Old 09-10-2012, 11:52 AM   #7096
donnh
donnh's Avatar
Oddometer: 274
Originally Posted by jjmead1 View Post
Before you go on your trip have the ignition switch resolderd (spelling?). There are many known instances where this is a major issue ( my Challenge most recently. ) Replacing the switch is a poor choice as eventually it will fail again. I had my service tech look at it and the answer I got was it was better to solder it, as it would be more secure than replacing it.
Not my bike but this should shed light on this:
http://www.advrider.com/forums/showp...&postcount=454
Imagine riding to 12,000 feet, turning off your bike to enjoy the views, and the damn thing won't start.
I disconnected the battery connection for my PDM60 which removes all the accessories including the Aux lights, heated grips, gerbing connection and voltage monitor just in case it was messing with the computer. No improvement during a ride yesterday, it died once and wouldn't start twice.
I like the suggestion to re-solder the switch - I've worked as an electronics tech for many years so I'm pretty good with a soldering iron. I'll take it apart and report back.
KTM 1190R, F800GS, WR250R ,ZERO Electric Bike (dead), 74 Norton Commando, 1969 Yamaha Trailmaster. 2010 Sasquatch Ride 2011 Utah Ride 2012 Baja Ride Report 2012 Rocky Mt Ride 2012 Sasquatch Pictures 2013 Seattle to Buenos Aries and BLOG Follow Me
donnh is offline   Reply With Quote
Old 09-10-2012, 12:31 PM   #7097
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,864
Just got a call from the machine shop. He was unable to extract the bolt by boring down into it in an attempt to grab hold and get it to screw out. The bolt now has a hole bored all the way through from end to end. He is now going to cut away the shock to expose the middle section of the bolt.
muddyrabbit is offline   Reply With Quote
Old 09-10-2012, 02:20 PM   #7098
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,916
Perhaps some folks besides Muddy might want to make a mental note to use a little anti-seize should they ever have the opportunity to remove that bolt. I had mine out once, came out easy, never occurred to me to swab it before I put it back in. Probably should have.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 09-10-2012, 02:53 PM   #7099
muddyrabbit
Lost Boy
Oddometer: 3,864
Same here. Dropped the shock out 2 years ago without even removing the wheel, piece of cake. I'd also recommend doing the swing arm bearings yearly.
Old 09-10-2012, 04:19 PM   #7100
kingbob7
Oddometer: 15
Pissed Muddy bolt
Hook the pos. on the welder to one side and the neg. to the other. Put the juice to the b...h and when she starts smoking good,drop the leads and stick her in a tub of water!!
kingbob7 is offline   Reply With Quote
Old 09-10-2012, 04:30 PM   #7101
muddyrabbit
Lost Boy
Oddometer: 3,864
Hook the welder leads to what?
Old 09-10-2012, 04:49 PM   #7102
kingbob7
Oddometer: 15
Pissed Muddy bolt
Each end of the bolt. The current will go through the bolt and heat it up like a stuck welding rod. When it starts smoking and before it gets red, disconnect one lead,then the other. Douse it in water, a bucket big enough to submerge the bolt area, and the bolt will shrink. It will also break the dissimilar metal bond that you have. The alum. on the outside should be unaffected! Sounds pretty exciting!!!! I love this stuff! Bob
Old 09-10-2012, 05:13 PM   #7103
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
I reckon that's why you live in Montana.
And why I live in the city and work at The Derek Zoolander Center For Kids
Who Can't Read Good And Wanna Learn To Do Other Stuff Good Too
I have the skill set of a male fashion model ...
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 09-10-2012, 06:35 PM   #7104
muddyrabbit
Lost Boy
Oddometer: 3,864
Butch just called from the machine shop. Bolt is out and swing arm is OK.
Old 09-10-2012, 06:39 PM   #7105
kingbob7
Oddometer: 15
Thumb Muddys's Bolt
Happy for you Muddy, but wanted to see some sparks. Just remember, the bolts and pins always lose!!
Old 09-10-2012, 11:03 PM   #7106
Johnnyboxer
Oddometer: 1,044
+1
Also replace the 3 'button' screws, with 3 cap head allen bolts whilst you're at it
Saves hassle when doing maintenance
I remove my swingarm every winter, for maintenance.... takes about 40-60 mins working steadily
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 09-10-2012, 11:06 PM   #7107
Johnnyboxer
Oddometer: 1,044
Had that one too, you can wiggle the key and switch to get you going in an emergency and use a zip tie around the ignition barrel & key to lock it in the 'on position' to get you home
Old 09-11-2012, 10:33 AM   #7108
FLAVIO79
FLAVIO79's Avatar
Oddometer: 6
what tires do you recommend that they go well to do a little off? O difficulty to find them because of the type of circle of motorcycle
FLAVIO79 is offline   Reply With Quote
Old 09-11-2012, 01:44 PM   #7109
noisytoys
Oddometer: 44
Same question here, TKC`s aint going to cut it in the mud, al I can find are rear tires, in 100/90-19 is that a viable option?
For instance, Maxxcross SI or SX (what`s the difference?)
noisytoys is offline   Reply With Quote
Old 09-11-2012, 02:23 PM   #7110
muddyrabbit
Lost Boy
Oddometer: 3,864
Try the Kenda Big Block, I've sold a few sets and people seem to like them.
Times are GMT -7.   It's 08:22 AM.
