Old 04-09-2008, 09:53 PM   #61
mackley
mackley's Avatar
Oddometer: 91
Talking
Hey CJ,
My cover arrived today and to say I'm happy would be a huge understatement. As sexy as it is to look at I can't wait to get it on the bike and use it.
Once again it has been a pleasure to deal with you. I'll let you know how it holds up to the punishment it's about to cop.
Thanks Matt
A MAN MUST HAVE HIS TOYS
mackley screwed with this post 04-10-2008 at 05:54 AM
mackley is offline   Reply With Quote
Old 04-09-2008, 10:30 PM   #62
The Big Bear
THE BIG BEAR
The Big Bear's Avatar
Oddometer: 244
Cover
Awesome Work CJ
Got the Cover
Was out this weekend and when I got back the surprise was on my patio!!!!
Post a Pic when I get it on.
Thanks Bear
The Big Bear is offline   Reply With Quote
Old 04-11-2008, 12:11 PM   #63
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Thanks for letting me know they made it to you guys safe.
Place bike on SIDE stand, you should only loose a few drops of oil.
When you go to install make sure your brake lever is not already bent in, look down from above, it should be straight. These are a tad thicker than your stock cover to allow for the Rekluse, if equipped. My brake lever was bent in far enough it rubbed my stock cover when the bike was new. Pulled it out to clear and have had no issues since.
Otherwise, to install I just pull the the clip on the brake adjuster, pull the pin out. Pull the brake lever down and put the pin back in so the lever is above the pin. Got that????
Loosen bolts and install cover. Repeat everything backwards. 10 min tops.
Potential Warnings!!!!
During normal use in warmer weather you should see no sludge build up (yellow-brownish slime). All motors form a bit of condensation inside of them. When warmed up this should get burned off and be removed from the engine. Now that you have a see through cover and can see this condensation. In cooler climates you may see this condensation. Don't think that your water pump is shot immediately.
I find that in temps cooler than 50F it may take up to 30 min or more at full motor temps for this to go away. The shorter the trips, more condensation can be built up, taking longer to get rid of on the next ride.
So if you see slime:
1) Think- Have you lost coolant lately? Is there any coolant in the Reservoir Bottle? If not- Pull your fairing and make sure there is some in the Radiator. Running low is BAD!!!
2) Make sure your motor is up to full temp and has been run for 30+ min. A quick run 5 min run to the store or work won't be enough.
3) If after you have run it for 30-40 min and you still see sludge, than pull your oil filter. If you are running a Paper filter, than you may see some waves in the pleats. They should be straight. If they are not straight, than it's water pump rebuild time IMHO. If they are straight and your not loosing coolant, it's most likely condensation built up.
If you are running a Stainless filter, you're on your own. You make the call if you want to replace the water pump of not. Think about #1) That's why I run paper filters.
I hope this helps to take some worry away and help understand what's going on in your motor.
Safe travels,
CJ
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer screwed with this post 01-29-2011 at 07:24 AM
cjracer is offline   Reply With Quote
Old 04-16-2008, 08:46 PM   #64
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Starting a list for the next batch. Anyone interested, best get your name on early, as first come first serve. I'm not sure how many the next batch will be as material cost have gone up a bit. It's looking like it will be about 3 months out yet for the next run.
When I finalize cost, I'll post prices. All I need if interested is a color option you prefer so I can get a count, even that can be changed up to the point they get sent out. Before they get sent out for anodize I need payment.
Rekluse package combos available also.
cj
Old 04-16-2008, 08:59 PM   #65
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
cj
OK - Put me down for Aluminum/Titanium.
Flanny is offline   Reply With Quote
Old 04-19-2008, 06:20 AM   #66
lostlobos
lostlobos's Avatar
Oddometer: 77
cj
CJ Don't forget the ORANGE one for Malaysia
lostlobos is offline   Reply With Quote
Old 04-21-2008, 10:32 PM   #67
hilslamer
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,786
Starting a list for the next batch. Anyone interested...
Oohh! Oohh! Me me me me! Got mine on the way....link soon to be HERE:
http//:................................................. ........
hilslamer is offline   Reply With Quote
Old 04-24-2008, 03:07 PM   #68
pburke
Talks more than he rides
pburke's Avatar
Oddometer: 995
cjracer installing Rekluse and Clutch Cover video in HD:
Windows Media here
Flash here: http://www.vimeo.com/937204
The cover shows up about minute 8 of the video - up to that point it's just Rekluse stuff
pburke screwed with this post 04-24-2008 at 03:14 PM
pburke is offline   Reply With Quote
Old 04-25-2008, 07:30 PM   #69
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Everyone that took part in this first run has received there covers and clutch combo kits.
As these start seeing some use I hope to read some replies on how they are taking your abuse.
Thanks again,
CJ
Old 04-27-2008, 01:46 AM   #70
goolie
Oddometer: 44
OMG that's one badass clutch cover . I was going over some stuff over on paochow's site and ran across it.
My 950 has been stock long enuf, time to bling out. I hope you can Make Mine Orange!!
Sending you a PM to get mine!
--goolz
'06 KTM 950 Adventure S
goolie is offline   Reply With Quote
Old 04-27-2008, 06:01 PM   #71
wshoc840
wshoc840's Avatar
Oddometer: 399
Hell yeah
There are Farkles and Then there is BLING baby
2006 KTM 950 Adenture
1997 KTM 620 RXCE
Trip to the West Coast
CJ Designs LLC - Specializing in custom parts for KTM ADV motorcycles
CJ Designs Blog
wshoc840 is offline   Reply With Quote
Old 04-27-2008, 08:03 PM   #72
Desert Yeti
Desert Yeti's Avatar
Oddometer: 246
That's not bling... everyone knows BLING only comes in ORANGE!!!
Rich
Rock Stars MC
TRS
05 KTM 300 MXC
07 KTM 950 SE-R
Desert Yeti is offline   Reply With Quote
Old 04-27-2008, 08:32 PM   #73
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Wow, that looks sweet. First Orange one I've seen installed.
Now how about the complete package?
Old 04-28-2008, 08:56 AM   #74
highlandcycles
highlandcycles's Avatar
Oddometer: 451
Don't mean to hijack thread but Cjracer, what skid plate are you running. I am looking for a bulletproof one. Thanks
Ni Siochain Go Saoirse
VIVA LOS MTNADS
www.highland-cycles.com
Highland Cycles
Montrose, CO
970-240-2197
highlandcycles is offline   Reply With Quote
Old 04-28-2008, 10:32 AM   #75
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Black Dog Cycle works,
Times are GMT -7.   It's 05:59 PM.
