Old 01-02-2013, 10:16 PM   #5161
Earlevet
ADVEarl
Earlevet's Avatar
Oddometer: 578
I have the H B side racks and rebuilding the rear fender once the tank is fit. I destroyed the wires, turn signals and license plate bracket when the rear fender broke off on a low side. Hoping that there will not be a clearance issue once I am done putting it back together.
Going to the steel yard tomorrow at lunch to pick out some material. Will post up some pics one it is put together.
I will keep my eye out for the pictures of the fuel line connection.
[QUOTE=tbarstow;20382606]Use steel for your first one.
I just used the included clear fuel line and looped it up under the bodywork and into the main tank vent. I'll get some pics tonight.
Earlevet is offline   Reply With Quote
Old 01-02-2013, 11:31 PM   #5162
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,294
Pics added to previous post.
tbarstow is online now   Reply With Quote
Old 01-03-2013, 10:43 AM   #5163
Earlevet
ADVEarl
Earlevet's Avatar
Oddometer: 578
Easy enough on the fuel line hook up! Thanks for the pictures!!!
Old 01-11-2013, 12:43 PM   #5164
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,169
Is anyone using dirtbagz on their xc? I just picked up a xchallenge and I'd like to figure out the luggage. The price is right, but how do they hold up?
Originally Posted by VACommuter View Post
I'd be cranky too if I had to blow 500 horses!
VAC
You can bet your sweet ass and half a titty...
gastone is offline   Reply With Quote
Old 01-11-2013, 12:58 PM   #5165
alpi
alpi's Avatar
Oddometer: 76
There's a thread mentioning them (luggage setups on a xchallenge?) where someone seems to be happy with them... you may want to PM him to find more. I'm endorsing Walter's Magadan bags, but their are larger and much more expensive.
'07 G650 XCh (and '04 recumbent bike)
alpi is offline   Reply With Quote
Old 01-11-2013, 01:12 PM   #5166
Powershouse
Powershouse's Avatar
Oddometer: 2,205
Dirt Bagz
I'm a fan. I've used them on several bikes now. They are rugged, simple and sturdy. You can see my setup in a ride report here. They are not waterproof so I use these for my clothes and roll-top waterproof bags for tools and other stuff. My shoes and jacket liner go in a waterproof bag on top. The design places the weight over the seat with some transfer to the frame via the Dirt Bagz rack. On the trip described in the linked ride report I encountered some heat issues from the muffler on the first day - a sharp tug on the rack moved the whole deal out enough to create some air space and there were no other problems on this trip.
Wisconsin Rustic Road Century
Powershouse is offline   Reply With Quote
Old 01-11-2013, 01:36 PM   #5167
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,169
The magadan bags are nice, but I just can't stomach the price...hence my interest n the dirtbagz. Giant Loop also has some new some soft panniers, to the tune of $650. Yowsa! Just getting higher now. Glad to hear that the dirtbagz are still working for you ph. I emailed their company a week ago, but still haven't heard back.
VAC
gastone screwed with this post 01-12-2013 at 03:28 AM
Old 01-11-2013, 02:03 PM   #5168
Johnnyboxer
Oddometer: 1,034
I had them, but wasn't convinced with mounting in just 2 points - too fragile
So sold on and swapped to HB racks
Never lookend back
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 01-11-2013, 02:14 PM   #5169
bigdon
Oddometer: 2,565
The Dirt Bags are a cheap way to put some Luggage on the XChallenge. Saying that I would not spend the money on them if you are going to travel with them.
Not Waterproof
Racks are not up to the task
Zippers clog with dirt and can be very frustrating.
IMO get something waterproof with roll tops.
I like the Madigans , Andy Straps, and the Wolfman Luggage.
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 01-12-2013, 02:37 AM   #5170
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 911
Thumb Wolfman Luggage...
I use the Wolfman dry luggage and in western WA they are the best choice I could have made. After the rain I am so glad I have them I don't think I would ever get something that isn't waterproof or doesn't at least have its own inner water proof liner.
