Old 10-07-2012, 08:34 PM   #391
MZRider
Neo-Luddite
Oddometer: 726
dancerdave - give Mark @ Moto Guzzi Classic a call on Tuesday - he can likely fix you up with everything you need. (562)986-0070. Headlights are especially scarce though - it seems everyone put Windjammers on their Guzzi back then and junked the headlight.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 10-08-2012, 04:16 AM   #392
mtiberio
mtiberio's Avatar
Oddometer: 88
if you are not an originality fanatic, emgo makes some replacement headlight shells for not too much money. they have british variants that are a bit deep, but work, and I have also used some kawasaki replicas, that have the right depth, but need fender washers to bolt to the headlight ears.
mtiberio is offline   Reply With Quote
Old 10-08-2012, 08:25 AM   #393
dancerdave
Oddometer: 168
The head light and ears are chrome and would like to find some like those to put back, the exhaust has lots of rust on bottom, both gear shift and rear brake arms are pitted just to give an idea what I am needing .. I could leave it like it is and worry about how long this thing will run before sinking loads of money in something that will die soon..it runs great for a bike that has set for so long but it took a couple of weeks to get it that way.. Not knowing about a Guzzi was mostly to blame tho..this throttle cable routing has been a bitch, I can't find a way not to put them in a bind but I have time and new cables will help.. Being a BMW rider I find I compair the two of them, but mostly riding dual sport bikes isn't fair and me being old the Guzzi will win because of the easy to get on and off...
never let be said to your shame that all was well before you came
dancerdave is offline   Reply With Quote
Old 10-13-2012, 05:58 PM   #394
dancerdave
Oddometer: 168
Mzrider I tried to call Mark.. I left a message hopefully he will call back..thanks for the help.
Old 10-13-2012, 11:16 PM   #395
Nick in PRC.
Nick in PRC.'s Avatar
Oddometer: 267
Keep trying.
_________________________________________
Nick in PRC.
CJ M1s & some two wheel Guzzi's.
Chang chat: http://cj750.forumcircle.com
Nick in PRC. is offline   Reply With Quote
Old 10-28-2012, 04:56 PM   #396
dancerdave
Oddometer: 168
I got a chance to ride this old bike today and headed for some gravel just to see how it did on some old roads close to my home, i was supprised how it handled on both gravel as well as twisty roads.. to me it felt best on an open road running at highway speeds.. it seemd tohttp:// want to go faster.. it has a little oil leak at the valve cover on the left side..
Old 10-30-2012, 03:16 PM   #397
nick949eldo
Oddometer: 1,102
Guzzis on Gravel
Yep - the old Guzzis do quite well on gravel.......
nick949eldo is online now   Reply With Quote
Old 10-30-2012, 05:39 PM   #398
dancerdave
Oddometer: 168
I am so new to moto guzzi and have lots to learn.. I need to learn first why it is so hard to start and where the oil is coming from. Hopefully restore thing to be my daily riders and can see I don't need to worry about a little gravel after looking at your bike..
Old 10-17-2013, 12:36 AM   #399
England-Kev
Oddometer: 3,743
A nice way to spend an hour, re going over this old thread....
England-Kev is offline   Reply With Quote
Old 10-17-2013, 08:30 AM   #400
flemsmith
lurk
Oddometer: 720
Hard to start?
One thing I've always really liked about my T3 is how instantly it starts, sounds almost like my old road king that way. Assume you've double checked timing? And looked into the carbs? Valves and head torque? That should do it you'd think.
Also noticed something about running the throttle cables: I messed
with that a while before I learned that if you run them alongside the frame opposite their respective carb, then let them cross over each other roughly where the rear tank rubber mounts fit the frame, you'll end up with a pretty smooth route that works better than anything else I tried.
good luck and have fun.
roy
flemsmith is offline   Reply With Quote
Times are GMT -7.   It's 05:44 PM.
