Old 09-25-2010, 05:35 PM   #91
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
I initially had the lines on the outside, but was concerned about them hanging up on the bolts for the crash-bar cross-brace (SW Motech bars, I confirmed contact). I've since put them on the inside, and double zip-tied them to the actual fork leg nice and tight. The "travel" of the lines now all happens below that point, so no scuffing of the fork tubes or lines.
I suspect that my brake lines are STILL coming into contact occasionally with the crash bar bolts under full compression, so I'm going to get some shorter bolts that don't stick through so far...
viola-tor is offline   Reply With Quote
Old 09-25-2010, 06:18 PM   #92
ten_fiver
ten_fiver's Avatar
Oddometer: 1,999
Huh. Thanks VT. Maybe ill just leave them where they are
ten_fiver is offline   Reply With Quote
Old 07-06-2011, 06:40 AM   #93
martinfan
martinfan's Avatar
Oddometer: 74
Ok, I know this is an old Thread but my search engine results only in errors. Do all the lower fork gaurds require a "bracket" to bolt on? or is there a direct bolt on? (2011 990 dakar)
martinfan is offline   Reply With Quote
Old 07-06-2011, 07:15 AM   #94
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 854
These are just crap cell phone pictures but maybe they will help. I used the SX85 fork guards and they only have one matching bolt hole. I reinforced them by using 1/2" aluminum that I bought at Home Depot and shaped myself using a C-clamp and a hammer. Very high tech I know. Then a bit of careful measuring and drilling and done! I will take some more detailed shots of the modification tonight and post the better pictures as soon as possible.
I've learned so much from my mistakes. I'm thinking of making a few more.
09 KTM 990 Adv
Lycan1 is offline   Reply With Quote
Old 07-06-2011, 07:31 AM   #95
martinfan
martinfan's Avatar
Oddometer: 74
Thanks, they look good to me, was gonna just do the same but wasn't sure if there was a direct bolt on. Looks like you've been running this set up for some miles any complaints/adjustments/ something you might do different?
Old 07-06-2011, 07:58 AM   #96
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 854
Actually I only installed it about 6000 km ago, just before the BCBTR6 ride. I really like it and in the mud I don't worry about the front wheel jamming up. I put 3/4 inch spacers between the bottom of the steering head and the top of the plastic fender so that the ABS brake line bracket (plastic T) wouldn't contact the fender. I have a European headlight kit and the electronic module under the light meant I could not raise the plastic bracket like some guys have on the top side of the lower triple, so the spacers underneath were my solution. I had to use 40 mm bolts through the fender to make this work. I did once manage to contact the tire to the underside of the fender crossing a steep banked stream, but I don't see that being a regular problem, and I have not set my supension up quite right yet. If you have ABS ther will be a small piece of the lower plastic bracket that you will need to trim off, but the pictuires will show it better than I can explain.
All in all I have no regrets and love the way it looks.
09 KTM 990 Adv
Old 07-06-2011, 08:31 AM   #97
BikeSDP
Reluctantly Crouched
BikeSDP's Avatar
Oddometer: 498
I made the somewhat foolish decision to make my own fork guards out of the OE fender. That would have been a wise move had I damaged the OE fender, but I didn't. There's no going back now.
Also, I cut a couple sections of that plastic wire wrap to cover the brake lines where they met the fender as they were chafing a bit with suspension movement.
BikeSDP is offline   Reply With Quote
Old 07-06-2011, 08:46 AM   #98
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 854
The chafing is near impossible to avoid. I have been checking the lines and so far they show no signs of damage. I did put a section of 3M clear film on the inside of the fork tubes and on the plastic fender. The wire loom over the line is a good idea. It is cheap and easily replaceable as it wears, unlike the brake line.
09 KTM 990 Adv
Old 07-06-2011, 09:50 AM   #99
DirtJack
DirtJack's Avatar
Oddometer: 1,452
Well actually there is a part which bolts on without modification (I didn't use it because, for other reasons, I had the needed parts).
See: http://www.advrider.com/forums/showthread.php?t=599438
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 07-10-2011, 02:59 PM   #100
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 854
Here is a better look at some of the bits. The bike was being used (as it should be) when I took them so look past the mud.
3/4" electrical conduit and aluminum bushings for spacers. I will make it prettier over the long winter.
right side.
left side, note hole for tying ABS line.
shows where I cut out to fit around the remaining part of the ABS bracket. I cut off the clip.
09 KTM 990 Adv
Old 12-22-2011, 12:43 PM   #101
Masa
Masa's Avatar
Oddometer: 297
Put fork protectors on, from '06 85sx, part #47001094000X4. The "high fender" is modified from a dead stock low fender.
Did my little best to elongate the holes with a heat gun and screw driver, but didn't quite make it, good enough tho.. Routed the ABS sensor cable inside guard, thinking there's enough room even if forks bottom (not very likely with my skills).
Masa is offline   Reply With Quote
Old 12-22-2011, 01:08 PM   #102
RozzyCat
Bleeds orange
RozzyCat's Avatar
Oddometer: 503
Another list
Here's the list I used. Pretty simple install as the only parts that need modifications are plastic. Even I was able to handle that.
http://www.ktm950.info/how/Farkels/a...ender_kit.html
KTM 990, 300XC-W, 500EXC
RozzyCat is offline   Reply With Quote
Old 12-22-2011, 02:17 PM   #103
alpo996
Oddometer: 86
Thumb Studs!
Nice ice studs, Masa! What brand are they, and do they screw in?
alpo996 is offline   Reply With Quote
Old 12-23-2011, 12:02 AM   #104
Masa
Masa's Avatar
Oddometer: 297
I bought tires from a local dealer and don't know much about studding tires, but they use a stud gun to get them on - so no screw ins..
Bigger picture
Dealer's site: http://www.kisarengas.fi/talvihinnasto.html#enduro
Old 12-29-2011, 01:05 PM   #105
alshaffer
alshaffer's Avatar
Oddometer: 48
Which Fork Protectors work best?
After reading through the entire thread, and reviewing the HOW Parts List, my only question is in regards to the Fork Protectors. A lot of discussion about modifying the 85SX protectors (47001094000X4 Orange, 4700109400030 Black) to properly fit the 990Adv forks, but can anyone weigh-in on use of the "KTM Fork Protectors L & R)" (5900109400004 Orange, 5900109400030 Black)? An inmate included these in his parts list early in this thread, but I didn't see much follow-on discussion.
Anyone have any info on these?
2014 Moto Guzzi Cali 1400 Custom
"Although motorcycle riding is romantic, motorcycle maintenance is purely classic." -- Robert Pirsig
"Beer is proof that God loves us and wants us to be happy." -- Ben Franklin
alshaffer screwed with this post 12-29-2011 at 01:34 PM
alshaffer is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
