Thread Tools Rating: Thread Rating: 393 votes, 5.00 average. Display Modes
Old 12-22-2012, 08:17 AM   #2746
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,391
Originally Posted by Jeffy View Post
The rear stick is the actual transmission. The other is an overdrive box. I'd imagine he's only got a 3-speed SM420 in there. It would make more sense to swap in something like a NV4500 or Clark 5-speed.
He also needs to adjust his alternator belts.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 12-22-2012, 12:32 PM   #2747
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,266
Originally Posted by crosscountry View Post
There is only a minor change in RPM after those gear switches. I realize these things redlines at just a couple thousand RPM, but switching that often to get to 30mph seems like overkill - unless you have a trailer full of horses or a house behind you.
Whoops ,made a mistake, the SM420 is a 4-speed transmission.
If the transmission he's got in there is a SM420 or SM465, his first gear is 7.01:1 (6.55:1) with 2nd 3.6:1 and 3rd 1.7:1 with 1:1 at 4th. With 1st that low you're basically left with 3 speeds. I agree that it is silly to run an OD like that when he could have a modern 5-speed. OD boxes are usually found in big trucks like big rigs. Although I think they now use a electronic solenoid so there is a small switch on the shifter and not twin sticks.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is offline   Reply With Quote
Old 12-22-2012, 04:05 PM   #2748
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,542
Not all that "cool", but it is my new shiny thing:
Power from the 2.4 liter 4 cylinder is "adequate" I suppose. I guess I need to manage my expectations and RPMs as it sure doesn't have the torque of the 2.5 liter six in my car - you have to run the RPMs up to get any real power from it, and even then it isn't much.
That's okay (although I may have someone look at it to make sure it is okay) as I didn't buy it to race around in, just as a daily driver.
At least the 4WD seems to work.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 12-22-2012, 04:17 PM   #2749
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,542
He probably doesn't need the aux. trans for normal driving. For that light of a truck he could get away with the main and then shift up the aux. when he is in top gear.
Also, either he purposely has the engine tuned rich or he needs someone to retune his rack - it does no good to be putting out all that unburnt diesel, it doesn't make power, it just pollutes. Beyond that, I am wondering it it really has a turbo as the caption said; the old DDs usually only came with just the supercharger - it was rare to also add on a turbo, although you could if you wanted (we had a 6V92 or was it an 8v92, with twin turbos in a 25 foot MSB in the USCG and that thing was a real powerhouse from what I heard).
'09 Husaberg FE570
'99 Beta Alp
Old 12-22-2012, 04:58 PM   #2750
doc_ricketts
Thumper jockey
doc_ricketts's Avatar
Oddometer: 5,352
1995 Cummins with 230,000 miles and Jayco camper, since removed and sold. Hauls my DR650 and camping/moving stuff now. With a topper only.
Before this truck, I had a new 1970 Dodge with 383 engine that would pull a mountain off its base. And the first truck for me was a 1955 Ford with big slicks on the back, a T-bird overbored engine with electric overdrive (switch on the dashboard for shifting up or down). It cost me almost zero, since a customer left the truck with us after the engine blew and I rebuilt a T-bird engine for it. Look liked this one except for the paint job:
1970 Dodge with the right color paint:
"Get yourself to the hills and be uplifted, assuming you got some good knobbies"
doc_ricketts screwed with this post 12-23-2012 at 08:06 PM
doc_ricketts is offline   Reply With Quote
Old 12-23-2012, 02:39 PM   #2751
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,483
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 12-23-2012, 05:26 PM   #2752
(none)
poser
(none)'s Avatar
Oddometer: 2,619
Nice! Frame in good shape?
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 12-23-2012, 06:30 PM   #2753
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,542
'09 Husaberg FE570
'99 Beta Alp
Old 12-23-2012, 06:45 PM   #2754
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,542
As far as I can tell.
The engine had some head work done on it. New radiator too.
But as I was coming home last night the "check engine" light came on.
I think I am going to have to work out some of the kinks.
Probably take the canopy off pretty soon - don't need it and I want to haul stuff in the bed.
The main thing is that it is completely stock (except for the brush guard which I will probably take off). This way I can know that some kid didn't go out and beat it to death on a trail, and jack up the suspension all wrong, and so on.
The suspension does feel loose, but that is not surprising after 220+k miles. For now I will leave it mostly stock. The idea is to use it as a daily driver and something to haul bikes to the trails in and so on. I just need it to do okay in the snow (it will probably snow here tonight) and muddy/dirt/gravel/potholed roads, and be reliable. I am not going wheeling or crawling with it - I just can't get out of my road without a 4WD when it snows and my other truck (1+ ton Dodge 3500 with 12' bed) is too big to be a convenient daily driver (besides, I need to work on it too).
I just need to get some loading ramps and some studded tires and I will should be set for this winter. I noticed it had some tie downs in the bed at each corner - I will probably get a couple of these though:
'09 Husaberg FE570
'99 Beta Alp
Old 12-26-2012, 10:11 AM   #2755
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 110
Does this qualify?
My daily transport since 1999!
And NO electronics, which is why the Pikeys are always wanting to to steal it to sell in Africa!
Duncan
R1200 GS (07)
R80 being Cafe Racered (82)
R80 G/S (81)
R100 GSPD (92)
Arkwright is offline   Reply With Quote
Old 12-26-2012, 01:37 PM   #2756
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,750
Originally Posted by Mambo Dave View Post
I don't know if they came this way from the factory, but...
They didn't.
However, I did see a few Detroit / twin stick conversions just like that in GM duallys back in the late '70s / early '80s around some of the big-time Quarter Horse shows.
Back at that time, there was no diesel in a light duty truck that could pull a big horse trailer, so everyone used the 454 gas engine in thier GM trucks...
Rocker59 (aka guzzimike), Aux Arcs
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 12-27-2012, 01:00 AM   #2757
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,483
Originally Posted by Arkwright2007 View Post
Does this qualify?
What's a Pikey?
David Hunn:
Old 12-27-2012, 01:09 AM   #2758
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,944
Originally Posted by gsd4me View Post
What's a Pikey?
Lowlife Travelers .
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 12-27-2012, 02:16 AM   #2759
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,185
Does this qualify?
But IFS is ......Gay :ymca
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 12-27-2012, 10:48 AM   #2760
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 110
What's a Pikey?
Travellers, generally from the Irish Republic, in this part of the world they steal anything metal that's not bolted down and most of the lead from church roofs. They've tried to steal this one three times, they got my last one, used it in an ATM robbery (dug it out of the wall with a stolen JCB) and dumped it with the empty ATM in the River Trent, after 7 similar robberies they were rounded up and got an average of 4 years after having got 700,000. Half sentence for good behavior and guess what..................................it's happening again! Two of them after trying to buy it at a car boot sale then proceeded to tell me how they were going to steal it without waking me!
Duncan
R1200 GS (07)
R80 G/S (81)
R100 GSPD (92)
Thread Tools
Times are GMT -7.   It's 05:59 PM.
