Old 08-02-2010, 03:21 PM   #2416
boxertricks
Oddometer: 189
And front wheel drive.
boxertricks is offline   Reply With Quote
Old 08-02-2010, 04:12 PM   #2417
outfit
outfit's Avatar
Oddometer: 658
Originally Posted by boxertricks
Hear you are Karl a Bonny picture or a Bonnie picture.
We're back on track Bring it on
Karl.
outfit is offline   Reply With Quote
Old 08-03-2010, 10:44 AM   #2418
boxertwin
Oddometer: 1,022
Boxertricks,
That looks really 'unsafe'. I want to drive it.
"If there's one thing I'm grateful for in life it's my sunny disposition." -Harry Pierce, MI-5
boxertwin is offline   Reply With Quote
Old 08-04-2010, 04:16 AM   #2419
Agent Wayward
Oddometer: 375
Suspension and subframe
Claude,
pics of suspension and subframe detail as promised:
Custom built swingarm, taper roller bearings at the pivot, Hagon shock, you can see the mount for the brake backplate just behind the hub.
Subframe manufactured for a ZZR600. All four struts mount to this one frame, which is removed from the bike with the two large bolts top front and rear, and the two smaller lower mount bolts in about 4 minutes, retaining the setup completely. This leaves the bike with only two small lugs showing when the bike is in solo mode and makes it very easy to refit, even in a camping field situation. This easy removal and refit was part of the design brief for the fitting. Electrical connection is via a single waterproof plug to the bike. Note this photo taken during a test fitting, hence incomplete.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 08-07-2010, 11:39 PM   #2420
fasteer
fasteer's Avatar
Oddometer: 283
Boxertricks 3-wheel FJ
boxertricks: it's front wheel drive (???!!!) - so those big hoops on the back are just for show?
or added weight to slow it down...
though maybe needs the width to make it stable...
Would be interesting to see the mechanisms that allow a driven wheel to steer.
Wonder how bad the 'torque-steer' effect is; get it into a turn under throttle, maybe only Popeye could straighten it out again (?)
boxertwin, I want to drive it, too.
87% of all statistics are made up right there on the spot.
fasteer is offline   Reply With Quote
Old 08-08-2010, 04:34 PM   #2421
boxertricks
Oddometer: 189
The engine and gearbox are fitted in the front end if I remember correctly, it looks pretty complicated in there. The back end is just the axle and wheels.I'd love to have a go in it,but I don't think I'd fit in there
Old 08-08-2010, 04:36 PM   #2422
boxertricks
Oddometer: 189
Old 08-08-2010, 08:55 PM   #2423
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,700
Terrifying on a wet road, me thinks.
rayb Crash Dummy (no testing involved)
Old 08-09-2010, 04:43 PM   #2424
George Ryals
Oddometer: 15
'72 FLH wit '80 HD CLE Sidecar
Just got this mounted. Still have to round up a windshield and maybe a spoked wheel to match the FLH.
George Ryals is offline   Reply With Quote
Old 08-09-2010, 06:48 PM   #2425
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 489
Thumb
Very nice George, and the spoked wheel would tie the whole ride together.
FLHs look great with a sidecar, are those 16" all around?
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 08-09-2010, 10:33 PM   #2426
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,635
Three Beemer hacks from the AHRMA races last weekend at V.I.R.
Old 08-11-2010, 12:03 AM   #2427
ErictheBiking
Oddometer: 115
My first outfit
1988 goldwing GL1500. The only history I have is that the bike was built in the States. It then went to Japan where the chair was fitted and somehow it ended up in Australia.
Ezy steer on the forks and adjustable electric brake on the chair.
Electric motor to raise and lower front of chair for easy access.
If any one knows name or builder of chair I'd be much obliged.
BTW, how do you people add so many pics at once. It appears you are not going through the ADVrider attach files process.
ErictheBiking is offline   Reply With Quote
Old 08-11-2010, 04:28 AM   #2428
RustyGT
Hairy Bloke
Oddometer: 31
K11 & Hrd
Evening Gents.
Not great pics but an interesting outfit.
K1100LT and Australian built HRD chair.
Originally put together by [the late] Bob Martin in Sydney AU.
Mate Ainsley has owned it about ten years now.
Not long after he first got it he took it back to Bob Martin to have the leading link fitted.
The rear wheel was modded to take a steel rim.
No mean feat fitting a chair to a K bike.
Cheers Rusty.
Edit: Gday from CQ Eric. Thats a good looking rig.
RustyGT screwed with this post 08-11-2010 at 04:33 AM
RustyGT is offline   Reply With Quote
Old 08-11-2010, 08:17 AM   #2429
Burrito Bandito
burrito eater
Burrito Bandito's Avatar
Oddometer: 217
you need to go through a photo hosting site, i.e. smugmug or photobucket etc.
Burrito Bandito is offline   Reply With Quote
Old 08-11-2010, 08:27 AM   #2430
BinDerSmokDat
BinDerSmokDat's Avatar
Oddometer: 404
Photoshopped promotional pic will have to suffice...I just got the call that mine will be ready for pick-up Friday!
BinDerSmokDat is offline   Reply With Quote
Times are GMT -7.   It's 04:43 AM.
