Old 06-05-2010, 02:42 PM   #106
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Well thanks HD, but I can't take all the credit. Remember this trick from grade school?
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 06-08-2010, 07:29 AM   #107
BHW
BHW's Avatar
Oddometer: 4,135
Thinking about trying it with large plastic zip ties. Anybody done that yet?
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 06-08-2010, 12:47 PM   #108
BHW
BHW's Avatar
Oddometer: 4,135
Originally Posted by postaldave
love strap idea!
this guy makes changing tire look very easy.
http://www.transworldmotocross.com/m...215721,00.html
He made it look too easy. I just spent an hour in the garage, following his steps...just to remove the Maxxis IT from the rim. No way it was going to slide off as easy as his did!
I'm now dreading the installation of the new tire...and tube.
I quit.
There's no way the new tire is going on the rim with the equipment I'm using, tire spoons. I can get it about 2/3s of the way on the rim, and the last 3rd just spins around the rim. One step forwards, two steps back. I don't see any way of making the strap method work with tubes either.
2003 Aprilia Tuono
BHW screwed with this post 06-08-2010 at 01:39 PM
Old 06-08-2010, 02:14 PM   #109
alphajory
alphajory's Avatar
Oddometer: 589
the rim that he was using is different from what you have on your bike. You have to make sure that the tire is pushed into the centre of the rim on the before you can lever it over the last half. Try using three tire irons one to stop the slippage and two to put the tire on, if you do this the tire should go easily if not your doing something wrong.
let it be warm
alphajory is offline   Reply With Quote
Old 06-08-2010, 03:48 PM   #110
BHW
BHW's Avatar
Oddometer: 4,135
Got the tire back on, but the tube is leaking like the Hindenberg. Back to square one.
2003 Aprilia Tuono
Old 06-08-2010, 10:29 PM   #111
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,214
BHW,
I feel your pain. Best Rest products has some interesting tools for dummies like me, that make the job much easier. The Best Rest tire changing DVD is AWESOME for boobs like me. David Peterson does a great job explaining everything on his DVD. Well worth the $20 for me.
I might be wrong, just ask my X...
ultane is offline   Reply With Quote
Old 06-08-2010, 11:19 PM   #112
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hey, this is not a Best Rest marketing thread! Love ya David! Mean it!
Old 06-09-2010, 07:30 AM   #113
BHW
BHW's Avatar
Oddometer: 4,135
Took the tube back out last night. Patches not holding. Will try and put in a new tube today without tearing it!
Popping one side of the tire off last night went smoothly though. Either I'm getting the hang of it, or my bead is tore all the heck!
2003 Aprilia Tuono
Old 06-10-2010, 09:02 PM   #114
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,214
Sorry Jim,..
I wasn't steeling your thunder. Your 'tooless' tire mounting method absolutely positively ROCKS.. I was just try to help the poor dude.. You guys have heard my struggles a while back. After mastering your technique, purchasing the BeadbreakR, and then the BeadsetR, and Davids outstanding DVD (tire changing for idiots) I know that my tire changing days are going to be a lot easier..
Old 06-11-2010, 04:07 PM   #115
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,306
I feel your pain! The only patches I trusted were the old "vulcanizing" patches you'd clamp on and light up with a match. Cool as hell with the billowing cloud of smoke. Once they were on, they were ON. I understand that they were outlawed by the EPA(!). I never had much luck with the glue type, no matter how much I sand/scrape/clean the tube they never stick very well for me...
I'm very interested in this "tool-less" tire change method, though. Back a whole bunch of posts, wasn't there a mention of a balancing stand? Did I imagine or miss it? (I've missed alot, that's for sure).
HapHazard is offline   Reply With Quote
Old 06-12-2010, 05:20 AM   #116
BHW
BHW's Avatar
Oddometer: 4,135
I ended up getting the patches to hold eventually....more of the rubber cement they came with combined with some gorrilla super glue. But I already slipped a new tube in. Don't trust the patches after the ordeal I had with them.
2003 Aprilia Tuono
Old 06-13-2010, 09:27 AM   #117
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,214
Dyna beads are awesome...
Old 06-16-2010, 04:55 PM   #118
Jeremy FL
Oddometer: 70
This is great. I just got done mounting a set of Anakee 2's on my g650gs. I put the tubes inside the tires and then used heavy duty zip ties like the ones that the cops use for cuffs around the tire, left the valve stem barely protruding from the bead lined it up and slipped them on. It worked great, didnt pinch any tubes.
Jeremy FL is offline   Reply With Quote
Old 06-18-2010, 09:29 AM   #119
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,714
I like this thread......I just had some Michelin PR2s installed on my K1200RS, we could have easily put the tires on by hand just like a bicycle, "Made in Thailand" Michelins...... I guess I don't need to buy a tire machine after all, just a balancer.
Have tools, will travel!
Old 06-21-2010, 07:26 AM   #120
Jman
a.k.a. FUglyK
Jman's Avatar
Oddometer: 900
Agreed, tried this method over the weekend on the rear wheel off my buddy's Vstrom. So slick and easy. Did it with 4 straps, and had to struggle a little, 6 would have been the magic number.
Thanks for sharing this !!
I love scotch. Scotchy, scotch, scotch.
Here it goes down, down into my belly...
Jman is offline   Reply With Quote
Times are GMT -7.   It's 03:05 AM.
