Old 12-14-2007, 06:10 PM   #1
ryanwilliamcantrell OP
Get Out and Ride!!
ryanwilliamcantrell's Avatar
Oddometer: 3,861
Anyone tried the Self-Tapping-Carbide-Tire-Studs?
I found these:
http://www.aerostich.com/catalog/US/...s-p-19555.html
And wondered if anyone has had any experiance with them? They seem to be a better answer to ice screws for someone like me who will use thier bike to commute to work - without the cost of the studding gun.
Anyone know how well the work (or don't work)?
Ride your own ride & enjoy your ride.
ryanwilliamcantrell is offline   Reply With Quote
Old 12-14-2007, 06:35 PM   #2
Knute Dunrvnyet
marooned in realtime
Knute Dunrvnyet's Avatar
Oddometer: 1,984
Thank you very very much! I been having to replace lots of screws every wkend on my TW. I will most definitely try them. You broke it wide open for me. Thanks!
"I used to be an adventurer like you; then I took an arrow to the heart."
[advwhiner since 1973]]
"Ride Hard, You can Rest when you Die."- Emmett Watkins, #245, 1958-2005
Knute Dunrvnyet is offline   Reply With Quote
Old 12-14-2007, 06:56 PM   #3
ditchbanker
Owner of dull user line
ditchbanker's Avatar
Oddometer: 1,143
Please, somebody tell me that this product is terrible. Otherwise I think Ryan may break my other arm.
(Which basicly means that )
"I can't think of a single unmemorable camping trip we've had."
--Heath
ditchbanker is offline   Reply With Quote
Old 12-15-2007, 03:13 PM   #4
ktm950se
ktm950se's Avatar
Oddometer: 1,385
I too would like to know if anyone has experience with these studs
ktm950se is offline   Reply With Quote
Old 12-15-2007, 05:48 PM   #5
ditchbanker
Oddometer: 1,143
I've decided that, if I'm going to keep riding with Ryan, I'm going to need these, because he's going to ride through snow and ice regardless of what's on his tires. Then again, I'm not the one who went down today...
--Heath
Old 12-21-2007, 11:53 AM   #6
Cauldron
Now in DESMODROMIC!
Cauldron's Avatar
Oddometer: 2,939
Question
so nobody has ever used them???
and sorry about the D-con sprinkles on your strawberry shortcake.
Cauldron is offline   Reply With Quote
Old 12-23-2007, 08:58 PM   #7
Get Out and Ride!!
Oddometer: 3,861
Seems that way...
I went ahead and drilled a set of screws in today instead, since nobody seems to have tried the self-tapping studes.
Old 12-23-2007, 09:39 PM   #8
Tim McKittrick
Oddometer: 1,760
Those look interesting- I have had a lot of problems with standard car studs staying in the tires. I wonder if these might be a little more likely to stay put. As for the ice screw method.... these are the real deal:
http://www.rockcentralcycle.com/Ice-...ce-screws.page
On clear ice you can drag the engine cases.
Tim McKittrick is offline   Reply With Quote
Old 10-28-2008, 08:12 PM   #9
Norsman
...a GSophile
Norsman's Avatar
Oddometer: 2,347
Originally Posted by ryanwilliamcantrell
Seems that way...
How did these work out for you? Did you ride on any asphalt at all?
2004 BMW R1150GS ADV
My SmugMug...save $5 on a SmugMug account with this: tKOaEps81O7hN
my2wheels
Norsman is offline   Reply With Quote
Old 10-29-2008, 09:34 PM   #10
Get Out and Ride!!
Oddometer: 3,861
Little to no asphalt. They worked great in hard-pack snow - traction was fantastic.
http://advrider.com/forums/showthread.php?t=298962
Old 11-01-2008, 04:34 PM   #11
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
couple of guys on GSs have em here in the city. They said it gets squirly on bridges that have metal grating and when going over any metal in the city (manhole covers, drainage ditches, steel sheets, e.t.c.).
I think they're buts using em in the city though, but hey they said it was good for the snow....this was in june.....
HaChayalBoded is offline   Reply With Quote
Old 11-02-2008, 09:12 AM   #12
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
Their great if you stay on snow / Ice. they are ICE screws. Any pavement will wear down the heads. Can you say 'tapdance'.
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 11-03-2008, 12:23 PM   #13
ADV Goat
ADV Goat's Avatar
Oddometer: 70
Tire Studs
Yes I have tried the studs from Aerostich. I rode about 160 miles in a good snow storm they did well ice, hard packed and small drifts. My buddy had some studs pull out on his driveway, he was pushing through drifts and spinning the rear tire. I like how easy they are to install and they seem to grab well. I put the Scooter B studs in new TKC-80's and have not had any flat tires. I ride a 08 R1200GS Adventure and will run them in the winter from now on I wondn't recomend them for anyone that want's to blast down the dirt roads spinning there rear tire.
Oh one other thing I have about 500 miles on them and don't see any noticable wear.
ADV Goat is offline   Reply With Quote
Old 11-03-2008, 12:36 PM   #14
Norsman
...a GSophile
Norsman's Avatar
Oddometer: 2,347
That is some great insight, thanks! What made you chose the scooter B studs? I ask, because I'm considering getting the "low profile A" set for some slightly worn TKC-80's... will they be to long?
Do you have to remove the tire to install them?
And one last question... if you hit pavement on them, how did they work then, slippery?
my2wheels
Old 11-03-2008, 02:28 PM   #15
ADV Goat
ADV Goat's Avatar
Oddometer: 70
Norsman
I bougtht the scooter B studs after reading on the Aerostich site that some folks had gotten flat tires. I measured a new set of TKC-80's 9mm & 10mm (I think) and then ordered what I thought would work the best. On pavement I don't notice any slipping I studded the inside two knobbies on the front and rear so it would be a one-two pattern if that makes any sence, when I lean over in a corner there is no studs touching the ground. No you don't have to remove the tires they come with a bit to install them very easy install. I think I may order more to have a 2-3 pattern. When the roads are bad I am going slow, so (in the corners) the studs are touching the ground. When I installed them in my tires we put some in my buddies rear but his front was half worn so we didn't take the chance it was very close we checked this on the half warn front I had taken off my bike. The bike behaves just fine and most of the riding has been on dry pavement about 160 miles of bad snowy icy roads. I may try to take some pic tonight and post it for you.
Hope this helps
ADV Goat screwed with this post 11-03-2008 at 02:49 PM
Times are GMT -7.   It's 10:05 PM.
