Old 06-08-2011, 01:31 AM   #5086
lewiss66
lewiss66's Avatar
Oddometer: 372
Thanks you all for your answer.
Snooker, glad you're here to clarify! It's been already 10 years since I last walk and ride a bike on your ground (and pracitice english).
Well, as you said my concern is a tubless to remove while on road. Is it a pain to remove this tire alone with only a pair of tire lever. Do you advice me to better wait for the dealer to sale those TT heidenau's type tube tire.
(Heidenau has already release the K60 scoot in Type tube in 140/80-R17).
Any of you have ever experience a flat tire and have to fix It on a side of the road?
http://g650forum.forumactif.org/
http://buyvintage1.files.wordpress.c...porteur_01.jpg
G650 Xcountry 2007 / Beta evo 4T 2011
lewiss66 is offline   Reply With Quote
Old 06-08-2011, 05:30 AM   #5087
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,821
Originally Posted by Niedz View Post
not gonna use red. oh jeez, now what am i gonna do?!! i probably need a new gasket, i should order that. ill give tightening them one more shot, this time ill loosen them all up and then alternately tighten them in a star pattern, the way i should have done it the first time. see if that does the trick. in the meantime i can wait for the gasket to come from germany like im guessing it will have to.
I'm not normally a person who uses a torque wrench on EVERYTHING but, would probably be a good idea to actually use a torque wrench. Make sure you are definatly getting them tight enough without overdoing it due to frustration.
muddyrabbit is offline   Reply With Quote
Old 06-08-2011, 05:36 AM   #5088
muddyrabbit
Lost Boy
Oddometer: 3,821
Had another thought, put blue Locktite on the threads and try putting some red up by the flange of the bolt head.
Old 06-08-2011, 06:39 AM   #5089
muddyrabbit
Lost Boy
Oddometer: 3,821
Well i am about to finally build our first 2 sets of prototype aluminum luggage so my current set up needs to go. Thought i would offer it to my fellow X Cons first sin e luggage/fuel options are pretty thin for us.
Check the flea market for details.
muddyrabbit screwed with this post 06-08-2011 at 08:55 AM
Old 06-08-2011, 07:43 AM   #5090
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 266
A pity you're over the pond, as I'd def be interested!
I'll get me coat..............
Harty is offline   Reply With Quote
Old 06-08-2011, 08:15 AM   #5091
MisterMo
mach schnell!
MisterMo's Avatar
Oddometer: 271
seat height on X Country's?
Ive heard that the seat height was lower on the 09s from the previous years. True? Is this due to a change in the suspension or a lower seat?
Any other differences (besides color) to consider when comparing model years?
I've tried searching the forum and this seems to be the major thread. But I can't go through all 341 pages.
Thanks.
Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts. Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime. -Mark Twain, Innocents Abroad
09 R1200GS/A, 93 R100GS/PD
MisterMo is offline   Reply With Quote
Old 06-08-2011, 08:45 AM   #5092
Niedz
Niedz's Avatar
Oddometer: 614
Originally Posted by DRONE View Post
Just realize that blue loctite turns liquid when you add heat--like the heat from engine oil. You'd have to use red loctite, and that stuff is of course a bitch to get hot enough to loosen. But I'm thinking, I will never need to loosen those bolts so why not? If I ever NEED to open up the engine, I'm taking it to the dealer!
just did a little googling, loctite 246 blue is stable up to 450 degree F continuous.
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 06-08-2011, 08:58 AM   #5093
Janet from Joisey
Bad Kitty
Janet from Joisey's Avatar
Oddometer: 676
Thanks.
2009 model comes with adjustable hand levers, too.
Janet from Joisey is offline   Reply With Quote
Old 06-08-2011, 11:22 AM   #5094
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,558
Can somebody with experience/knowledge on tubeless type tires comment on whether you think they are much stiffer and therefore more difficult to change a tube in than a comparable brand/model tire that is a tube type?? Of course the K60 scout tubeLESS type is really what is in question here, but what is the thinking in general?? I don't think anybody commented on that yet...
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker screwed with this post 06-08-2011 at 01:43 PM
snooker is offline   Reply With Quote
Old 06-08-2011, 11:45 AM   #5095
Niedz
Niedz's Avatar
Oddometer: 614
i have had the stock rear metzler tourance on and off with tire levers alone.
dont know if that is tube specific tire or not though. but someone did comment that they are stiff.
i have a set of kenda big blocks waiting to be mounted, and they are tubeless compatible, but i am not really worried they dont seem any stiffer than the metzlers. i did read somewhere though to leave them in the sun for a while right before you mount them to get hot and a little more pliable. i think im going to do that.
Old 06-08-2011, 12:02 PM   #5096
snooker
snooker's Avatar
Oddometer: 1,558
Blue threadlocker!
Good point... I've found that most blue threadlockers in hardware and even auto stores (at least in the U.S.) sell Loctite or Permatex brands that are based on the 242 by Loctite, but this is NOT always what we need for hot engine (oil) environments. There are other, better "blue threadlockers".
I'm no expert but when I installed my used Rekluse clutch they provided Loctite 243 which is oil and heat resistant. I needed more but none of my local auto stores (and I'm in a decent sized city of 200,000)... well nobody had 243 and were confused trying to order it as they could only get big sizes, so I finally ordered Loctite 243 from amazon.com. Online was the only way I could find smaller sizes as I'll never use the bigger expensive bottles.
It's possible 246 is even better but I too read the application description on both of the tech data sheets on each, and only the Loctite 243 data sheet said: "The product offers high temperature performance and oil tolerance."
That's what I'd use, but of course I already have some. Guess I better check my drips now...
Old 06-08-2011, 12:09 PM   #5097
Flachlandtiroler
sincere amateur
Flachlandtiroler's Avatar
Oddometer: 219
Needed a new chain and sprockets.
Under acceleration in 1st and 2nd I could feel and hear the chain slipping over the rear sprockets' teeth.
Chain and front sprocket lasted 25 K kilometers, rear sprocket 17 K.
I mounted a steel one from Stefan Scheffelmeier this time, I'm curious if it will hold up better/last longer.
What's your mileage??
Flachlandtiroler is offline   Reply With Quote
Old 06-08-2011, 12:34 PM   #5098
dieselwolf
dieselwolf's Avatar
Oddometer: 27
Originally Posted by snooker View Post
Of course the K60 scout tube type is really what is in question here
My husband mounted these tires two weeks ago with a portable tire changing station (Moose Racing). I got 130/80-R17 on the rear. These are very stiff tires and was not easy to mount them, especially the rear. He did change Kenda Trackmasters using only tire levers but those are much softer tires.
dieselwolf is offline   Reply With Quote
Old 06-08-2011, 12:39 PM   #5099
dip1
Oddometer: 115
Speaking of sprockets has anyone tried a 17 tooth front sprocket? Going a long trip with quite a bit of freeway.
dip1 is offline   Reply With Quote
Old 06-08-2011, 01:21 PM   #5100
lewiss66
lewiss66's Avatar
Oddometer: 372
Thanks dieselwolf,
Hum, That's a bad news. I guess I'll have to wait for the Type Tube k60 scout to be released or go for the TKC80...
Times are GMT -7.   It's 01:52 PM.
