Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 05-23-2013, 05:38 AM   #59626
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by sion View Post
107K on the cables? or the bike?
107K on bike. Only about 47K on these cables. I think I replaced them at about 60K last time.
Originally Posted by ohioroadrat View Post
When you replace it make sure that it does not rest in the slot of the adjuster,that will cause it to fra like that.
Hmm, I'm not sure what you mean but I have service manual and will take a look at procedure again and make sure I'm doing it right. ;)
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 05-23-2013, 07:16 AM   #59627
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Originally Posted by Gonzo_Matt View Post
Anyone have any experience with that plasti-dip stuff they are doing to make new cars look old these days? It think it's kinda dumb on a car, but I was considering doing my Versys with it, mostly because the paint is absolutely flawless now and I'd like to kinda protect it from getting too scuffed up, plus the maroon just isn't my thing.
I've played with it some Matt. It's very easy to prep for, but the coating itself is so so. Avoid heat and high wear areas with it
It'll melt and char,or crack,peel,and rub off. If you don't mind rea
pplying it then no biggie. Also,you better like matte paint jobs.
As far as chemicals in it wrecking existing paint jobs..don't know that either. I've used it on bare metal. It's like a cheap half-assed powder coat IMO. It'll hold up,but not in an offroad setting from what I saw. Now all that said they could've came out with stronger versions of it since I used it years ago.
I'll check when I get home,but I might have some left. I have some Duracoat if you want to try that too and you have an airbrush or hvlp.
Two of the best coatings I've found for hard surfaces are a good epoxy or spray on bedliner. Duracoat would probably be top for flexible plastic bits for things like bike plastics.
Danjal screwed with this post 05-23-2013 at 07:28 AM
Danjal is offline   Reply With Quote
Old 05-23-2013, 09:18 AM   #59628
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,477
Actually, the newer plastidip comes in gloss and even pearls. It is supposed to just go over the exiting paint after you clean it and apply a bonding agent, then when you are tired of it, it peels right back off.
Not gonna try bedliner or the like, because it fades, is heavy, and you can't remove it.
Gonzo_Matt is offline   Reply With Quote
Old 05-23-2013, 09:46 AM   #59629
indypup
indypup's Avatar
Oddometer: 3,764
Me at the Hanging Rock 200
Old 05-23-2013, 10:15 AM   #59630
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
They must've really changed it recently. When I used it surface prep was clean with alcohol then apply. No bonding agent was involved. I heard last they were working on a clearcoat. After my initial run with it,it didn't interest me much. If they made the coating stiffer that would definitely be beneficial to it in a whole host of forms. Before it was really rubbery,almost like soft tool handle coatings. If its upgraded to more of a plastic then I'd say try it.
Old 05-23-2013, 12:50 PM   #59631
Trapshooter
Monkeying Around
Trapshooter's Avatar
Location: Louisville, Ohio/South Carolina in the winter
Oddometer: 552
Matt, I have used plastidip with very good results, the new stuff stay glossy and sets up pretty hard, just like plastic. As far as just peeling off I can't tell you about that, but I have had it on things that were really abused and it held up quite well. You can thin it and spray it if you need to, I've always just brushed it on or dipped the piece into it, very strong and the gloss holds for years. I would highly recommend it. Comes in a lot of colors.
Dave
Trapshooter screwed with this post 05-23-2013 at 12:56 PM
Trapshooter is online now   Reply With Quote
Old 05-23-2013, 01:12 PM   #59632
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Do you still have any left? I had big plans for that stuff if it worked right.
Old 05-23-2013, 01:55 PM   #59633
Trapshooter
Monkeying Around
Oddometer: 552
Yea, I got about half a can left, if it didn't set up, it's black. I'll check it for you, you want me to start painting your DR with it?
Dave
Old 05-23-2013, 01:57 PM   #59634
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,944
My advice is to leave it the factory color.
I think it looks nice. It'll likely look like rape -like your KLR250 - if you start trying to modify the color on the cheap.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 05-23-2013, 02:07 PM   #59635
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,477
That's the whole point of the stuff, if you change your mind, the coating just peels off and you are left with an unmarred finish...https://www.dipyourcar.com/home.php.
I'm more concerned with keeping the factory paint in good condition and free from stone chips, scrapes etc.
ANd for the record, the first time I met you, you said my KLR looked , and I quote "Badass"
Old 05-23-2013, 02:13 PM   #59636
indypup
indypup's Avatar
Oddometer: 3,764
He was just being nice. He was nice to me too the first time we met.
Old 05-23-2013, 02:14 PM   #59637
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Dave
No, I was going to use it for plastic repairs and possibly mold casts. Problem is the stuff I used was more like rubber/latex mix. Didn't work for crap on much of anything.
If I had my way, the Dr would have blue carbon fiber plastics on it now.
Old 05-23-2013, 02:17 PM   #59638
Trapshooter
Monkeying Around
Oddometer: 552
Yea Matt, check this website out, pretty much tells you everything you need to know and also sells the spray cans.
Got a good video on doing wheels, and other stuff.
Dave
Old 05-23-2013, 02:19 PM   #59639
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,477
I really don't give a shit, the KLR was a stupid cheap bike, I disliked the dated graphics, so I spent $6 on Krylon fusion and changed it, spend 5 minutes cutting a stencil to Gonzo the tank, and it was done. I went with a flat color because I knew it was going to get beat.
On real world stuff, I can paint, quite well actually. My dad owned a body shop and was a custom painter for many years, and I shot my first car when I was 14. On a $1500 KLR in february, it's getting Krylon'd in an hour and we're callin 'er good.
Old 05-23-2013, 02:20 PM   #59640
Trapshooter
Monkeying Around
Oddometer: 552
Well try what I got and see if it works for you.
Dave
Times are GMT -7.   It's 12:46 PM.
