Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 08-31-2011, 12:17 PM   #39346
MeanStreaker
KLR > Pee-wee's Bike
MeanStreaker's Avatar
Oddometer: 511
Originally Posted by Just GO! View Post
I'm possibly getting a DRZ400E that's currently titled and street legal in Michigan. I know this kind of question has been asked and answered on here before. Anyone know if there would be any issues with getting it licensed in Ohio?
Get in touch with nconoan if he doesn't see your post. He recently did it and will tell you how easy it was.
"Those who expect to reap the blessings of freedom must, like men, undergo the fatigue of supporting it."
Learn how Project Appleseed is supporting freedom.
MeanStreaker is offline   Reply With Quote
Old 08-31-2011, 06:43 PM   #39347
Mr. 0
Mr. 0's Avatar
Oddometer: 353
Alright, I could probably throw this in Beasts, but I figured there's plenty of knowledge here.
So, as many of you know I have a 2000 Tiger with ~8k miles on it. It's stock except for tires, and it has the "off-road" ECU map.
The other day I was out riding and noticed that when coming to a stop it would die when I pulled in the clutch. It was only when stopping, never when just changing gears.
After a little searching I'm thinking maybe an IAC issue, but I'm not certain. I don't have any other problems, and it doesn't happen every time. When it does happen it just completely dies, no stumbling or anything. It just quits and some of the dash lights come on, but not the engine light, and it starts right back up after it dies. Otherwise I have no problems, no surging or rough idle or anything.
I also had read in the past about issues with the sidestand switch. On the way home I put the side stand down enough to trigger it, and it dies in the same manner, with the same dash lights. It seems that when the sidestand switch is bad, or not properly adjusted on these bikes then there are problems with being able to start the bike. I have no problems starting the bike.
So any other ideas of things to check?
Mr. 0 is offline   Reply With Quote
Old 08-31-2011, 07:08 PM   #39348
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,245
Originally Posted by MeefZah View Post
We are looking to move to the area soon; probably rural around Newcomerstown / W Lafayette / Port Washington. A lot hinges on where and when Meredith finds a job... obviously if an Akron Hospital picks her up we might be well north of that, even.
I just dropped the house price $11,000 trying to get it sold; I'm giving it two months and then it goes up for rent and we will rent a small house in the target area.
Nice areas. You'll find east of 77 to be more trailer parkish, west to be more Amish. I'd be able to pedal to your house in any of those 3 towns and only climb one hill. Port Washington Road leaves town and goes pretty much straight to Millersburg and is 50% gravel, also the 1st state road in Ohio.
Rt 36 is so flat, I'm not sure how water flows off of it except the crown.
Lots of good riding in and around that area. Uhrichsville is between Crow, Beans and Lightning raceway so you'll always have a place to watch a race or play ride.
Navarre & Bolivar would be about 1/2 way between Akron and Uhrichsville, Both nice small towns, any farther north and your getting too close to the NTZ.
Go too far east and you start getting into the Swingset Ohio geography dispute area, aka, little Appalachia.
Have Meredith check with Infinity Hospital in Massillon also. They have plenty of my records there but I doubt that kind of name dropping would help!
Our neighbor just took a $10k loss on his house just to get into the next township for the school. His kid won't even start school for another year or two, just impatient.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 08-31-2011, 07:10 PM   #39349
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,870
Have you tried bypassing the clutch safety switch just to eliminate it as a possibility? It doesn't sound like that's the culprit but it's the obvious first link in a clutch/in stalling issue.
swingset is offline   Reply With Quote
Old 08-31-2011, 07:15 PM   #39350
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,245
Try turning the idle up even just 100 rpm. My 950 would do the same thing and after some searching found it to be a common issue if the idle wasn't set to factory specs. I thought the spec seemed a bit high but I turned the screw just enough to bump the idle and no more stalling.
