11-13-2012, 06:36 PM
#54391 | |
U-Boat Rider
Oddometer: 1,490
The CDI is tough to check. Usually you just try a know good CDI. The coil is easy with a multimeter. Check the resistance across the two terminals, and again from the terminal to the spark plug wire. They should be less than 1 ohm. Zero ohms is bad as well. Any large, or infinite resistance reading means bad coil. Same thing for the stator. Any large values are bad, as well as 0. You can probably google to get the exact spec to compare to. As long as the resistance values are small, I'd suspect the CDI then. They did try a new plug didn't they? EDIT: My google fu is week. I couldn't find the specs.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost. ScienceOfDirt screwed with this post 11-13-2012 at 06:41 PM |
11-13-2012, 07:20 PM
#54392 |
"Whitebread"
Oddometer: 9,332
11-14-2012, 04:15 AM
#54393 | |
Oddometer: 310
![]() I have the tools still if someone needs to borrow them. I also rewired part of the bike and installed ato weatherproof fuseholders for the circuits on my KLR. I put a couple under the kickstand switch cover and one near the radiator fan. I hate electrical gremlins. The fuseholders came from eBay, they look like this:
08 WR250R, 05 450EXC |
11-14-2012, 04:26 AM
#54394 | |
Random Hero
Oddometer: 1,633
Never turn your back on Fear. It should always be in front of you, like a thing that might have to be killed. |
11-14-2012, 05:43 AM
#54395 |
Insert wit here.
Oddometer: 1,203
I take it thats the infamous KLR doohickey everyone has problems with?
11-14-2012, 06:02 AM
#54396 | |
Zwei Kolben
Oddometer: 4,954
It was supposed to be a beer, doohickey, shooting day, but life got in the way & he just took it to his house and did it himself. Mine was cracked, but intact. Back together with a fresh valve adjustment and this 22 year old bike sounds as quiet as new. http://eagle-m-e.com/ I guess you can use OE parts, but he likes them from this guy so that is what he used.
This is SPARTA! |
11-14-2012, 06:28 AM
#54397 |
"Whitebread"
Oddometer: 9,332
Mine may have lasted so long because I was always very gentle with it. I only drove mine to church on Sundays and Starbucks on Thursdays.
Actually I only ever worried about the spring coming loose. The lever should be fine as long as it is carefully adjusted and not he-man tightened up. If you pull the side cover when you adjust it you can see the condition of it. I just did it this spring @ 11k when I adjusted the valves also. Since the stock spring sucks, I used a screwdriver to help add some tension against the lever while I tightened the bolt down . All looked well.
11-14-2012, 07:38 AM
#54398 | |
Blue Clutch.
Oddometer: 892
Me too! ![]()
The German scholars have improved Greek so much. |
11-14-2012, 09:26 AM
#54399 |
"Whitebread"
Oddometer: 9,332
11-14-2012, 10:14 AM
#54400 |
Lost Boy
Oddometer: 2,972
If y'all could please help me spread the word on this it would be greatly appreciated:
OMTA would like to announce we are launching a pilot program for providing low interest loans to private riding facilities! As more private riding parks are working to make more riding opportunities available for the riders, OMTA wants to help. We are seeking a candidate to be the first trial run of this new program. If you own, or know of, a facility that could benefit from a little boost we want to hear from you. Candidates may be recreational trail facilities, or tracks. We will consider both new start up operations; or existing, operating facilities seeking to expand and take the next step. Terms, rates, and conditions will be negotiated based on the merits and scope of each project. We are calling this a "low interest" program because the intent is to help finance projects that traditional lenders would likely charge higher rates for, or shy away from completely. The goal is to help a private facility become a more appealing destination, provide better recreation, and ultimately benefit both the property owner and the riders. For more information and discuss a specific opportunity, please email us at OMTARide@gmail.com. Include you name, phone number, mailing address and location of property, as well as a brief description of the facility and your project needs. Since this is ADV, you could also shoot me a PM, or call me.
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. muddyrabbit screwed with this post 11-14-2012 at 11:12 AM |
11-14-2012, 11:03 AM
#54401 | |
"Whitebread"
Oddometer: 9,332
11-14-2012, 11:21 AM
#54402 | |
Curmudgeonly
Oddometer: 8,812
Yet another reason the KLR is a gigantic lump of shit. BTW, my doo was intact but my spring was broken with 1300 miles. And if you are gonna change the doo you really need to replace it with the upgraded Eagle Mikes version, I mean the labor is the same, so why install an inferior part (that I think actually costs more)? If you haven't already nosed around on KLR forums and the like, I'd also suggest the following cheap mods: subframe bolt upgrade, footpegs welded on, waterproof wheel bearings. All three of thsee things broke / failed on my 2006 in under 20,000 miles; so I'm not just reguritating internet drivel. You ever ride home with no left footpeg? It's awkward.
Go forth, wander aimlessly, explore, have adventures and shit... |
11-14-2012, 11:24 AM
#54403 |
Lost Boy
Oddometer: 2,972
There, I made it bright ass safety yellow JUST FOR YOU!
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. |
11-14-2012, 12:32 PM
#54404 |
Oddometer: 306
Meef sez:
"You ever ride home with no left footpeg? It's awkward" I used to ice race with no left foot peg at all....does that count ![]() It wasn't awkward....damn thing drug on the on ice and caused traction issues
There is a good chance you don't like me. There is a better chance, I don't care! |
11-14-2012, 01:25 PM
#54405 | |
Oddometer: 973
'95+'95+'96 BMW R1100RS/RSL '99 Husky WR250 '98 Honda XR 70 AMA, OMTA (ohio organization), BRC, BMWMOA |
