Old 12-22-2007, 04:03 PM   #1
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,072
Leo Vince Installation
Installation of a Leo Vince exhaust on an 07 KTM 990 Adventure.
After much perusing it was decided that the Leo was going to be the system of choice to install on the bike.
The installation was pretty easy with minimal disassembly required for the job.
In order of take down:
Side panels removed. – 3 screws and 2 bolts
Rear grab handles and luggage rack. – 6 bolts
Inner rear fender. – 2 screws and 2 bolts
Exhaust mounting bolts.
Exhaust Flange bolts – connects the cans to the mid pipe
Mid pipe clamp bolts
Here the cans and inner fender are removed, next comes the mid pipe.
The pipe is removed from the throttle side of the bike, it just slips off of the headers and is routed through the frame.
Now in my case with these pipes I had to remove the gasket that is there from the factory, this can be a pain in the ass but it pulls off with enough patience and force.
Also in my case to install the new head pipe I had to remove two bolts for the sub frame so I could slide it back a couple of inches to install the new head pipe.
Be careful here since you don’t want to stress the wires etc that there.
This is what came out..
This is what’s going in..
Here you can see the new header pipe installed on the bike, note that you use the stock mounting points for this whole system just none of the hardware since the stock one has captured nuts. The directions are not that detailed but the diagram lets you figure it out pretty quick overall.
Right side is done
I like the additional details..
Left side is on…
Now that’s a nice looking rear end…
Before:
After:
Weights savings of over 10lbs.
Stock cans were over 11lbs each, the replacements were in the 5.5 range. Not only did i get rid of the weight up high I also got the bike to sound so much better.
I am running the quiet inserts since it would be just too loud without them.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 screwed with this post 03-03-2009 at 02:13 PM
DSM8 is offline   Reply With Quote
Old 12-23-2007, 08:06 AM   #2
DSM8 OP
DSM8's Avatar
Oddometer: 4,072
Ooops...
This belongs in Orange Crush not beasts...sorry bout that it was late...
Old 12-23-2007, 10:01 AM   #3
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,879
Super thread!
Gracie's Gold
Lobby is offline   Reply With Quote
Old 12-25-2007, 02:52 AM   #4
helsingland
helsingland's Avatar
Oddometer: 19
new map?
Any insructions from Leo Vince about new map after mounting the new exhausts ? or is it ok. with the 15 minute map.?
Very nice work on the Leos.
helsingland is offline   Reply With Quote
Old 12-25-2007, 03:40 AM   #5
Chivani
Oddometer: 42
I have the same leo's and first try with the original map, the bike runs perfectly but with a lot of pops, and after i change to the akra map and the bikes runs better than stock map, no pops, more sweet, and think that with the akra map the fuel/air mixture are better. After put the akra map the bike goes perfect .
Chivani is offline   Reply With Quote
Old 12-25-2007, 04:16 AM   #6
Chivani
Oddometer: 42
I try to explain with some photos the solution to the problem with the leos aren't in the same line after assembly.
The left side have to assembly how the instructions says, but the right side are the problem.
This part have to turn the position up to down.
In the instructions, the position of the part are like this
But if change the position like this, you have a little more milimetres to put the right exahust more up.
And if in the assembly of the left exahust you push down the exahust while tighten screws, and in the right exahust push up while tighten screws, do the two sides are in the same line.
At the end after assembly the two exahust, only be carefully with the right screw that goes in there.
have a lot of patience to put that screw, because the clamp now is too near of the subchassis nut.
I hope that the explanation are good, my english are too poor, and i try to help in that case.
Chivani screwed with this post 12-25-2007 at 04:22 AM
Old 12-25-2007, 06:06 PM   #7
DSM8 OP
DSM8's Avatar
Oddometer: 4,072
The new map was already loaded on the bike so I just did the 15 min thing.
My bike just had the recent service. they did the new map then.
Old 12-26-2007, 05:17 AM   #8
helsingland
Oddometer: 19
Is the new map they already done on yours the original update map or is it the Akrapovice map ? Sorry but asking again
Old 12-26-2007, 09:03 AM   #9
DSM8 OP
DSM8's Avatar
Oddometer: 4,072
Mine is the new KTM map that came out in November.
Old 01-01-2008, 02:43 PM   #10
Keith
Slabbing it
Keith's Avatar
Oddometer: 922
Nicely done. If each can saved 5.5lbs of weight, for a total savings of 11lbs, where did the rest of the weight savings come from?
Random Crap
Keith is offline   Reply With Quote
Old 01-01-2008, 05:04 PM   #11
DSM8 OP
DSM8's Avatar
Oddometer: 4,072
Good catch, total savings was 10+lbs not 20.
Thanks for the catch. (that damn 1 key is too close to the 2 key)
Old 01-01-2008, 06:58 PM   #12
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
I have those on my 950SE. Awesome pipes - I had to take both sets of inserts out because it needed to be LOUD!!!
señormoto is offline   Reply With Quote
Old 01-01-2008, 08:56 PM   #13
Keith
Slabbing it
Keith's Avatar
Oddometer: 922
Ok, cool. Still, 10lbs is quite a bit off the tail of the bike.
Random Crap
Old 03-02-2009, 01:21 AM   #14
scalci
scalci's Avatar
Oddometer: 111
Pipes
Seems this is the pipe. I can get a set for a good price now, and wil do this to my baby... Thx for the cool thread..
scalci is offline   Reply With Quote
Old 03-02-2009, 07:57 AM   #15
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
There's a newer style.
I have had two sets of Leos on my 950 and 990 with the same cans pictured
in this thread. Great price and quality.
So it was natural for me to install a set on my SE. Had my dealer order up a
set and when I unpacked them, found they were a different can.
They are close to the same length with a shaped end cap but have a
much smaller oval section, weigh 25 to 30% less and only have a single clamp.
I ordered a second clamp, cut a bracket and what you see below is how they
look.
I'm not sure what's up with LV but they do show the new can on KTM Twins
web site.
Twist it MAX
Da oggi la strada
é senza limiti
MAXVERT is online now   Reply With Quote
Times are GMT -7.   It's 10:18 AM.
