Old 01-30-2013, 07:57 AM   #1636
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Team Latus will be running AMA Pro Flat Track this season
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-30-2013, 09:40 AM   #1637
montanaman
Traveler
montanaman's Avatar
Oddometer: 171
2011 Sprint GT's on close out sale !
I am thinking about adding a Sprint GT to my flock. ( 2011 Multistrada, F800GS) because I love the triple motor and it seems like they are practically giving them away here in the US where they did not sell and are no longer being offered. There are a few new ( 2011's so not so new) out there for 10-11k. Seems like a lot of bike for that money. Question is why didn't they sell here and are there any big issues that I should be aware of. I am thinking of getting this bike as a stop gap until the new Trophy gets sorted out and more affordable.
Quit dreaming, get on and start living.
montanaman is offline   Reply With Quote
Old 01-30-2013, 09:55 AM   #1638
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
They did not sell because most did not know about them. The Sport Touring Market is only about 1% of the bikes sold in the USA. They are GREAT bikes. Buy with confidence and have fun.
Bib
Old 01-30-2013, 02:03 PM   #1639
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Just delivered this 2013 Street Triple R
Bib
Old 01-30-2013, 05:12 PM   #1640
montanaman
Traveler
montanaman's Avatar
Oddometer: 171
Now that is a beautiful bike .. congrats !! I love the new exhaust treatment..
Old 01-31-2013, 01:42 PM   #1641
Yostwerks
Oddometer: 189
Lovely bike ... I'm still grinning from a test ride on the Street Triple. I think there's room for one in the garage ... next to the Sprint
02 Aprilia Falco
08 Triumph Sprint
12 ZX14R
Yostwerks is offline   Reply With Quote
Old 02-01-2013, 07:17 AM   #1642
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
Originally Posted by DAKEZ View Post
One off swinger I assume? That is pretty hot.
....and what is this bakes on a flattracker crap? I thought they didn't run any?
Eitherway that should give the Harleys a nice run for their money.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 02-01-2013, 10:14 AM   #1643
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Playing around a little to see what works best.
Need a way to stop them in the pits.
That's what we are counting on. Joe Kopp leading the team with Johnny Lewis riding. "Johnny Lewis" heck, he even sounds fast.
Bib
DAKEZ screwed with this post 03-08-2013 at 07:06 AM
Old 02-03-2013, 07:48 PM   #1644
Censport
Vendor
Censport's Avatar
Oddometer: 424
This '95 Thunderbird was donated to the museum where I work a couple of years ago. Owner bought it new. Running issues developed, apparently scaring him pretty good during a ride. That's all I know.
The bike would start with starting fluid, but it was very rough. Only ran on the right cylinder consistently, the middle one occasionally, and the left one not at all. The airbox was rough and leaky, so we bought a new one. Carbs were funky, so I took them apart and cleaned them. Installed new o-rings under the floats. Blew out the passages for the idle circuit. Soaked the jets in carb cleaner.
Now the bike runs on all three. But only when you're revving it. It will not idle, and it will still only start with starting fluid. It will not start on gasoline from the tank, and the moment you stop revving it, it dies.
I've tried to register on TriumphRat.net, but cannot for some reason. Can't even contact an administrator. So does anybody here have any suggestions?
Censport is offline   Reply With Quote
Old 02-04-2013, 01:29 AM   #1645
PVRnick
Pennsy Flyer
PVRnick's Avatar
Oddometer: 176
Try cleaning the carbs again. Make sure the pilot jets are clean .
Check and clean the enriching circuits for starting and be sure to
check the emulsion tubes above the main jet as they are often
overlooked during a carb clean. Also check for air leaks at the intake
manifold.
Hope this helps.
Nick
Keep your Knees in the Breeze
Nick
'12 Triumph Tiger 800XC
'06 Wee Strom
'95 XR650L
PVRnick is offline   Reply With Quote
Old 02-04-2013, 11:05 AM   #1646
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,354
^As Nick says - also I presume these carbs have the small holes in the top of the venturi near the throttle blades - these can be plugged - clean all these little holes with a guitar string, plenty of carb cleaner and compressed air, making sure that they are clear. That looks like a neat bike! The green is my favorite.
HapHazard is online now   Reply With Quote
Old 02-04-2013, 03:11 PM   #1647
PVRnick
Pennsy Flyer
PVRnick's Avatar
Oddometer: 176
Carb Cleaning
I should also mention that these, and all, carbs from 1978 on have "tamper resistant" plugs pressed into the carb body over the idle mixture screw. These may or may not have been removed previously to you getting the bike. If they are still in place they are easily removed by drilling them out CAREFULLY. Use very light pressure on the drill and be prepared to stop the instant the bit breaks through the plug. Some people use a stop on the drill bit so it cannot go deep enough to damage the screw. If you are careless doing this, the drill bit can catch the screw and run it down into the tiny orifice the fuel flows through and damage the screw and the carb body. You do NOT want to go there ! A small bit works best, just a big enough hole to get the tip of a sheet metal screw started, then pull the plug out with pliers grasping the screw.
These idle mixture screws are usually located on the top of the venturi just forward of the diaphram, or directly under the venturi just ahead of the float bowl. Be careful removing the mixture screw because it will have a very small spring and a washer and an o ring on it. Take note of the order they are positioned in. It is important.
When all is clean set the screws at about 2 or 2 1/2 turns out from being lightly seated to start.
Actually this whole procedure take about 2 minutes. probably took me longer to write
about it than to do it. Very simple really.
I have had very good luck with Yamaha Carb Cleaner. It used to be available, and I hope it still is, in quart bottles.
I always poured some in the float bowl and put all the removed carb parts in the solution. Lightly clamp it in a vise and CAREFULLY heat with a heat gun. NOT A TORCH ! It is flammable ! Allow it to boil for a minute and then let is soak for a little while. Dump the cleaner into a coffee can through a strainer and rinse off your clean carb parts. A very light, small wire brush with brass bristles will polish the jets, etc. and they will look like new.
Reassemble your carbs. Sync and adjust idle mixture and speed and go for a good long test ride on your Beautiful new Thunderbird !
Sorry for being so long winded ! Hope this is helpful.
Nick
Nick
'06 Wee Strom
'95 XR650L
Old 02-05-2013, 07:54 AM   #1648
wwestbrook
wwestbrook's Avatar
Oddometer: 32
Buy one. Trust me, buy one.
2011 Triumph Sprint GT
2005 CBR1100XX
2009 XL1200N - SOLD
1998 Electra Glide - SOLD
wwestbrook is offline   Reply With Quote
Old 02-05-2013, 05:28 PM   #1649
Censport
Vendor
Censport's Avatar
Oddometer: 424
Thanks for all the tips on the Thunderbird! It's back in rotation for the bay, so once hopefully I'll have an update soon.
Old 03-03-2013, 01:05 PM   #1650
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
New owner of a sprint ST
not a new bike but new to me as they say.
needed a road bike, more for her then me, (two up riding) as she hates all my other bikes, but that is a story that could fill an entire other thread.
I saw one on local CL, it had been down but no mechanical issue.
not sure whether to invest in plastic, hard to find and big money, or go nake, turn it into a speed triple like look
please share your thoughts and advice
it needs right side and nose fairings
2005 sprint ST
get out and live
sailer screwed with this post 03-03-2013 at 07:30 PM
sailer is offline   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
