOT. Mine has run flawlessly on a steady diet of rechargeables for almost 2 yrs.
It's to keep the batteries from leaking all over the place over time. These things have such a long battery life and some folks don't use them that often that they have a tendency to sit around with the same batteries in them for a long time. I used mine on longer trips for tracking and I've probably only put 3 or 4 sets of batteries in it since I bought it.
If you've ever found a flashlight that has had a set of regular Alkaline batteries sitting in it for a long period of time you probably found a lot of corrosion in the flash light and the batteries were possibly seized in the tube.
Lithium batteries generally do not have this problem, they are much less susceptible to it. Running Alkalines in the unit will not damage it as long as they do not leak. I'd just suggest putting it on a 30 day batter inspection cycle if you decide to run Alkaline batteries in it so you can catch any corrosion issues early.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 12-31-2012, 07:10 AM   #3287
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,663
Bzzt. Wrong, but thanks for playing the game!
If you read Spotmaker's excellent posts (before he finally gave up) you would know why the Lithiums are required:
Spotmaker said in this post (among many others)
"Once again, the primary reason we tell you to use Lithium batteries is because Alkaline batteries DON'T WORK if the temperature is below freezing! This has nothing to do with what device they are powering.
Put alkalines in your SPoT, send check in messages during a relatively warm day, it works great. Then, you get a sudden temperature drop, you're getting hypothermia, you hit the 911/SOS button and those alkaline batteries aren't working anymore!
So, the new SPoT insists on Lithium batteries for the same reason the old one did.
I work for Axonn LLC, the company that designed and manufactures the SPoT Satellite messenger. However opinions expressed here are mine and mine alone and do not necessarily reflect those of SPoT INC. or Axonn LLC."
Emmbeedee screwed with this post 12-31-2012 at 05:35 PM
Emmbeedee is online now   Reply With Quote
Old 12-31-2012, 12:18 PM   #3288
jeepinbanditrider
Oddometer: 1,237
Ok. Thanks.
I came on on the tail end of this thread because of a recent merge. Sorry didn't read the whole thing.
Sent from my iPhone
1978 GS 1000
Old 12-31-2012, 01:01 PM   #3289
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,663
Ok. Thanks.
No problem - the question comes up periodically, so those of us who've read from the beginning have seen it often.
Old 01-01-2013, 03:22 AM   #3290
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Originally Posted by HogWild View Post
It's worth it just for that. Plus you get the added bonus of the 911 feature! See the BOG SPOT thread here:
http://www.advrider.com/forums/showthread.php?t=282391
Be aware it won't work in the southern part of Argentina and Chile. Those regions are outside the coverage area. If that's a problem, get the Delorme InReach instead, which costs more but also does more.
I must disagree. I rode to Ushuaia in 09/10band had it in tracking mode all the way. It worked fine. That was with a V1
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 01-01-2013, 03:29 AM   #3291
TravellingStrom
Oddometer: 397
Originally Posted by BigToad View Post
I would never leave home without it, read the story under this youtube video pasted below......
It's good for tracking however I will never mount it to my bike again. In this crash which broke my femur if had it been mounted to the bike I would not have been able to activate it as the bike went over the bank and I could not move.
http://m.youtube.com/#/watch?v=qgJqZ...%3DqgJqZ1TaZ5w
That can be fixed
I have mine mounted to the dashboard if my bike. It has a steel cable clip attached to it by wire
I then have a steel cable that clips to that clip and the other end is attached to me
I have tested this a few times now, not intentionally, and each time the Spot comes with me when the bike goes the other way
You still have to be conscious to push the 911 but an ascending track number in one location is as good as that
Old 01-01-2013, 05:47 AM   #3292
BrzGSAdv
BrzGSAdv's Avatar
Oddometer: 50
It seems that the problem here is about SPOT using Globalstar's network vs Iridium in the case of InReach. Please check coverage maps here:
http://www.gtc-usa.com/satphone/Coverage_Maps.html
As you can see map is "grey" at SA's southern end. I think you might have gotten lucky during your pass by the area.
I have asked before but I rarely see people talking about InReach and I am inclined to take my chances with it since the gadget seems a bit more flexible / better tech plus the coverage issue. Bear in mind I LIVE in Brazil so SA coverage is critical and the far end of the continent is definetly in my plans... any MAJOR issues against it?
