Old 01-07-2008, 04:42 AM   #1
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Thumb Mount a Motorcycle Tire Without Using Tools
Companion tire dismount thread: http://www.advrider.com/forums/showthread.php?t=299856
No tire irons. Amaze your friends. Do the job with lashing straps.
8 straps are needed. 99 cents each at Harbor Freight.
Strap the tire so the beads are touching.
Place the tire onto the wheel. Notice the gap between the bead and wheel at the 6 o'clock position.
First thing to do is push the bead against the wheel at the 6 o'clock position.
Push the tire over the wheel lip with hand pressure. Push just ahead of where the bead crosses the wheel lip.
Halfway on.
Two-thirds.
Three-quarters.
Hey... Have you noticed? No tire lube.
One last push and...
Pretty cool eh? No tire irons. Only your hands.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside screwed with this post 01-08-2008 at 04:35 PM
Poolside is offline   Reply With Quote
Old 01-07-2008, 05:39 AM   #2
Wanderer99
Oddometer: 106
tire
Awsum you the man !!! I have to try that.
Wanderer99 is offline   Reply With Quote
Old 01-07-2008, 05:55 AM   #3
BSK
Ohhh mist! Die Bullen!!!!
BSK's Avatar
Oddometer: 232
Send a message via ICQ to BSK Send a message via AIM to BSK Send a message via Yahoo to BSK
nice one!
Stephan
12 Suzuki DL650AL02
BSK is offline   Reply With Quote
Old 01-07-2008, 07:44 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,498
Pretty cool, and with some lube you wont risk abraiding the rim surface, and it might be even easier.
Jim
PS I suspect getting those straps tight was a bit of work, right?
JimVonBaden is online now   Reply With Quote
Old 01-07-2008, 07:46 AM   #5
BigX
n00b - Yeah, right
BigX's Avatar
Oddometer: 609
You are a rocket scientist!!!
BigX is offline   Reply With Quote
Old 01-07-2008, 07:55 AM   #6
2wheelsrbest
Oddometer: 264
I've got a couple straps. I think I will try that with one section of tire and see about finishing the job with tire irons--a combined effort.
I also wonder about slipping a strap or two in/under/around a tire that is coming off? That should help, too.
This reminds me I need to make a valve fishing tool as well. Always have a terrible time getting tube's valve to come through hole when installing new tire on KLR.
2wheelsrbest is offline   Reply With Quote
Old 01-07-2008, 01:24 PM   #7
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,255
Absolutely brilliant!!
Reckon it would work with a tubed tire as well if you start with the valve first
Laromo
'91 Vespa PX 200E "Lusso"
'05 KTM 640 ADV "Fatman"
'99 HD FLHRCI "Leviathan"
Laromonster is offline   Reply With Quote
Old 01-07-2008, 01:29 PM   #8
*Gravy*
Jedi Loser
*Gravy*'s Avatar
Oddometer: 3,170
Anybody want to buy a slightly used harbor freight tire changer
Bravo my friend!
I will be trying this. Let me add one question - after this process are you lying in a heap of your own sweat and blood or is it as easy as it looks?
*Gravy* is offline   Reply With Quote
Old 01-07-2008, 01:47 PM   #9
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 5,517
Holy snikeys! That's too cool!
Now, how do you get it off with just the straps?
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-07-2008, 01:52 PM   #10
E900Vadar
The Dark Fant
E900Vadar's Avatar
Oddometer: 248
I second That!
How do you unleash the beasty?
Thnx Cheers
E900Vadar is offline   Reply With Quote
Old 01-07-2008, 03:21 PM   #11
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 2,686
I wonder if tywraps would work as good as the nylon straps?
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 01-07-2008, 03:25 PM   #12
Mr. Magoo
Follow me; I'm lost!
Mr. Magoo's Avatar
Oddometer: 4,287
Mr. Magoo is offline   Reply With Quote
Old 01-07-2008, 03:32 PM   #13
espacef1fan
Oddometer: 582
Man ...I wonder if that would work ok with a tube type tire.
tube/tire changes SUCK!!!!
If you cant tell I just learned how to change dirtbike tires....lol
espacef1fan is offline   Reply With Quote
Old 01-07-2008, 04:13 PM   #14
2wheelsrbest
Oddometer: 264
I have not tried, but I, too, am excited at the prospect of giving this a whirl. I would think that once bead is broken, you may be able to fish straps around a flatted tire and do same in reverse. May not be faster than using tire irons, but could offern an option. Still, which is more of a pain to lug around, 3 tire irons or 8 straps?
Tie wraps could work, too. They would only have to hold the tire pinched, not necessarily pull it closed (you could stand on it, etc.)
I will mention it here, as it falls into the same "crafty/McGuyver/outsidethebox" mindset--Someone here mentioned breaking the bead of a flatted tire loose with another bike's sidestand. Both of these tricks may save me considerable grief in the future.
Old 01-07-2008, 04:22 PM   #15
slide
A nation in despair
Oddometer: 21,030
Absolutely brilliant. If there were some sort of award for tech excellence, I'd nominate you. I just gotta try this one.
slide is online now   Reply With Quote
Times are GMT -7.   It's 01:29 PM.
