Old 12-09-2012, 11:03 AM   #1561
Two Plugs OP
Two Plugs's Avatar
Oddometer: 1,389
Originally Posted by aikidimi View Post
... no unfortunately they are NOT the same!
2003-2006 models have different mounting for skid plate than newer models.
Not to mention... we also have the popular 1998-2000 MK1 and the 2001-2002 MK1 (both with carburettor) which are different too regarding the mountings...!
Bernard 'Two Plugs', NL
Honda XL1000V Varadero & VFR1200X Crosstourer Forum www.vci-forum.com
22-25 May 2015: 17th Varadero & 4rd Crosstourer International Meeting, Milau, France!
Two Plugs is offline   Reply With Quote
Old 01-01-2013, 05:38 PM   #1562
africa twin
Oddometer: 184
2013
First ride of 2013 Happy New Year to all Varadero riders
africa twin is offline   Reply With Quote
Old 01-02-2013, 06:33 PM   #1563
RickS
RickS's Avatar
Oddometer: 603
Dang I like those bikes. Wish we had them in the states
RickS is offline   Reply With Quote
Old 01-06-2013, 05:34 PM   #1564
VO1MX
VO1MX's Avatar
Oddometer: 227
Originally Posted by kojack View Post
Patrick, you are one crazy feller....goodwin said your an amazing rider....to see you take the vera through that....WOW....hopfully you get down here to newfoundland soon!...
Lot's of fun on the demo
Dan
VO1MX is offline   Reply With Quote
Old 01-07-2013, 12:50 PM   #1565
bruceca2002
Oddometer: 276
Front Suspension
I wanted to put some extra pre-load on the forks springs and was surprised the right side had a spacer about 1.5 inches long and the left side had nothing. Both forks springs were the same length. Is one side for damping and the other side for compression? Thanks for your help. Cheers, Bruce
bruceca2002 is offline   Reply With Quote
Old 01-14-2013, 06:05 PM   #1566
*AL-VARADERO*
Long Dist Adv/Tour
Oddometer: 38
Greetings my fellow Varadero riders. Photo taken in upper Manhattan, New York City, USA!
*AL-VARADERO* is offline   Reply With Quote
Old 01-14-2013, 07:25 PM   #1567
africa twin
Oddometer: 184
Looking good
Old 01-14-2013, 07:33 PM   #1568
africa twin
Oddometer: 184
Its normal for one side to have a spacer and the other not to, the forks are different internally. If you want to stiffen the front end you can add additional spacers or better yet install stiffer aftermarket springs. Another trick that I've seen used is to use an appropriately sized engine valve spring instead of a spacer. Valve springs are typically quite a bit stiffer than fork springs and so function similarly to a spacer but with a little more protection against coil bind in the fork spring by adding a little extra movement at full compression.
Old 01-21-2013, 02:05 PM   #1569
pedro portugal
Oddometer: 2
pedro from portugal
hello, im pedro from Portugal.
my motorcycle is an Honda Varadero 1000 .
pedro portugal is offline   Reply With Quote
Old 01-21-2013, 02:10 PM   #1570
pedro portugal
Oddometer: 2
Old 03-01-2013, 05:42 AM   #1571
Ghostbrother
Ghostbrother's Avatar
Oddometer: 106
RW Vardero SO
My new roadwarrior.
Honda Varadero XL 1000 SO (Super Offroad)
(This is a sketch)
During construction, is expected to be test-run 1/5 13
Marzocchi fork 45x270mm
Excel 19 "and 21"
Custom-built saddle.
New lightweight exhaust pipe and silencer.
estimated weight of the first phase around 200 kg empty.
Red / Silver.
etc.
"IP-Rider"
Is there life before death ... I believe that.... RW Offroad
Ghostbrother is offline   Reply With Quote
Old 03-02-2013, 12:11 AM   #1572
mousitsas
mousitsas's Avatar
Oddometer: 2,948
Very interesting project, but to be honest, I think your weight estimate is a bit optimistic.
However, I am so looking forward to see it!
mousitsas is online now   Reply With Quote
Old 03-02-2013, 04:41 AM   #1573
Ghostbrother
Oddometer: 106
Varadero 216.4 kg
Sorry I forgot to tell you that the original weight empty is 216.4 kg at my 2001 (if my scale function correctly, and it is 220 kg in the registration certificate, recent model with abs o 6 gears weighs around 260 kg) just to change exhaust, fork, brakes (from 2 big calipers with combination pump and valves, triple hoses, etc. etc.., to a small light ktm 950 see calipers) and wheels with double dics and heavy chain sprocket is probably more than 16 kg, so around 200 kg is not impossible i think.
In this phase, the first step, it's okay, weighing around 200 kg in the next leg, with new alu rear frame, upgraded air filter, maybe a smaller gas tank, plastic, etc., I am aiming for 195 kg approx. Phase two begins now I November-December 2013.
Photo from the scale comes when our snow and cold is gone.
This tour goes on a 245 kg bike with 19 "front wheel so I'm not worried about the weight, weight challenges me to drive with driving technique rather than the routine.
Please ... Listen a little extra on engine noise!
"IP-Rider"
Ghostbrother screwed with this post 03-02-2013 at 08:11 AM
Old 03-02-2013, 06:41 AM   #1574
bluesman
Oddometer: 3,360
It's entirely possible BUT you will have to chop off much more than your sketch showing and add some.
If weight is importan - CF sump guard is a must for that motor.
Tank is not lightest one too.
Footpegs assemblies kinda fragile and massive at same time - can be easily replaced by machining simpler ones and making same tabs for swingarm axle.
Fully agree - rear hub is lead heavy, but twin disks are not really culprit. Rear wheel as you probably noticed caryy XX more weight because of sprocket carrier. Calipers are not light ones thou and nice Beringer etc. would save a lot of weight.
It would be great if you can turn that Battlecruiser into Starfighter :) I always wanted to do it myself, but did not come across cheap accident Vara.
Subscribed.
bluesman is offline   Reply With Quote
Old 03-02-2013, 08:36 AM   #1575
mousitsas
mousitsas's Avatar
Oddometer: 2,948
Ghostbrother, it would be really nice to know the weight of rolling frame (engine+frame+suspension+wheels), if its not too much of a hussle for you.
As a reference, the weight of a 950SE without fuel and with lightweight mufflers is around 180 kg. If you manage to keep it at 200Kg dry you will end up with a very interesting ride, but like Bluesman said, you will have to get the hacksaw ready.
Times are GMT -7.   It's 02:24 AM.
