Go Back   ADVrider > Riding > Regional forums > Central – From Da Nort Woods to the Plane States
Old 11-05-2012, 08:37 PM   #54121
Benly
Benly's Avatar
Oddometer: 215
Well I managed to pick up the WRR and ride it home this evening. It was fairly cold ride home so the first modification I made to it after pulling off most of the decals was to install a hookup for my heated vest.
Not counting my vintage bikes which are a whole other riding experience entirely this is the first small bore bike I've had since my XL250 which I bought new in 1986. 8 miles home is not much of a test ride, but I can already tell I'm going to have a lot of fun on this bike. I figure it is a good 90 pounds lighter than my KLR with the same amount of fuel on board. Might not make me a better rider, but it should be a lot easier picking it up when I fall over.
Benly is offline   Reply With Quote
Old 11-05-2012, 09:05 PM   #54122
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Originally Posted by RallycarJon View Post
It's delicious kool-aid though. If I find one for the right price I plan on unloading my KLX250 for one.
That much better than the klx250?
Danjal is offline   Reply With Quote
Old 11-05-2012, 09:11 PM   #54123
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,818
If you put it on the trails, it will absolutely make you a better rider.
swingset is offline   Reply With Quote
Old 11-05-2012, 10:01 PM   #54124
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Or blue can still trump orange...
But, why would anyone limit themselves to poorer equipment unless there's an underlying reason? Your skills can only improve as far as your equipment allows most times. Far too many times I've ran into this.
Old 11-06-2012, 03:20 AM   #54125
ruppster
ruppster's Avatar
Oddometer: 882
Originally Posted by swingset View Post
Or mebbe something in between?
WR450
Slap a plate on, bulletproof motor, EFI, a little lighter than the WRR and lots more balls.
That's what everyone is waiting for. Retail would be $9k-9500 as a guess, local dealer & I discussed this before I picked up a used 250.
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 11-06-2012, 03:25 AM   #54126
ruppster
ruppster's Avatar
Oddometer: 882
... I figure it is a good 90 pounds lighter than my KLR with the same amount of fuel on board. Might not make me a better rider, but it should be a lot easier picking it up when I fall over.
I guessed 100-125 lighter than my KLR650. Its much more nimble too.
A guy has to figure out what he wants a bike to do, that's what I found was the hardest part.
BTW the WRR & I picked this up on Sunday, but I still don't exactly understand the points system.
Old 11-06-2012, 06:27 AM   #54127
MrFurious
MrFurious's Avatar
Oddometer: 704
I really don't see the huge advantage of the WRR over the KLX250S, especially when you can get the 351 kit and larger carb for it and still be well under the price of the WRR. Yes you loose the fuel-injection, but in my book that's a good thing as I can fix most any carb problem on the trail. You can also still add an OEM kick-starter kit for the KLX for $300 - something you can't do with the WRR.
I dunno... Yeah, you'll be changing more oil and checking valves...but I'd bet the pee-pee tingle you get when you're on the dirt just might make it worth it. 26lbs lighter, and double the HP to the ground and way better brakes and sproingers. Of course, you'll be writing a lot bigger check.
Hard to argue against the KTM unless you start talking about the cost or maintenance. The 350 and 500 EXC-F's are essentially the Ferrari of the D/S world. They have all the fancy bells and whistles and are faster than a Skyline Chili induced bowel evacuation, but it all comes at the expense of affordability and bulletproof reliability.
Seems the street-legal version of a WR450F has been available in other markets (Europe and Australia) for quite awhile so it's not as much of a long shot as some might think. Whether it shares the same race-bred WRF engine or has a more maintenance friendly and less powerful engine like the WR250R is the question.
Jim B.
MrFurious is offline   Reply With Quote
Old 11-06-2012, 06:32 AM   #54128
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,371
I'm pretty sure that is not going to happen. I wish it would, but it is not going to. Lots of politics involved with corporate air quality issues. Yamaha had to kill several 2 stoke outboards to keep the 2 stroke MX bikes. Even more difficult for stuff with a plate.
Much easier when you bring in a small amount of units, such as ....KTM, Husqvarna, Beta, Husaberg, TM.............the rules only apply to people bringing in a bunch of units.
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 11-06-2012, 06:49 AM   #54129
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,738
Like it's hard to make a wr450 street legal in Ohio...
z@ch is offline   Reply With Quote
Old 11-06-2012, 06:57 AM   #54130
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,818
The one I pictured is the WR450F, which is already available...obviously not street legal from the factory but that matters little in Ohio.
Frankly, I'd choose it over the WR450R, if it should ever be a choice. The F will be lighter, better sprung for offroad, and retain the kicker option.
It's all what you're into I guess, but my bias is more towards offroad and less towards road. I'll give up some street comfort for trail manners.
FWIW, the Yamaha place out in Hebron has a new leftover 2012 WR450F right now for $6499, that's a lot of bike for the $$.
Old 11-06-2012, 07:00 AM   #54131
Mikef5000
Oddometer: 2,030
It's easy to make a wr450f street legal, but I want a wr450R; with a subframe, high output alternator, and extended maintenance intervals.
Heck, a wr250r has many internals from an R1; I wouldn't mind one bit if they made a 'wr450r' with simply a parallel twin of the same idea. Tune it for low/mid range power, and let it rip!
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 11-06-2012, 07:29 AM   #54132
Benly
Benly's Avatar
Oddometer: 215
My real problem has been finding the time to ride off road. At least now when I have the time it should be more enjoyable.
Old 11-06-2012, 07:36 AM   #54133
Benly
Benly's Avatar
Oddometer: 215
I still remember getting my XL250 after my IT175 and thinking it was sooo much heavier. I don’t recall how much the XL weighed, but I’m sure it was at least 10-20 lbs lighter than the WRR.
Old 11-06-2012, 07:40 AM   #54134
dox
How much for the ape?
dox's Avatar
Oddometer: 2,649
The cost/maintenance beliefs were what has kept me from owning a KTM for quite a while, but after a lot of research, the newer XC4 engines have proven to be extremely reliable and the valves rarely move.
The newest of the new is always going to be high, but NOS 450 and 530s can be found for 7 grand or less. Street legal out of the gate and a lot of bang for the buck considering MSRP of a WR250R is now at $6,690.
Sure, you'll change the oil a little more often, but it's a five minute job. Trans and filter every other oil change. Valves rarely (if ever) move. Fifty pounds lighter, gobs of power, both kickstart and magic button.
The FI vs. Carb debate notwithstanding, the only real compromise is fuel economy.
dox is offline   Reply With Quote
Old 11-06-2012, 08:52 AM   #54135
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,818
Stator output and subframe, too. They aren't important to me personally I don't use my little DS bikes for anything but trails and day trips and I don't ever intend on powering heated gear off 'em, but for someone wanting an "all arounder" that is a tangible downside to a race-bred KTM.
Times are GMT -7.   It's 01:38 AM.
