04-22-2012, 02:17 PM
#1456 | |
Oddometer: 979
So, on a '08 model, if you don't trust the fuel warning light (when that illuminates you have 4 liters of fuel left and from that moment, the ODO has an setting which gives you a clear indication what mileage is left on the remaining fuel capacity (depending on speed / riding style)
Bernard 'Two Plugs', NL the First International Crosstourer Forum - www.crosstourer-international.com the First International Varadero Forum - www.varadero-international.com May 2013 Wales/UK: 15th Varadero & 2nd Crosstourer International Meeting! |
04-23-2012, 03:37 PM
#1457 | |
Oddometer: 3
It is one of more convenient add-ons that I have installed on my Varadero Pro's
04-24-2012, 11:37 PM
#1458 |
Oddometer: 979
I've tested the Scottie, the CLS200 and OSCO from which the OSCO unit was the best because it can be manually controled on a very precise level. Towards a spray can, the fairytale that an auto oiler increases the live span of the chain and sprockets, is a host. Even with an oiler, you have to replace the front sprocket after apr. 30.000 / I switched back to MOTUL Chain Lube Offroad. Not that I use the bike that much in rough offroad conditions, but it sticks to the chain and keeps it clean. Normally, I use the can every I never have an 'greased' back rim or -fork, but its all about how- and when you apply the chain lube. I only apply it on the INSIDE of the chain, when the chain is still warm after a ride. And leave it there to rest. Its not a big job, any proper biker will turn the wheel frequently on main- or side stand to check the tires. Any auto oiler will set you back apr € 100,- without labour. For that amount of money, I can get up to 10 spraycans which last 2 years per can (I'm doing Just my 2 ct...
04-24-2012, 11:55 PM
#1459 |
Oddometer: 2,993
More Pro :)
-Automatic oiler means that you can use biodegradable oil - yeah, I know, nobody cares what they leave on road...anyway... -Automatic oiler means you do not need to lube chain on long trips. 3500 km = 7 times. That's 1 week of riding. That means that if you have central stand that usually adds good 5 kg of weight to already heavy bike and affects clearance it can be removed (done so on my bikes). - You do not need to find space for spray can ( I prefer smaller luggage). -Proper automatic oiler pumps oil instead of letting it flow, e.g. always put out measured fixed amount of oil per 1 pump cycle. I use PDOiler. 9 levels of adjustment changing frequency of pump cycles but cc per pump cycle always same with any oil viscosity. - On my bikes chain life improved significantly. Firestorm never does 20 000 to a chain, DR800 never does too. - Using of correct oiler cleans chain, this is proven. It stays lubed and clean and makes much less mess under front sprocket cover. - I never ever had overspray on rear wheel and I install oiler using self-made nozzle that drops oil to chain under front sprocket. - Any problems with oiler installed in way, it requires removing panel to refill is installer fault IMHO. I fitted PDOilers to 4 bikes and all owners can refill and adjust rate without removing anything. - I never install tube on rear sprocket so I never had described problems. - I never have to refill more often than let say every 2000 km. But again - this is with PDOiler, on road. E.g. good auto oiler good if you do more of long trips than daily riding. Only Cons I can see - PDOiler costs 55 pounds, it is about costs of 5 small-ish spray cans where I live. - Auto oiler won't change relation between sprockets and chain life. Chain worn=sprocket worn. To be honest I never before heard statements about chain oiler improving sprockets life over chain life. May be on other bikes...do not know. - It has electric parts and I never trust anything electric. Thou I ride bike with CDI etc. That's I guess my own paranoia
04-25-2012, 03:56 AM
#1460 |
Oddometer: 979
Biodegradable oil? You also ride an electric powered bike plugged in on an Atomic Power plant?
![]() Seriously... how about the rubber you leave on the road, flushed in the enviroment by the rain, the oil in your oilpan, etc? We are bikers. Enviroment, sustainebility and dureability are important Global issieus - no argue about that - but for enviromental issieus they build things like Prius or Insight... About the frequenty... Using good oil for chainlube (either auto-oiler or spraycan) is obligatory. And 7 times in 3.500 km... that's not my statement: I wrote 1 x 1.000 km... ;) And it still works. I think its also a matter of personal choices. If some one is happy with an auto oiler, that's fine. But they don't increase live span of chain + sprockets compared with a spray can.
04-25-2012, 04:06 AM
#1461 | |
Oddometer: 3,816
Probably not sprockets but definitely chain In my experience.
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. |
04-25-2012, 05:54 AM
#1462 | |
Oddometer: 2,993
But come on, with all my respect chain, that lives for 20 000 on Varadero with oiling ince per 1000 km with spray can means you have featherlight trottle hand. And I do not think you do, at least I never seen "slow and easy riding Dutch people" - mostly hard and fast riders. My VTR eats chains MUCH faster than that (until I put oiler on). Or you meant about part of your riding in Netherlands and Germany where roads are VERY clean comparing to many other countries. Spray can that lasts for 2 years for 2 bikes that do 10 000 miles a year? Wow. About biodegradable. How about slipping and sliding down roundabout because previous rider over lubed his chain with good quality lube and when it got properly hot it left slippery patch? This is how one of my friends came to my garage to glue his Fazer 600 plastic together after lowsiding it... Rubber do not eat tarmac. And if nobody else cares - why I can't? It is my personal choice. |
04-25-2012, 12:28 PM
#1463 |
Oddometer: 7
my bike
Hello guys, this is my varadero. Trying it out on the gravel and the sand, and find it a big too heavy.
04-25-2012, 03:52 PM
#1464 |
Let's Go!
Oddometer: 300
California Dreaming
Welcome to the forum.
I'm sure you'll find the Dero great in the gravel as you gain more experiance although deep soft sand is a struggle. It's a great bike and will give years of dependable service.
Mark 2008 Varadero TCAT Ride Report . http://advrider.com/forums/showthread.php?t=825909 |
04-26-2012, 05:00 AM
#1465 |
Oddometer: 7
Pegs
I am looking to buy a set of other pegs - for the gravel and sand roads.
Does anyone have experience with good ones, or maybe a tip? Thanx! ANd another question: does anybody know if it is possible to switch off the ABS? california dreaming screwed with this post 04-26-2012 at 05:06 AM Reason: one more question |
04-26-2012, 05:16 AM
#1466 | |
Oddometer: 979
Try www.varadero-international.com and www.varaderoclub.nl as well!
04-26-2012, 05:26 AM
#1467 | |
Oddometer: 7
04-27-2012, 12:14 PM
#1468 |
Zan de Siropoulos...
Welcome....Nice colors...!
John XL1000V Varadero MK2...! Adv. in Lake Como Italy.... Albania express.... West mediterranean coast.... |
04-27-2012, 04:51 PM
#1469 | |
Oddometer: 158
04-27-2012, 10:32 PM
#1470 | |
Oddometer: 7
