Go Back   ADVrider > Riding > Regional forums > Central – From Da Nort Woods to the Plane States
Old 09-21-2012, 05:19 AM   #52606
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 8,815
Originally Posted by GregsBro View Post
You got it neighbor.
Apparently it is the tires, not the milkshake, that brings the buildit to your yard.
Go forth, wander aimlessly, explore, have adventures and shit...
MeefZah is offline   Reply With Quote
Old 09-21-2012, 06:44 AM   #52607
buildit
Pumpkin Rider
buildit's Avatar
Oddometer: 13,207
He doth speakith in riddles I say.
Don't trust links? Google ADVFilmer for videos.
http://www.youtube.com/user/advfilmer
buildit is offline   Reply With Quote
Old 09-21-2012, 07:01 AM   #52608
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 2,209
Send a message via Yahoo to indypup
Maybe it was for her milkshake(s)...
If there's no video...it didn't happen
2007 ST1300, 2008 KLR650, 2008 WR250R, 1995 Ninja 250R
Only a dog knows why a motorcyclist hangs his head out the window! Be real, be whole, be innovative.
indypup is offline   Reply With Quote
Old 09-21-2012, 07:10 AM   #52609
GregsBro
a.k.a. Scott
GregsBro's Avatar
Oddometer: 358
Go here http://www.advrider.com/forums/showp...ostcount=12602
and read a page or two and that will explain it. I was confused too Mark had to explain it to the old man.
GregsBro is offline   Reply With Quote
Old 09-21-2012, 07:48 AM   #52610
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,253
Originally Posted by swingset View Post
And oh so affordable!
Guess if you have 570 money, what's an $800 gas tank?
Don't look at the 950 tanks then
Michael
mgorman is online now   Reply With Quote
Old 09-21-2012, 07:55 AM   #52611
buildit
Pumpkin Rider
buildit's Avatar
Oddometer: 13,207
I get get it. Dam kids and there pop culture references.
Old 09-21-2012, 07:56 AM   #52612
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,253
Originally Posted by Gonzo_Matt View Post
I'm not saying that the KTM is going to explode if you don't adjust the valves every 40 feet, but they don't have the 26k interval the WRR does. I've read the stories about the guys with 20k on RFS engines, but having to change the oil every ride would get to be a drag. My 450 RFS only holds 1.2 quarts, you can't tell me that little bit of oil can stay clean and retain it's lubricating qualities for more than 15 or so hours. Not to mention every other oil change comes with changing/cleaning 2 filters and dropping the skid plate.
Possibly because you have the SX model, mine has not only a wet sump but holds 2 more qts in the frame that has a spin on filter. (3 qt system) There is also a filter in the engine case I replaced with a stainless re-usable. Does your cover have external lines running to the head or cases anywhere?
btw, you should have room for more oil, you're missing a few parts in the transmission!
Michael
Old 09-21-2012, 07:59 AM   #52613
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,513
It's not all about oil capacity. WR250R only takes 1.4L
3,000 mile changes, 6,000 for the filter
z@ch is offline   Reply With Quote
Old 09-21-2012, 08:18 AM   #52614
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 1,210
It certainly helps though. Runs cooler and has all those nifty particles that bond to debris.
Danjal is online now   Reply With Quote
Old 09-21-2012, 08:58 AM   #52615
z@ch
z@ch's Avatar
Oddometer: 4,513
What I meant was that people are suggesting that race bikes were worse than dualsports because of reduced oil capacity and that's just not the case.
The higher-spec motors tend to have a shorter oil change interval, but those numbers are often based on the bikes being raced. Listen to Gorman, he's had everything from air cooled trail bikes to high-spec euros and knows what he's talking about.
I will say that the higher performance dualsports are more likely to break down in the long-term, their parts are often built for power or lightness and they're just not as durable.
Everything is a trade off.
Old 09-21-2012, 10:19 AM   #52616
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,661
Compression, oil path, filtration style and efficiency, and yes how and where its ridden all plays into how the oil is going to last. Temperature and contaminates kill oil, so how a bike treats its oil and how hot that oil gets determines quite a bit. Some of it you control, some of it you don't.
But, all things being equal the more oil you got the longer it's gonna last before breaking down.
If I was easy on my 1.2 liter TTR's oil, it would last 2,000 miles. If I did a 100 mile dual sport in the dust, it was shot.
The Rant-Fu blog & podcast ->Rant-Fu
swingset is offline   Reply With Quote
Old 09-21-2012, 10:58 AM   #52617
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,253
Dust? Why is dust affecting your oil? Your breather should either be breathing between your air filter and cylinder or have a filter on the end or at least some foam in the tubing.
If you want to complain about oil capacity, the CRF450 holds less than a qt of oil in the crank and less than one in the transmission (separated).
Michael
Old 09-21-2012, 11:16 AM   #52618
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 9,333
What kind of oil do you use?
Whitey1 is offline   Reply With Quote
Old 09-21-2012, 11:18 AM   #52619
dox
How much for the ape?
dox's Avatar
Oddometer: 2,599
What kind of oil should I use?
dox is offline   Reply With Quote
Old 09-21-2012, 11:34 AM   #52620
Mikef5000
Oddometer: 1,668
2012 XT1200Z (Totaled - Ride/Crash Report)
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Times are GMT -7.   It's 05:12 AM.
