Go Back   ADVrider > Riding > Regional Forums > Central From Da Nort Woods to the Plane States
Old 10-16-2013, 07:13 PM   #62641
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 828
Originally Posted by FireDog45 View Post
One of the things I wanted to do to my newly acquired GS was to direct wire the power port under the seat to the battery. My intention is to use this port to power my gerbings jacket as well as an air compressor in addition to be an access point for a battery tender. I am planning on fusing this with a 15A fuse.
My questions are: is 15A enough and if so what gauge wire would you recommend? The distance to the battery is less than 12".
I should clarify: I know the 15A fuse is OK for the Gerbings but I'm not sure about what an air compressor would need.
Thanks!!
14 AWG is the normal recommended size for a 15A fuse, but if you have 16 on the shelf that will work just fine for a short run. I would not go any smaller than 16 however
Mike
2001 KLR 650
2003 V-Strom DL1000
mpenner is offline   Reply With Quote
Old 10-16-2013, 11:37 PM   #62642
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,070
It's only going to pull about 7.5+/- amps.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 10-17-2013, 02:58 AM   #62643
klxsqrl
klxSQUIRREL
klxsqrl's Avatar
Oddometer: 188
The weather man says sun Friday and I actually have it off!!! Been rainin' in Southern Ohio but that's what knobbies are for. Apologies in advance to the residence of Pike County... just passin' thru.
KLXsqrl
Hey, Where'd you guys go?
klxsqrl is offline   Reply With Quote
Old 10-17-2013, 05:55 AM   #62644
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,243
KLXsqrl
Go get the photo tag.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 10-17-2013, 09:15 AM   #62645
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,457
FD now that you're a Beemer rider you need to check on the amps needed to run the official Mottorad espresso machine too. I know you're fine with regular ol firehouse coffee now, but your tastes will change.
Have you practiced holding a fire axe with your pinky extended?
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 10-17-2013, 10:17 AM   #62646
rxcrider
rxcrider's Avatar
Oddometer: 1,373
He'll be fine as long as he stays away from the MOA forums. There can be a bit of going on over there. Actually, there are a lot of great riders over there - only a few are truly fancy. I do believe the fancy ones type their posts with their pinkies extended though.
'95+'95+'96 BMW R1100RS/RSL
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider is offline   Reply With Quote
Old 10-17-2013, 11:35 AM   #62647
sion
sigh-own
sion's Avatar
Oddometer: 3,654
Rubicon Trail on KTM 990s:
from this page:
http://www.advrider.com/forums/showt...913598&page=55
start of ride report:
http://www.advrider.com/forums/showthread.php?t=913598
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is offline   Reply With Quote
Old 10-17-2013, 01:25 PM   #62648
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 831
I figured I'd learn all this after I've been shown the secret handshake
I did get the power hooked up up to the side port and nothing burst into flames! I can now power my Gerbings as well as connect my trickle charger. Don't know about the espresso maker though...
FireDog45 is offline   Reply With Quote
Old 10-17-2013, 02:20 PM   #62649
blackdiamondmike
blackdiamondmike's Avatar
Oddometer: 191
Seeing the 990 adv in the video above got me wondering about the guy who used to post here frequently that crashed a tenere and bought a new 990 adventure. WHat happened to him and does he still like the ktm? -mike
blackdiamondmike is offline   Reply With Quote
Old 10-17-2013, 02:37 PM   #62650
sion
sigh-own
sion's Avatar
Oddometer: 3,654
mikeF5000...dunno why he doesnt post much anymore...too busy with his new job maybe...?
yo mike!!!....you still alive...?
by the way, anyone catch what the one guy in the video said when he saw the name on that weak-assed bash plate?
sion screwed with this post 10-17-2013 at 02:58 PM
Old 10-17-2013, 02:46 PM   #62651
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,427
Ran into Mike down at RiverJam (OSU Football Tailgate) a few weeks ago.
He acknowledged that he hasn't been on here much recently ... "Hobby A.D.D." he said.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 10-17-2013, 03:28 PM   #62652
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,767
If you need anymore circuits/power ports Eastern Beaver makes a great little fuse panel. http://www.easternbeaver.com/Main/Wi...3_circuit.html
jimjim is offline   Reply With Quote
Old 10-17-2013, 03:41 PM   #62653
sion
sigh-own
sion's Avatar
Oddometer: 3,654
hehehe...
he said "beaver"
hehehe
Old 10-17-2013, 03:51 PM   #62654
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,457
Do all KTM riders have a hammer that big in their tool kit?
Dang.
This is SPARTA!
Old 10-17-2013, 04:02 PM   #62655
sion
sigh-own
sion's Avatar
Oddometer: 3,654
Dang.
lol...they had borrowed it from a passing Jeep (also a quart of oil and some paper towels to clean the "wound" with)
Times are GMT -7.   It's 04:06 PM.