Michael
Old 08-31-2011, 09:15 PM   #39351
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,870
That's a good thought too, the Strom will stall if you have the idle too low, even by a little.
Old 09-01-2011, 05:03 AM   #39352
Rich B
Rich B's Avatar
Oddometer: 777
Thumb
MeefZah,
Newcomerstown, Port Washington, etc, you are getting into my 'hood.... CR10 out of Gnadenhutten is awesome, as is SR 258 from Newcomerstown to Stillwater....
SR416 between Gnadenhutten and Tuscarawas can be fun too
Lots of other secondary and gravel roads in the area as well....you can spend hours exploring.
Rich B is offline   Reply With Quote
Old 09-01-2011, 05:24 AM   #39353
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,743
That's probably a good 50% of why he's moving up there. "New" roads.
z@ch is offline   Reply With Quote
Old 09-01-2011, 06:17 AM   #39354
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,963
Hey flashover, here's an interesting look at the durability of a 525 on a RTW trip...
http://www.advrider.com/forums/showthread.php?t=712492
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 09-01-2011, 06:37 AM   #39355
rob748
resident alien !!!!
rob748's Avatar
Oddometer: 825
front
Originally Posted by flashover604 View Post
I know it's a little less svelte than my 525, but I should be able to hoist the front tire off the ground. I've seen rob do it, so I know it's possible! We'll have to get a group together sometime. If we pick the right day, meefzah can probably grace Todds Mountain View again...
you can wheel the thing but it takes a little work, the FCR is the key, it makes a huge difference when you get on the throttle. it carries alot weight in the front so its never going to be a wheelie monster
switching the cog for the woods is good if you are running single track
once you get it down it is easy
rob748 is offline   Reply With Quote
Old 09-01-2011, 06:38 AM   #39356
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 822
Tenere at MidOhio
I was at MidOhio in Mt Vernon last night and they have a Tenere sitting on the floor waiting for somebody to take it home. It was marked $13,900 as I recall.
Mike
2001 KLR 650
2003 V-Strom DL1000
mpenner is offline   Reply With Quote
Old 09-01-2011, 07:00 AM   #39357
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,725
I'd rather have to order mine and wait 10 months for it to be delivered.
jimjim is offline   Reply With Quote
Old 09-01-2011, 07:06 AM   #39358
flashover604
tailgunner
flashover604's Avatar
Oddometer: 552
I just want to be able to get the front up a little to clear stuff... Puddles, logs, you know, the stuff that'll put you on the ground if half the bike isn't past it when a tire hits it. Hmmm. I was hoping to not get into carbs, but if that's what it'll take, I guess I'll have to look into that route. What donor bikes can I source the FCR? is it fairly straight forward to swap? I swapped the 17 tooth for a 16 last night. Two questions. First, the right side axle adjuster is pretty tight. I was able to back it out a turn or two, but it was SQUEEKY TIGHT. I didnt want to force it any more. Any tricks to getting all the way out to antiseize it? I'm thinking heat and some Deep Creep? Also, I picked up a new countershaft bolt and spring washer. As I torqued it to 44ft/lbs, it seemed to really crush the washer down. When I looked at the old bolt/washer, I noticed that the old one had a collar that holds the washer captive and would bottom out on the shaft, whereas the new one just centers on the bolt and the two pieces can be separated. Which one is correct?
"That which does not kill You, usually makes you wish it did......."
flashover604 is offline   Reply With Quote
Old 09-01-2011, 08:04 AM   #39359
dox
How much for the ape?
dox's Avatar
Oddometer: 2,649
dox is offline   Reply With Quote
Old 09-01-2011, 08:09 AM   #39360
EJV
Fuso FG Expedition
EJV's Avatar
Oddometer: 960
Whatever. I did not wait that long.
It was 9 months.
I think I am a Hipster now, I got a Mac.
EJV is offline   Reply With Quote
Times are GMT -7.   It's 01:55 AM.
