Old 10-05-2010, 04:19 PM   #46
unL33T
Oddometer: 9
Originally Posted by redveloce
I imagine they'd look at a motorcycle in the snow pretty closely.
I should clarify that they are not illegal to use here depending on where you live. If you live here, you can't run them. If you live a few hours north or in any of the adjacent provinces, you're good. I suppose I could bypass it by becoming friendly with someone north and change the address on my license to theirs but that's more hassle than I'm willing to go through.
They might look at it more closely. If they do, I'll pay the fine and limit my riding to off road or at least less patrolled areas.
unL33T is offline   Reply With Quote
Old 10-31-2010, 04:28 PM   #47
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,698
We just started studding today. A friend of mine is a veteran Num Bum 24 hour racer, and he recommended running a Cheng Shin C755. Super cheap tire, but he says it awesome because it doesn't chunk like a lot of other MX tires. He runs 4 of the long screws through each knob, and into another cut up street tire lining the inside. They also had a box of the shorter ice screws, so I bought them and we set to it. The first set is going on this guy's 530. We are just going to be screwing around on a nice big pond where he works.
350 ice screws. We can't wait to try them!
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod screwed with this post 11-02-2010 at 01:55 PM
B-Rod is offline   Reply With Quote
Old 03-08-2011, 10:41 PM   #48
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: Northeast PA, Some... On HIGH ADVENTURE Most!
Oddometer: 1,225
Well how'd they work!?
Jettn Jim is offline   Reply With Quote
Old 11-24-2012, 03:00 PM   #49
Canadian FJR
Oddometer: 94
I plan to stud up a set of Dunlop 606s for my KLR this winter. Does anyone have any experience with the Aerostich studs and these tires?
Canadian FJR
Canadian FJR is offline   Reply With Quote
Old 12-03-2012, 06:48 AM   #50
Smoke Eater 3
Oddometer: 68
I have them.
I built an ice bike from a Yama 250 a couple years ago. These studs work great. Easy to install and not one ripped out. I don't ride it off ice and I put a drop of crazy glue on each one during the install just in case. Highly recommended.
Smoke Eater 3 is offline   Reply With Quote
Old 03-13-2013, 11:46 PM   #51
ryanwilliamcantrell OP
Get Out and Ride!!
ryanwilliamcantrell's Avatar
Oddometer: 3,786
Good to know, thanks! I've also used a drop of Gorilla Glue when I put ice screws in, and it helps a lot to keep them in place.
Ride your own ride & enjoy your ride.
ryanwilliamcantrell is offline   Reply With Quote
Old 03-25-2013, 06:41 AM   #52
Canadian FJR
Oddometer: 94
I've got a full winter with the Aerostich studs.
New Dunlop 606s all studded up.
They did work very well after adding a few more in the front tire.
My question is what to do know. Do folks simply remove these until the next winter or keep these tires as "winter" tires and order up a new set. I'm not sure how well the bit will bite these for the removal/install. They are obviously ground down some since the start of the winter.
Canadian FJR
Old 03-25-2013, 02:41 PM   #53
jkm
Oddometer: 185
I use the off-road studs. I leave them in the tires, and consider them my 'winter tires'. I've used them about 6 seasons now and have never lost one.
I would like to stud up a set for the DRZ to be used on-road. Can you tell me what size studs you used? I know there are a number of sizes to choose from, and would like some input. Thanks.....jkm
jkm is offline   Reply With Quote
Old 03-25-2013, 07:01 PM   #54
Canadian FJR
Oddometer: 94
I went with 200 of these:
#4706 Low Profile A (8.7 x 12.4mm, Base penetrates tire 10.5mm, tip protrudes from tire 1.9mm
I need a few more in the rear and I would likely go with the 4707 in the rear if I was to do it over again. I just need to decide what to do with them now. Either leave them in for a winter tire or remove them.
Canadian FJR
Old 03-27-2013, 10:35 AM   #55
jkm
Oddometer: 185
Thanks for the info...jkm
Old 03-31-2013, 06:17 PM   #56
Canadian FJR
Oddometer: 94
Just in case anyone is interested.
After a fairly aggressive run with a bit of spinning yesterday covering everything from dry pavement to ice to snow to dry dirt road to mud I seem to have lost two studs in the back tire. Two more were getting loose.
Tonight I removed all remaining studs from the rear and replaced the front tire. My plan is to keep the studded front as my winter tire and re-stud a new 606 rear when the time comes. The studs came out pretty much as easy as they went in.
Canadian FJR
Times are GMT -7.   It's 02:58 PM.
