Old 09-27-2011, 06:10 PM   #5686
Bykemeister
Oddometer: 149
i want to thank everyone for their opinions on my idling problem.
MY problem however is that my mechanical skills are.................
well, let's just say that what i DON'T know about"resetting throttle position sensor
and idle actuator positioning" would fill at least 20 volumns.
before i call on my mechanic friends, i was wondering if the dealer will do any of this.
my bike is still under warranty.
thanks again.
07 BMW 1200 GS Adventure
05 BMW 1200 GS
06 Suzuki V-Strom 650
04 Kawasaki KLR 650
06 Suzuki DRZ 400
you can play shuffleboard for five years and age ten, or ride a motorcycle for ten years and age five.
Bykemeister is offline   Reply With Quote
Old 09-27-2011, 06:47 PM   #5687
leafman60
Oddometer: 1,953
Pre-09 XCo rear shock
If anyone knows where I can obtain a pre-09, long length, stock rear shock as fitted on the XCo, would you please Private Message me ? Thanks
leafman60 is offline   Reply With Quote
Old 09-27-2011, 06:55 PM   #5688
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,089
Like this one on the bottom--
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 09-27-2011, 07:08 PM   #5689
leafman60
Oddometer: 1,953
Yes, like the one on the bottom of that pic.
Old 09-28-2011, 06:53 AM   #5690
kr1
SAR-EMT-40
Oddometer: 104
Are both of those set as low as they can go? I have an '07 if that is what you are looking for. Send me a PM.
KR
kr1 is offline   Reply With Quote
Old 09-28-2011, 07:35 AM   #5691
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,903
I have one, brand new, never been in the bike, got it as a warranty replacement and never put it in. I have been considering having John at Moto Pro re-spring it for my weight and selling off my 2 X-Challenge air shocks, but I am still on the fence. The shock is actually at Moto Pro waiting for me to make up my mind, but I could probably be persuaded to part with it, then I could fund finishing my Husqy for conversion. If you still have my number call me if you like.
muddyrabbit is offline   Reply With Quote
Old 09-28-2011, 07:37 AM   #5692
muddyrabbit
Lost Boy
Oddometer: 3,903
BTW, does anyone have a stock shock with the preload circuit blown sitting in their garage? I seem to remember that someone has one that got "Snookered" up...
Old 09-28-2011, 01:29 PM   #5693
kr1
SAR-EMT-40
Oddometer: 104
I was wondering if anyone knew how to release this collar? Do I need a spring compressor or is there another way to do it?
Any help would be appreciated.
KR
Old 09-28-2011, 05:40 PM   #5694
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,089
KR
Are you wanting to replace the bump stop? If yes, I've been told that it can't be done. Don't know if that's true.
WUMPA
Sidecardogs.com
Old 09-28-2011, 08:14 PM   #5695
kr1
SAR-EMT-40
Oddometer: 104
If that is what I am pointing at in the picture is called. The lowering kit that I bought actually replaces that bump stop. The instructions are written in goodley english translated from German. I am trying to figure out the easiest way to replace that.
KR
Old 09-28-2011, 10:40 PM   #5696
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,590
Yo... but you already knew I had one... so not sure what you are up to man?
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 09-30-2011, 09:39 AM   #5697
XFrog
XFrog's Avatar
Oddometer: 71
I have never had either of my BMW's in an actual BMW dealership for service, so I don't know. I would guess that some dealers would frown on some of my suggetions. Cleaning the idle actuator & throttle body and resetting the TPS would be no worries. I am sure they could install a booster plug, change the battery, spark plugs, air filter, etc.
They may take issue with removing the canister or re-rerouting the crankcase vent but this depends entirely on your dealership. I have heard of some dealerships removing the canister because they can cause some fueling problems if clogged.
The things MOST LIKELY to fix your problem are the cleaning and resetting of the idle actuator and removing the canister.
If it is under warranty I wouldn't change anything until they take a look at it as they should fix it under warranty.
Xfrog
thanks again.
XFrog is offline   Reply With Quote
Old 09-30-2011, 10:37 AM   #5698
Niedz
Niedz's Avatar
Oddometer: 641
I have never heard that removing the canister can help alleviate cold stalling issues. I still have my canister and have had stalling issues come and go. When I got the second battery warrantied the stalling issue went away, but has since returned. When I had the bike at the dealer for the 6000mi service they cleaned the throttle body and idle actuator.
I suppose its time to remove my canister (something I've intended to do for a while).
Can anyone tell me the procedure for resetting the TPS? I searched pretty vigorously in all the pertinent X-threads, but couldn't get it to turn up. This time I will save it!
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 09-30-2011, 05:15 PM   #5699
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,089
key off
key on
throttle wide open
throttle full close
throttle wide open
throttle full close
key off
key on
start engine with no throttle
allow engine to find idle without touching throttle
once it settles into an idle, key off
you're done.
WUMPA
Sidecardogs.com
Old 09-30-2011, 07:17 PM   #5700
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,377
key off
key on
throttle wide open
throttle full close
throttle wide open
throttle full close
key off
key on
you're done.
Thanks, Drone. You type. We enjoy.
Geoffster is offline   Reply With Quote
Times are GMT -7.   It's 06:49 AM.