Going back to the satelite coverage issue I read somewhere (sorry to miss the link here) that Globalstar has been improving its network recently by launching new satelites while Iridium's are supposed to need a major revamp in its satelites by 2014/15. As you folks know those businesses have not been as profitable as expected by the early 2000's, had to file for cahpter-11, so any major investment needs on their part is something to be considered by users beforehand...
Does InReach gets access to the same 911 network SPOT does? What about GOES? Any similar service available?
Great 2013 folks!!
...work, work, work + kid + 2011 BMW GS1200Adv.
...wifey + 2007 Ducati Monster 696
...job + 2001 Yamaha XT600
1978 Yamaha TT125
Ride on!!!
BrzGSAdv screwed with this post 01-01-2013 at 06:06 AM
BrzGSAdv is offline   Reply With Quote
Old 01-01-2013, 05:49 AM   #3293
DualSport855
what he said
DualSport855's Avatar
Oddometer: 129
Travellingstrom can you show us a picture of your Spot leash set up?
2007 990 Adventure US Orange
Riding in Alberta, BC, NWT and Yukon is most amazing.
DualSport855 is offline   Reply With Quote
Old 01-01-2013, 07:19 PM   #3294
TravellingStrom
Oddometer: 397
HI
This is the original setup, but was not perfect, it was fine tuned over time
The mount was changed to a RAM mount after I had physically seen one, it works a treat.
The main difference is, the connector at the SPOT end is now sitting in the front of the SPOT, I have wrapped tape around it and then a length of wire to hold the snap lock, you can see it in the bottom of this next photo
That connector is a marine fitting, I have no idea what name it goes by, but the cable side bit needs to be slid back before they disconnect or connect. There is s ball nestling in there which helps the swivel
The other end is just a jaw type dog clip, this clips to my jacket zipper usually.
When it is in the RAM mount, I don't seat it back all the way in, I rest the small wheel thing of the release lever on the join of the two SPOT shell halves at the top. This makes it release smoother and I have less chance if being clocked in the head by a cartwheeling spot. In the lower photo it is seated all the way because I am surrounded by traffic and have no need to tether myself. I only tether when I am up in the hills or by myself
I hope all that makes sense, if not and I will try another way
Cheers
TS
www.TravellingStrom.com -- blog www.richardstravelshop.com -- shop
Old 01-02-2013, 05:58 AM   #3295
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,636
sad, bet they wished they had a SPOT. These are 2 separate incidences.
http://www.detroitnews.com/article/2...TION/212200415
http://www.dailymail.co.uk/news/arti...eze-death.html
PFFOG screwed with this post 01-02-2013 at 06:04 AM
PFFOG is offline   Reply With Quote
Old 01-02-2013, 06:17 AM   #3296
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,663
That's terrible.
I used to think of the Spot as something I'd only carry on the bike but with the weather being so unpredictable, it makes more sense to carry it at all times unless you spend all your time in the city.
Old 01-03-2013, 07:51 AM   #3297
drewjb7
drewjb7's Avatar
Oddometer: 139
SPOT in the news
http://www.unionleader.com/article/2...WS07/121239866
Doesn't mention the SPOT specifically in the story but my wife was watching the news on TV and recognized it. She is a big fan. When she called SPOT a while back to get some help with their website during one of my trips the rep on the phone told her "if it wasn't for wives and girlfriends we'd be out of business."
Drew
"You're confusing me with someone who gives a sh*t." - bad guy in "Kickass"
Ride report: Orange in the Greens
Web:http://dbanton77.wix.com/industrialstrengthpr#
Blog:http://theindustrialstrengthpress.wordpress.com/
drewjb7 is offline   Reply With Quote
Old 01-03-2013, 08:10 AM   #3298
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,663
Drew
Wives, girlfriends and mothers.
Old 01-03-2013, 08:14 AM   #3299
Gillus
High Desert Rat
Oddometer: 795
Just got my spot, it sez in the manual it should be 12" away from another GPS device. Is this an issue??
Travellingstrom has his mounted right next to his in the picture. I like the wire to rider system. I may try it with a tank bag and I am hooked up ear buds to the satellite radio from a tank bag anyway. Just one more thing to unhook.
Disclaimer: I am only responsible for what I said........... Not what you understood or how you interpreted my words!!
Gillus is offline   Reply With Quote
Old 01-03-2013, 11:24 AM   #3300
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,194
Never had an issue with mine and I usually have 2 GPS's on my bike at all times.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Times are GMT -7.   It's 02:15 PM.
