Old 12-21-2007, 11:40 AM   #1
mcnut OP
Oddometer: 1,365
Loading Map Data to Garmin 60csx
OK, I'm old school but soon to move up in the GPS world! In ancient times loading map sets to a Garmin with internal memory via serial port was a slow drawn-out process. Part of the reason was that it always started from scratch even if only one map segment was to be changed. I understand the USB interface is faster and a card reader faster still.
My question: In the newer units that can use a flash memory card, is the process the same? Is the old map set 100% erased and loaded anew even if only 10% of the data is to be changed???
MCNut
mcnut is offline   Reply With Quote
Old 12-21-2007, 11:47 AM   #2
JimC
JimC's Avatar
Oddometer: 1,039
MCNut
Yes!
The USB connection makes this much faster and large SD capacities make the requirement to do it much less frequent. It really isn't an issue anymore on the Garmins.
Jim in Sacramento
JimC is offline   Reply With Quote
Old 12-21-2007, 02:09 PM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,022
Originally Posted by JimC
Yes!
Jim in Sacramento
Is the 60CX that much faster via the USB? My 376c is not that bad, but certainly not quick.
When I get mine in a week or so, I am going to try loading the SD card via the SD reader on my laptop and see if that works. I'm crossing my fingers.
Dave
dunno.....
Old 12-21-2007, 02:45 PM   #4
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
Yes!
Jim in Sacramento
Is this true even if you computer can read the SD card as a storage device?
Reality does not always develop in a way we expect it to.
techieguy is offline   Reply With Quote
Old 12-21-2007, 03:20 PM   #5
JimC
JimC's Avatar
Oddometer: 1,039
The comparison was between a serial interface to the GPS and a USB connection. If you are writing directly to an SD card from Mapsource that will probably be faster than writing through the GPS. How much, I don't know. I find writing through the GPS fast enough for my purposes.
Jim in Sacramento
Old 12-21-2007, 03:22 PM   #6
bombarde
DL650AK7 - K75
bombarde's Avatar
Oddometer: 260
I loaded about 850MB of Topo onto a 1GB card inside a 60CX the other night. It took about an hour or so, but I wasn't paying close attention to the time. It was definitely faster than the olden days.
bombarde is offline   Reply With Quote
Old 12-21-2007, 06:30 PM   #7
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,273
You can load the whole US CN8 to a 2gb card in about 50 minutes IIRC.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 09:16 PM.
