Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 525 votes, 5.00 average. Display Modes
Old 05-26-2010, 12:03 AM   #1276
ColinDoyle
ColinDoyle's Avatar
Oddometer: 724
Nice, utilitarian truck. As trucks should be!
Colin Doyle
2004 BMW R1150R Rockster | 2008 Honda Ruckus
ColinDoyle is offline   Reply With Quote
Old 05-26-2010, 05:04 AM   #1277
Ride_There
Will ride for bacon.
Ride_There's Avatar
Oddometer: 3,125
that does look useful. Nice
Ride_There is offline   Reply With Quote
Old 05-26-2010, 09:43 AM   #1278
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
yes, it's very utilitarian... is there a forum for discussing diesel truck repair/issues on advrider, just curious.
cynicwanderer is offline   Reply With Quote
Old 05-26-2010, 10:23 AM   #1279
rmarkr
Squatter
rmarkr's Avatar
Oddometer: 407
My 49 CJ2A
Found growing in the weeds - took a bit of work.
rmarkr is offline   Reply With Quote
Old 05-26-2010, 10:28 AM   #1280
Speed King
Speed King's Avatar
Oddometer: 1,650
^^So freakin' cool.^^
Speed King is offline   Reply With Quote
Old 05-26-2010, 11:06 AM   #1281
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,712
Originally Posted by rmarkr
My 49 CJ2A
Nice work.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 05-26-2010, 08:50 PM   #1282
TinyBear
TinyBear's Avatar
Oddometer: 548
Dont think their is BUT what ya need to know pm me if ya like.
IM a diesel tech by trade and spent a few years working on the old IDI Ford diesels like ya have there. Is yours a 6.9L or a 7.3L?
Oh and i used to own a VERY well tuned and modded 7.3 IDI with the factory turbo. Truck went like stink (it would out run my first bike a 650cc vstar witch was slow for a bike but still impressive for a 7000lbs truck to beat it). BUT it also was not very reliable after the modifications LOL. But hey that truck would still see 21mpg driven nicely.
Heres some pics of my old BEAST ( i miss that truck ).
would ya believe i bought that thing as a beat up farm truck LOL Little elbo grease and ALOT of work and about $3000 go a long way LOL
TinyBear is offline   Reply With Quote
Old 05-26-2010, 10:01 PM   #1283
cynicwanderer
Oddometer: 555
very nice truck you had. I just picked up my truck. it used to be someone's work truck (lift gate and a vice, etc...), maybe a farm truck. the engine/tranny is great on it, and the frame doesn't have any rust, the bed does, etc.. only has 122,000 miles on it. it's a 6.9l without turbo.
however, someone converted it to veggie and got rid of the mechanical fuel pump, switchover for the dual tank, and installed electric fuel pumps and coolant heated fuel line and tank heater for the veggie tank. they also ran some bad diesel/bio diesel and the rear tank has red/brown varnish/slime in it and both of the electric fuel pumps are ruined, etc...
anyway, I ordered a new rear tank (it was cheaper than trying to clean the exising tank) and new fuel pump. at this point I just want to get it running on diesel with one of the tanks and then eventually rip out the veggie conversion stuff, since it's kind of hokey/amateurish and convert it back to normal. I'm also tempted to add a turbo kit (banks, or ATS?) at some time in the future to get even better mileage, especially at elevation.
at this time, I'm just trying to figure out what the standard fuel delivery system should look like and whether the fuel pumps that came on it are adequate (they are some generic fuel pump from napa), or whether I should go back to the manual pump.
Old 05-27-2010, 06:21 AM   #1284
JasonH
JasonH's Avatar
Oddometer: 188
While we're on old Fords, here's one I sold a few years ago to a guy in New Zealand. He bought it based on my pictures and had it shipped over.
85 F350 with the 6.9L and a C6. I added a Hypermax turbo kit and a Gear Vendor. Originally owned by Jerry Owens of Owens Sausage. He bought it to haul his hot air balloon. Had dual sunroofs (that leaked like screen doors). Looked like new in and out.
78 R80/7
JasonH is offline   Reply With Quote
Old 05-27-2010, 06:24 AM   #1285
TinyBear
TinyBear's Avatar
Oddometer: 548
The manuel pump worked well enuff even with the modifications i made but if its got electric pumps on it now and they they work they will deliver just fine.
I dont have any experiance with vegie converstions but if ya live in a colder climate Veggie coversions are problematic due to gelling of the fuel (even coolant heated).
Sounds like youron the rigth track but i would recomend you stay away from the turbo kit. It will net ya better power and a bit better fuel milage BUT 6.9L had issues with head gasket failurs due to a weaker head bolt. They do make much nicer stronger STUDS for the 6.9L and that would handel the boost just fine if ya really want to go all out. The 6.9L is imho a better engine than the 7.3 as they are more robust and not suseptable to cavitation of the cylinder walls like the 7.3 are.