Just my 2 cents... good luck.
jonnyc21 is online now   Reply With Quote
Old 01-12-2013, 11:42 PM   #5171
Earlevet
ADVEarl
Earlevet's Avatar
Oddometer: 578
Baja 1.1 gallon tank added to XC with Hepco Becker Racks
Thanks to Butter and tbarstow posts of their Baja tank addition I have completed my tank set up. Purchased at http://justgastanks.com/product_info...roducts_id=572 This included brackets that mount to the top of tank and at the front tip. Included aluminum spacer not used. Replaced with rubber stopper drilled through the center.
With the physical help of grinding drilling and cutting 1/4 stock steel from Mouthfulloflake I present you picutres.
We did cut into the cross bar bracket to provide for addition 1/2 inch of room to play. Did not seem to compromise the stability of the bar at all.
Stock signals should mount just fine. Plenty of room.
Instead of using the supplied aluminum spacer we used a rubber stopper. This set up will allow for the tank to run with out the side racks installed.
About 1 inch clearance from the tank to the sidewall of tire.
Test run beginning of next week
Edit: The tank did great! No issues with clearance and it drained into the main tank just fine.
Earlevet screwed with this post 02-04-2013 at 09:43 AM Reason: updated infomration
Old 01-13-2013, 08:21 AM   #5172
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,550
I considered cutting out that same part of the rack. I agree with you and don't think that extra material has any effect on the strength of the rack. I'm still kicking myself for not doing this sooner as the tank had been sitting around my garage for at least a year and the extra range is nice if only to avoid frequent gas stops.
Props to Oggi for posting about this tank back in the day, wherever he may be.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-13-2013, 01:27 PM   #5173
mikeysduck
Slow Ride to Nowhere
mikeysduck's Avatar
Oddometer: 217
Your Seat height?
What is your seat height with a stock seat?
I want to lower the bike 2 inches to swing my stubby legs over. I'm going to need a shock too.
I'm sending my new Shivers / forks from a Husky out for re-building and shorting. I like the seat height to peg spacing no knee issues, so I prefer to not cut out the
seat foam. I am be looking for a stock seat to rebuild. I don't want to destroy this one. I will post my seat needs
in the flea market.
Sorry I can't flip the photos. The look great on my computer, but come out sideways when I post them.
I have my forks lowered to the second mark from the top.
[IMG][/IMG]
I have an aftermarket seat.
The seat height is 37 1/4 in / 946mm at the level and 40.5 in / 1029 mm at the stick
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson
14 R1200RT 09 KTM 450 EXCR 75 Norton 850 E-Start It's going to run. I swear! 69 Z-50A Mini Trail with Lights 03 GasGas 280 Pro 03 CRF 230
mikeysduck is offline   Reply With Quote
Old 01-14-2013, 05:04 AM   #5174
MizzouRider
MizzouRider's Avatar
Oddometer: 1,759
I've put about 5 or 6 thousand miles on my XC with the Dirtbagz now. No issues at all. I actually found a used set with racks, so I got the whole set up pretty cheap. I have torn the connecting strap off the right one, but that was in a pretty hard get off. (Broke my fibula and ankle) I added a heat shield from Giant Loop to help with cooking the bag that's against the exhaust. I've been lucky with rain, so I can't tell you how bad the waterproof problem is.
I did just add a GL Coyote bag. (They were on sale, and can be mounted over the Dirtbagz racks.)
I'd buy the Dirtbagz again though. Best bang for the $$..
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 01-15-2013, 04:28 PM   #5175
vfrpilot
Stress Relief Rider
vfrpilot's Avatar
Oddometer: 708
+1 for Wolfman
Wolman gets my vote. I built the racks and the dry bags are super!
*1975 Kawasaki KS125 **1987 Honda TR200 Fat Cat
*1976 Honda MR250 Elsinore **1987 Honda XR200R
*2011 Beta 400RR **2012 R1200GSA
*2012 Gas Gas TXT250 **2014 Beta 520RS
*2014 Ural Patrol
vfrpilot is offline   Reply With Quote
Times are GMT -7.   It's 11:33 PM.
