Go Back   ADVrider > Riding > Regional Forums > Central From Da Nort Woods to the Plane States
Old 04-27-2012, 12:19 PM   #47941
Rich B
Rich B's Avatar
Oddometer: 807
Eh?
buildit, that is ugly. May not be possible, but on some of my restoration projects with stuck swing arm pivot bolts....force becomes necessary
If you can get a hacksaw blade between the frame and swing arm, you can try cutting off the bolt flush with the swing arm. Then remove the swing arm and have the bolt pressed out of the swing arm.
If you can't get a blade in between the swing arm and frame, try cutting the bolt off flush with the outside of the frame. Then center punch and drill out until it is so thin you can break off what is remaining then remove the swing. arm. Then have the bolt pressed out.
Neither are easy. Both will result in use of words that will get you banned if you post them online But the swing arm will come off.
LIfe is too short to drink bad beer!
Rich B is offline   Reply With Quote
Old 04-27-2012, 12:53 PM   #47942
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,298
Weighing my options, right now it looks like "drill baby drill" will be the next step.
2013 Super-10, 2007 KTM950SEr, 2006 KLR650
buildit is offline   Reply With Quote
Old 04-27-2012, 12:57 PM   #47943
indypup
indypup's Avatar
Oddometer: 3,764
Ok, I've been up since 4am this morning. I had a boring 2 hours conf call with Europe this morning. I'm canceling on going to Meefville tonight. Too tired to drive almost 4 hrs. :( I think I'll might check out Perry tomorrow since it's relatively close to Zanesville and then do the ride on Sunday there.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 04-27-2012, 01:40 PM   #47944
blackdiamondmike
blackdiamondmike's Avatar
Oddometer: 191
Luke, unsolicited advice- Try calling smilingjohn and have him check the photos to see if he has any ideas before you start drilling. I suspect that is some pretty hard steel. -Mike
blackdiamondmike is offline   Reply With Quote
Old 04-27-2012, 02:21 PM   #47945
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,753
Originally Posted by motodirtlover View Post
Awww, C'mon guys, you don't have to be there until 9ish to sign up!
I could really use the riders as I am paying for all of this out of my pocket....Trying to get this new group off the ground...
Don't make me beg...
I was on the fence, but I'll be at the road enduro with 3-4 others. We northeasterners have to leave at 7AM, so the middle of the state crew shouldn't complain.
Is there by chance a GPS of the route available? I have another person who wants to go, but will not be able to get there until just before noon. If nothing else, if you could tell me, or PM me the lunch location, I can have him meet us there.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 04-27-2012, 02:35 PM   #47946
ohioroadrat
It`s YOUR fault !
ohioroadrat's Avatar
Oddometer: 1,749
Took a swing arm bolt ouy of one of Shawn`s bike that was frozen like that. Used JB Blaster for 3 days before it would break loss but it finally did. Give it at least 3 days of squirting the stuff about 8 times a day. Hit it from both sides (I know it won`t move on the one side but it will send different shock waves through it and when it does break loose you can knock it back and forth) GOOD LUCK !
The second slowest rider in district 11.
Time spent riding is not deducted from one`s lifespan.
ohioroadrat is offline   Reply With Quote
Old 04-27-2012, 02:43 PM   #47947
indypup
indypup's Avatar
Oddometer: 3,764
The PB 50 is scented! It smells like vanilla or coconut or something...your KLR will never forgive you. ;)
indypup screwed with this post 04-27-2012 at 02:51 PM
Old 04-27-2012, 02:44 PM   #47948
Mikef5000
Oddometer: 2,031
That's what I would do. Pb blaster it for days. Unless of course you are in a time crunch.
But drilling bolts, especially huge awkward bolts, has never worked well for me.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 04-27-2012, 03:03 PM   #47949
alansz400
alansz400's Avatar
Oddometer: 1,018
Maybe try a air hammer. I have had good luck with them. They dont seem like they are doing much but then the bolt will start to move.
alansz400 is offline   Reply With Quote
Old 04-27-2012, 03:11 PM   #47950
S2P
S2P's Avatar
Oddometer: 747
I'll second the drill as a last resort. Things rarely work out as planned. I had a similar encounter last fall with a football sled hinge, even with putting it in a bridgeport and drilling it out, it didn't come out centered. It didn't matter with the sled,it left more room for grease is what I told them, but it would be bad on the swingarm. Soak it and the air hammer or other similar shock for a few days is the better option.
"In wine there is Wisdom, in beer there is Freedom, in water there is Bacteria"...Benjamin Franklin
WR 426
TTR 125
S2P is offline   Reply With Quote
Old 04-27-2012, 03:26 PM   #47951
alansz400
alansz400's Avatar
Oddometer: 1,018
2012 Cabin Fever Road Enduro Ohio
Anyone else want to meet in Loudonville sunday morning and ride down with me? I am going to be on the WR.
Old 04-27-2012, 04:39 PM   #47952
buildit
buildit's Avatar
Oddometer: 14,298
I did call them last night before posting. There advice was basically bigger hammer.
So I driller the top off the bolt and about three inches into the bolt before a bit broke off and couldn't be extracted. The bolt is free of the outside frame on both sides as it will move in and out of each side. Not giving up yet but running out of ideas and energy.
Old 04-27-2012, 04:42 PM   #47953
buildit
buildit's Avatar
Oddometer: 14,298
I'll head out tomorrow and get some PB blaster as I'm out of the other penetrating spray I was using.
Old 04-27-2012, 04:45 PM   #47954
swingset
Got the knack.
swingset's Avatar
Oddometer: 11,056
If you have some ATF & Acetone, mix 'em 50/50....works as good if not better than anything you can buy. Hard on paint tho, so use carefully.
swingset is offline   Reply With Quote
Old 04-27-2012, 04:58 PM   #47955
buildit
buildit's Avatar
Oddometer: 14,298
Probably pretty hard on your lungs too. Wait, I'm a smoker. Should I care?
Times are GMT -7.   It's 07:50 PM.
