Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 09-28-2012, 11:36 AM   #52906
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 819
Originally Posted by MeefZah View Post
What would be the next step up that has a micro SD slot?
The 60CSx has the microSD slot. For the 60C, the S means that it has a barometric altimeter and a magnetic compass and the x means that it has the micoSD slot. The 60CSx is a nice GPS that has a lot of functions like a Swiss Army knife, but I find the screen and buttons a bit small for the bike. I usually take one as a backup on a long trip.
Mike
2001 KLR 650
2003 V-Strom DL1000
mpenner is offline   Reply With Quote
Old 09-28-2012, 12:01 PM   #52907
Mikef5000
Oddometer: 2,030
I have the Nuvi 550 and use it extensively. It works well for setting up basic routes and getting you from point A to point B (with a few via points), but it doesn't like importing tracks. I wouldn't recommend it for that type of riding, it's more useful for touring, or for after you've got yourself sufficiently lost, and it's time to get back to gas/home. I've used it with long detailed routes (like the TWVT), but I have to set it up as a custom route manually, which means adding point by point into a custom route (on the GPS), which is inconvenient and takes forever.
I took the S10 out yesterday to pass it's big 1-5.
Took a ferry ride (the Augusta ferry this week, hit the Fly/Sistersville ferry last week)
Eventually got there!
In 6 and a half months no less! I put less than 500 miles on my car in the same time.
Got home to find this:
Bummer! Fixed though:
I changed the air filter too, it wasn't near as bad as I anticipated:
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 09-28-2012, 12:04 PM   #52908
dox
How much for the ape?
dox's Avatar
Oddometer: 2,649
I'm reluctant to upgrade to the newer stuff due to the lack of rugged power connection. The new Mini USB stuff just doesn't seem that durable compared to the old round garmin power port.
What was special about the garmin hardwire cord you got for your Nuvi 500 that keeps it from disconnecting, etc?
dox is offline   Reply With Quote
Old 09-28-2012, 12:16 PM   #52909
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,725
How big of a job is it to change the air filter on the tay-nay-ray?
jimjim is offline   Reply With Quote
Old 09-28-2012, 12:20 PM   #52910
EJV
Fuso FG Expedition
EJV's Avatar
Oddometer: 960
Piece of cake.
Remove / tilt fuel tank.
A few screws and the airbox opens right up.
EJ
I think I am a Hipster now, I got a Mac.
EJV is offline   Reply With Quote
Old 09-28-2012, 12:23 PM   #52911
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by EJV View Post
Piece of cake.
EJ
That sounds like what I have to do on ST13 and it's not a piece of cake. At least not the kind I like.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 09-28-2012, 12:25 PM   #52912
EJV
Fuso FG Expedition
EJV's Avatar
Oddometer: 960
Well, what is the definition of cake? I didn't say fast.
I replaced the plugs at the same time, so it was all apart already.
EJ
Old 09-28-2012, 12:26 PM   #52913
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,224
I have the Zumo 660. It's weatherproof and the RAM mount allows me to move it between bikes. It won't do topo maps, so I'm not sure how it'll work offroad. I also have a Garmin eTrex for backpacking and geocaching.
Spyder
and WRR
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 09-28-2012, 12:43 PM   #52914
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by ArmyJoe View Post
I have the Zumo 660...
I have the 665 and it's held up pretty good using it off-road on my WRR so far. I flipped over the handlebars during the Athens D/S ride and now have a bruise the size of the GPS on my stomach and it didn't come off the mount.
indypup screwed with this post 09-28-2012 at 01:08 PM
Old 09-28-2012, 01:19 PM   #52915
indypup
indypup's Avatar
Oddometer: 3,764
Nut Cracker 200 Dual Sport Ride Part 1
Old 09-28-2012, 01:24 PM   #52916
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 819
That is true about the 550 importing tracks. Strangely, I can download tracks into it using Mapsource, but I can not get them to display.
IIRC Basecamp will convert a track into a route very easily. That is what I did when I rode some of the TWVT this Spring.
Mike
2001 KLR 650
2003 V-Strom DL1000
Old 09-28-2012, 01:36 PM   #52917
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 819
There are 3 things that make it better. First there is no cig lighter adapter to shake loose (which seemed to be a big part of the problem). Second, the USB connector is just higher quality. Third, the USB connector is right angle so less torque is transmitted into the connection on each bump.
I put the kit on before I went to AK and I don't recall ever having a problem, where before it drove me nuts.
That being said the old round 4 pin power connector was better and the units that used it would take 12V directly rather than 5V like the Nuvis
Mike
2001 KLR 650
2003 V-Strom DL1000
Old 09-28-2012, 02:05 PM   #52918
Mikef5000
Oddometer: 2,030
Nothing, and I've killed one Nuvi because of this weak link. Surprisingly though, with this second Nuvi, I've killed 3 power cables, but not the power port on the GPS yet. I also don't like it, but I've made do. It's nice that, if I do kill a cable, like In Alaska just south of Denali National Park for example, most gas stations have a mini-USB car adapter. I've never had the cable 'fall out' though.
Nothing really difficult about it, but it's more time consuming than I think it should be. That's most likely due to the fact that I'm used to Buells (4 screws and 4 snaps) and the WRR (2 screws and 1 snap).
You've got to pop off the side covers and seat: 4 quick turn fasteners, then 6 non-quick-turn fasteners
Unbolt the tank: 2 allen bolts
Tilt the tank up, then hold it somehow: I used a ratchet strap to the luggage rack
Then about a dozen screws hold the air box lid down, some harder to get to than others.
So what's that, about 24 different bolts/screws? Jeesh. Seems like an awful lot to me, but like I said, not difficult, so I'm just bitching to bitch. I haven't heard a single person report the spark plugs looked anything but fine when they replaced them, so I'm putting it off till I do the valve job and am already in there.
EJV (and S10 friends) have any of you done the air screw adjustment and throttle body sync? Mine isn't running as smooth as it did before, and I'm thinking about trying that. Nothing wrong with mine really, but it's supposed to be an improvement, and it's about free, so why not.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 09-28-2012, 02:09 PM   #52919
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,283
Make sure the color is turned on. I know when I first started messing with the GPS60c it would default to no color, making the tracks invisible.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 09-28-2012, 02:20 PM   #52920
indypup
indypup's Avatar
Oddometer: 3,764
Anyone want to ride dirt Saturday? Maybe Tar Hollow stuff? KLR friendly or not...
Times are GMT -7.   It's 09:27 PM.
