12-28-2010, 12:39 PM
#4216 | |
Oddometer: 1,084
I pretend to work - they pretend to pay me |
12-28-2010, 01:14 PM
#4217 |
Dusty and Thirsty
Oddometer: 1,302
Indeed, I was on the phone with James today.
Rob Swartzwelder, Southern AZ I'm not real fast, but I do have a dog named Dakar! 97 M900, 07 G650 XChallenge,11 KTM 990 ADV R 2011 North up the CDR Sierra Vista AZ to Paonia CO and Back through Moab UT |
12-28-2010, 01:48 PM
#4218 | |
AttitudeIsEverything
Oddometer: 1,255
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
12-28-2010, 06:56 PM
#4219 |
BMW Dirty Dozen
Oddometer: 250
So everyone knows there are two versions of the LeoVince exhaust. The newer ones have the second CF heatshield in the middle of the pipe. The first gen didn't and a few people were burning their legs. I opted to have my dealer order me a new one from LV. Just a FYI
12-28-2010, 07:32 PM
#4220 | |
WELL LIT ADVENTURER
Oddometer: 774
12-28-2010, 07:33 PM
#4221 |
Dusty and Thirsty
Oddometer: 1,302
Good to know, my stock pipe has plastic burnt on it right where the muffler connects to the header, the plastic is burnt off my cheap joe rocket pants. I was going to make an aluminum heat shield for that part of the pipe if necessary, I hope this new one with the shield fixes that problem.
12-28-2010, 07:56 PM
#4222 |
Lost but laughing.
Oddometer: 4,572
If you just open the end up a bit then the heat drops to normal exhaust temps except where the cat is mounted, but it cools down very quickly as well. Have the header pipe ceramic coated and it is cooler again. The weight loss would be nice though.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
12-29-2010, 10:01 AM
#4223 | |
Oddometer: 1,255
Current look:
12-29-2010, 11:33 PM
#4224 | |
BMW Dirty Dozen
Oddometer: 250
12-29-2010, 11:38 PM
#4225 |
BMW Dirty Dozen
Oddometer: 250
01-01-2011, 04:09 PM
#4226 |
Slow Ride to Nowhere
Oddometer: 121
I have decided to keep my X Challenge. I think the motor is the king of the thumpers. It's time to address some issues, on the cheap. I have read through the thread. My budget is 1K, and 250 of that is going in to Mefo tires. Looks like 350 to 500 for the fork springs and re-valve. The forks are simply unacceptable. I am not opposed to waiting for used parts to show up.
Help: I am looking for the pattern for the peg and kick stand guards offered by one of the inmates. I would like these cut out of stainless plate. I would like a real shock. Has any one tried to fit a KTM, non linkage, shock to an X bike? Is there a Japanese shock that would bolt in? I understand the rising rate linkage shocks would need to be re-valved / springed to be in the ball park. I would like to lower the bike by an inch front and rear. I got the recommended YZ shift lever. It fits much like the stock shifter only it sticks out from the case an extra 1/2 inch. The stock shifter is so short I have trouble getting my size 12, Tech 8 boots under it to shift. I would like a piece of broken stock shifter to weld in a small extension. I will drill it out to create weak spots, just in case... All the things that scare me about the X center around the cast frame parts. Stripped out lugs, castings that snap with a small tip over. Aw hell, just ride it. Fix it when it breaks. My ABS X has the small Turatech rack, Tail Tidy, Cycra pro-bend hand guards, I have a Cee Baileys wind screen, not installed. Heated grips will be installed. This bike will also see duty as a bumper bike for camping. The wife says I need to keep this bike, just in case there is an earth quake... Good women are hard to find.
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson 06 FJR1300 09 XR1200 H-D Yea I thought I never would either 75 Norton 850 E-Start Project 69 Z-50A Mini Trail with Lights & 2007 X-Challenge Heavy dirt bike sweet sweet motor |
01-01-2011, 06:12 PM
#4227 | |
Oddometer: 1,434
I need one. Thx!
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
01-01-2011, 07:33 PM
#4228 |
Oddometer: 520
I think you're on the money there Mikey, all bikes have weaknesses and these forums, by their nature, tend to focus on them. I worry about the cast stuff too, but being aware of it is half the battle. I take my bike through some gnarly stuff (Im wary of rock though) and havent broken anything yet.
01-01-2011, 11:22 PM
#4229 | |
Oddometer: 713
Rear shock - I was wondering about the PDS shock last night but I'm fairly happy with the air shock at the moment. I have broken gear lever on my bench at the moment. No problem with posting it to you. |
01-02-2011, 02:08 AM
#4230 |
Lost but laughing.
Oddometer: 4,572
I can only suggest that you do your forks first, you may not worry about the air shock afterwards. I did it the other way around and could probably have saved a chunk of money. Even when you get an Ohlins that is set up for your weight from the factory, it still needs another chunk of money to get it working nicely off road.