Also for trouble starting check your glow plugs. ITs easy to do. take your test light put the clamp on the POSITVE terminal of the battery. And then Disconnect the harness plug for the Glow plug (8 of em) and touch the test light to the glow plug end. If it lights up the glow plug is good.
Also if its got air in the system (AKA if it has starved for fuel). your gona need to pull off the fuel filter and fill it with GOOD diesel and put it back on. You may need to give it a LITTLE either to get it going and bleed out the air in the fuel system.
It may be a good plan to put a bit of fuel conditioner and 1/2 a liter of automatic trans fluid in your first tank of fuel as well if the trucks been sitting for a bit. Veggie and Bio Diesels are hard on the seals of a old mechanic injection pump. The 50/50 mix of Atf and conditioner is a old trick to help seal up the pump a bit and it will run MUCH better if or untill the seals dry out again.
Old 05-27-2010, 06:16 PM   #1286
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,619
This is a Leyland Buffalo,the biggest on road British truck of the '50's.Very few came to New Zealand,and I think I might know this one.My father worked as a mechanic for a haulage company,and their Buffalo was his favorite truck...it was used to haul the biggest loads,not fast,but it could pull them.A sad state for one of the mightiest trucks on the road in that era.
motu is offline   Reply With Quote
Old 05-27-2010, 06:31 PM   #1287
SKT
Born II Ride
SKT's Avatar
Oddometer: 78
My 49 CJ2A
Good looking Willys!!
Do you have any before pics?
'02 HD Deuce
'07 HD Springer
SKT is offline   Reply With Quote
Old 05-28-2010, 08:14 AM   #1288
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,973
Originally Posted by jesusgatos
Where is that? I know someone on Steel Soldiers would love to rescue and restore that old PowerWagon.
It's just off 68 in Merceer County ,Ky. next to the Kentucky River. IF you know someone who wants to look at it P.M. me.
Old 05-28-2010, 09:10 AM   #1289
cynicwanderer
Oddometer: 555
hey, thanks for all the tips and advice. the truck starts and runs fine now when I run it form a spare tank. originally when I got it, it would start and idle OK, but when driving it, it would starve above 45mph. when I drained the fuel form the tank, it was all brown and decided to pull the tank to find nasty brown stuff growing all over it. eventually, the remaining fuel pump also died off. the other fuel pump was already dead when I bought the truck.
the only issue I have with the electric fuel pumps, is that they cost $70/ea, while the mechanical pump is more like $25. especially, if it turns out that I have to replace the electric fuel pumps on a regular basis. hopefully, cleaning out the fuel system will keep the fuel pumps from dying.
in the stock fuel system, where is the fuel pump located in relationship to everything. from what I gather it's :
tank -> tank selector -> water seperator -> fuel pump -> fuel filter -> IP
does that sound right ? currently, it's hooked up like this:
rear tank -> fuel pump -> water sep. -> fuel filter -> Tee -> IP
front tank -> fuel pump -> heated fuel filter -> Tee -> IP
the tank is selected by powering only one of the fuel pumps since they feed into the same Tee. the return is routed through a valve to the appropriate tank. I'm a little concerned about the active fuel pump pushing fuel through the unselected fuel pump back into the other tank through the TEE, or whether it harms the pump and also that the fuel pumps don't have a filter or water separator in front of it. BTW, the water separator has been replaced with a cartridge style fuel filter/separator, so it seems like it would make more sense to have the fuel pump after it.
the PO removed the original fuel selector valve/solenoid assembly during the veggie conversion, so the tank sender isn't switched over any more. too bad that valve is like $120 bucks.
I don't plan to run veggie in it. it's too much hassle to deal with (obtaining and straining the oil, etc.) and too much stuff that can go wrong with the truck (like having coolant lines running under the truck along the frame to the tank, clogging, etc...). although, in the summer the temps are hot enough here to probably run without a heater (100+F) !
thanks about the advice on the turbo. I was hoping that I would be able to get a turbo where I can adjust the boost. I don't need much boost at sea level, but plan to operate at elevation (7000+ft) from time to time. I'll check out how it does without a turbo at elevation first. at the most, I will be hauling some motorcycles and not a huge tavel trailer. so it's probably not worth making the engine less reliable. all I need is to be able to keep up with the traffic over the passes. I suppose at some point when I have to rebuild the engine, I might beef it up and add a turbo, or just get a different engine with turbo.
the priorities are to have a rugged reliable diesel truck to haul and retrieve bikes (and the occasionaly dump run) and go on trips. maybe add a camper at some point.
now, has anyone added rails to a lift gate so that it can lift a motorcycle lengthwise and roll it into the bed ?
Old 05-28-2010, 09:52 AM   #1290
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,772
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~
My Ride Through Roatan
Road Rash is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:44 AM.
