Old 02-04-2011, 03:55 PM   #4411
Muddler
Muddler's Avatar
Oddometer: 764
Thanks Cruz
Originally Posted by Cruz View Post
These guys did mine and do a lot of new bikes from the Husky, KTM and Jap dealers located around them at Springwood. I know Full Throttle Husky use them to do the TE630 pipes from new.
http://www.motorcycleexhaustprofessionals.com.au/
They didn't cut my outer casing but went in through the exit pipe at the rear by cutting out the restrictor and then somehow removing more bits inside and modifying parts and welding them in. Looked a bit like making one of those ships in a bottle but works well, still has the cat in it.
Muddler is offline   Reply With Quote
Old 02-15-2011, 10:37 PM   #4412
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Sorry for the cross-post, but trying to get most eyeballs!
Does anyone own BOTH an Xch and a F800GS? I just noticed that the 8 has a low front fender (60$ on Max's fiche), and that they both share a LOT of common parts (wilbers springs, almost close part numbers, etc...)...
Weird thought: Could the 8's low front fender fit easily on the Xch?
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 02-15-2011, 10:45 PM   #4413
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
I checked into this the last time I was riding with a guy on an 800. Didn't look like it would work due to the lower connection points. Still, if you just rivet it to the existing fork protectors, it should work just as well as the KTM 950 one does.
tbarstow is online now   Reply With Quote
Old 02-15-2011, 11:00 PM   #4414
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Actually I bought F800GS low fender to try to install it to XChallenge.
It doesnt fit straight in - mounting points are different - you must weld it, or use rivets, to attach low fender to oryginal fork protectors
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 02-15-2011, 11:08 PM   #4415
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Thanks Guys - Lucas, how's the fairing coming along? Do you have any pictures of the mounting system? Does it come with a dashboard to install behind it?
Old 02-15-2011, 11:14 PM   #4416
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Fairing from lituania comes just itself. I tryied to make some holding brakets and dashboard on my own. Results posted here (not finished yet - low fender not mounted, front suspension mods not started, waiting for acerbis rear fender 6l tank)
https://picasaweb.google.com/lukasz....WINTERPROJECT#
I will test it during next weekend - if snow will melt down... or even if it will not
Regards
Lucas
Old 02-16-2011, 01:46 AM   #4417
keep it simple!
Oddometer: 147
Yesterday I could test in the pouring rain the effectiveness of the Scheffelmeier high KTM front fender; no more spraying on the rider, at the underside the engine is also much better protected (the fender is cut in 2 pieces).
Though a low fender looks more beautiful, this one is very good on road and going offroad I don't have to change from low to high = more time in the saddle!!!
Stephan is busy with the latest changes to the OEM muffler, ride-report soon!
keep it simple! is offline   Reply With Quote
Old 02-16-2011, 01:48 AM   #4418
pampaX
pampaX's Avatar
Oddometer: 419
Hi mate I'm working on same fairing though still working on bracket. Can u show pic of side mount points?
pampaX is offline   Reply With Quote
Old 02-16-2011, 09:00 AM   #4419
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Can any of you guys recommend some compact, yet really bright turn signals/indicator lights? LED would be great. I have some OEM indicators on the back of my G650 on my custom tidy tail, and they hit the muffler, and H&B bracket (HB bracket and muffler installed after I built the tidy tail). I can make a new tidy tail, but I would rather just install some smaller indicator lights. I also need a new set for my R1200S, as the cheap ebay ones have discolored and look like crap.
Thanks all
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 02-16-2011, 09:43 AM   #4420
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Thanks all
http://www.highwaydirtbikes.com/HDB_Shop/ - that's the route I'm going (already have their hand guards)...
Old 02-16-2011, 09:46 AM   #4421
Niedz
Niedz's Avatar
Oddometer: 614
does anyone have any experience with the HDB integrated mirrors? im curious as to how well they work, how much you can see in them. im thinking either these or the touratech folding ones for my x-co.
either way i will probably get the HDB handguards, just not sure if i want the mirrors or not.
Niedz is offline   Reply With Quote
Old 02-16-2011, 09:51 AM   #4422
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
I've had mine for ~2 years...love them...you won't be able to fix your eye liner at 80mph , but you'll be able to see who/what is behind you...
Old 02-16-2011, 01:40 PM   #4423
Niedz
Niedz's Avatar
Oddometer: 614
how about lipstick?
can i add the mirrors at a later time, or do i need a specific model to run the mirrors?
Old 02-16-2011, 01:48 PM   #4424
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
how about lipstick?
yep - you can add at a later time...I have 2 on order for my rock crawler...the face that they fold when they get hit is awesome!
Old 02-17-2011, 11:19 AM   #4425
sideway5
Mudmuppet
sideway5's Avatar
Oddometer: 36
Any pics?
sideway5 is offline   Reply With Quote
Times are GMT -7.   It's 07:19 PM.
