Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 10-31-2012, 04:52 PM   #54001
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,137
Originally Posted by MeefZah View Post
I'm not sure "more power" really is accurate, but I'll be damned if I can come up with a better descriptor. It's smoother starting out in 1-2, for sure.
If I'm holding the throttle steady in 3rd gear, and I flip the switch to "on" (simulating pulling in the clutch), there is a noticeable surge of power.
I use the switch so that around town I can have smoother starts from stopped positions, and on the road I can shut it off and save a bit of gas.
Cool, thanks for the detail. I had heard talk of gears 1-3 having the ignition retarded to save wear and tear on the drivetrain. Or something like that and wondered if it was in fact noticeable.
Originally Posted by MeefZah;19941874
I may take you up on that soon, once we get in the[I
butt fuck of winter[/I] I could probably run straight south until warm, and then straight west.
Things sure are different in your town. We just have to deal with salty roads and potholes.
Whitey1 is offline   Reply With Quote
Old 10-31-2012, 05:09 PM   #54002
sjsred323i
Oddometer: 242
I'd like to find a super low shield to eliminate the buffeting but there's nothing currently out there
You may want to consider taking the screen to a glass shop and have it cut down. I did that at Advance Auto Glass (N Canton) with my ZG sport touring screen for my Bandit. I think that the cut it down for $20 and did a great job.
"If you have to worry about the risk, you're dead already." Paul Newman
sjsred323i is offline   Reply With Quote
Old 10-31-2012, 05:23 PM   #54003
BOB RAMSAY
Not in the Clique -
BOB RAMSAY's Avatar
Oddometer: 347
Originally Posted by Rich B View Post
Danjal sez:
"I don't know what most of you folks do for a living for that matter"
I won't bore you with my occupation...I have tried explaining to some face to face and they still aren't clear what I do....so trying to do it with my usual short smart ass online answer won't work at all...
Lets put it this way....it requires a passport and patience
So you work for the CIA. I need a favor. . .
I'll take Heaven for the climate - Hell for the company.
BOB RAMSAY is online now   Reply With Quote
Old 10-31-2012, 05:27 PM   #54004
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,348
Originally Posted by mgorman View Post
Send me the dimensions, I have 3 rear springs in my garage, you are welcome to try one if it is close. If you go to some of the spring companies and or sites like Race Tech suspension will have charts with the stock spring rates and what's available. I think 2 of the springs I have are labeled with the rate and one is an XR spring which uses oddball Honda rates and is pretty much 2 or 3 times what anyone else uses. I also have some fronts but may be too big around.
Thx! Email sent.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 10-31-2012, 05:39 PM   #54005
'Flagger
'Flagger's Avatar
Oddometer: 2,348
Originally Posted by OhioPT View Post
Yeppers, you might get lucky and find a spring that fits. Otherwise, you will need to make some spacers or coller adapters. What's the inner diameter and length? Any idea what the stock spring rate is? I might be able to help find one for you.
Sasquatch and Cogent Dynamics (both inmates here) should be able to revalve it for you, if you don't mind sending it out. They can probably source a spring as well.
I need to read closer ... missed your offer to help find a spring.
Spring Dimensions:
Spring free length: 9 13/16"
Spring O.D.: 3"
Spring I.D.: 2"
Wire diameter: 0.475" (didn't scrape the paint off, however, so this is a little high)
Spoke to a couple of shops today, including Cogent. 1st call was to Bruce's Suspension. He does revalves on the sealed CRF230F shock .. was hoping he would be willing to take a look at this one. Turns out he's going through some medical stuff and isn't taking any work until December at the earliest. 2nd call was to Cogent. Spoke to Rick ... great guy. Spent a 1/2 hour talking options/cost for a custom build. Tempting.
Will make some more calls tomorrow.
- B
Old 10-31-2012, 05:53 PM   #54006
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,737
I may take you up on that soon, once we get in the butt fuck of winter I could probably run straight south and then straight west.
Yeah, I'm not gonna miss the grey...
z@ch is offline   Reply With Quote
Old 10-31-2012, 06:29 PM   #54007
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,736
Spring Dimensions:
Spring O.D.: 3"
Spring I.D.: 2"
Remind me Sunday,that sounds close to a dr650 spring. I've got a stock spring that you could have if you could use it. Otherwise I'll hand it off to someone else here that could use a full stock set.
Danjal is offline   Reply With Quote
Old 10-31-2012, 06:42 PM   #54008
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,836
Hey thanks!
They get the "taper" on the edge correct, so it looks factory, and doesn't look like some mook with a hacksaw went to town on it? I'm not that concerned with aesthetics, but I can do a shitty job all by myself.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 10-31-2012, 06:50 PM   #54009
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,419
Originally Posted by Whitey1 View Post
Meef,
I understand what you are saying. I miss the klr daily. She was like one of the kids and took me a lot of places.
I'd be happy to sell it back to you. $4500 and she's yours
Gonzo_Matt is offline   Reply With Quote
Old 10-31-2012, 06:53 PM   #54010
'Flagger
'Flagger's Avatar
Oddometer: 2,348
Hey thanks!
I cut down a windscreen on my Honda Shadow back in the day. Sanding the edge with finer and finer grit sandpaper produced a pretty nice edge. Used a jig saw with the speed set real low to keep the heat down ... if it gets hot, you'll melt the plastic causing some issues.
- B
Old 10-31-2012, 06:54 PM   #54011
'Flagger
'Flagger's Avatar
Oddometer: 2,348
"Remind me Sunday"? We going to church?
- B
Old 10-31-2012, 07:06 PM   #54012
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,137
tempting.....
Old 10-31-2012, 07:08 PM   #54013
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,137
That looks awesome. Have you done much riding down there yet?
Old 10-31-2012, 07:08 PM   #54014
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,808
I did the same on my Vee's OEM shield, making a low shield out of it. I was never 100% satisfied with the lip, so I split some black tubing and put it on the edge and it looked pro-fessional.
The Rant-Fu blog & podcast ->Rant-Fu
swingset is offline   Reply With Quote
Old 10-31-2012, 07:09 PM   #54015
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,137
Speaking of ordained ministers where is Swingset at??
Edit...as if on cue.
Times are GMT -7.   It's 12:41 PM.
