Old 01-15-2008, 08:12 PM   #16
Mukluk25 OP
Hitchhiking to Bingo
Mukluk25's Avatar
Oddometer: 736
Originally Posted by mark1305
(Because I historically have always paid too much for what my heart tells me to buy)
Story of my life brother!!!
I dont know where I am going, but I'm making great time!
Mukluk25 is offline   Reply With Quote
Old 01-15-2008, 08:46 PM   #17
kta
kta's Avatar
Oddometer: 577
Your bike looks a lot like the /7 I picked up for $500. Missing headlight and all!
Cheers on a great find!
Ongoing Ride Report: ..... I'll just skip to the Baja part.
Motorcycle Tours in Guatemala
kta is offline   Reply With Quote
Old 01-15-2008, 09:12 PM   #18
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
Can you tell me what size headlight goes in this bike? 7 or 8 inch? The diameter of the whole assembly is 8 inches, but 7 inches would fit within the assembly. Thanks
Old 01-16-2008, 12:19 AM   #19
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,083
Ya done good! REAL good! I've gotten a few good deals in my time but none as good as that! I got a /5 that was a yard sale left over for $225 - but it's pretty rough and doesn't compare.
The headlight is slightly over 7" (it's a metric size) and you'll have to get the BMW Bosch light. There are three pieces to it: lens, reflector, and the chrome mounting ring. There's also a gasket between the lens and reflector and six or seven clips to hold the reflector/lens into the ring. Expect to pay $50 to $100 for the complete assembly. Those headlight rings can get dented fairly easily, so be sure to check the used ones over well. Nice undented examples aren't easy to find and are expensive from the dealer.
Old 01-16-2008, 08:02 AM   #20
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
Where is the air filter on this dern thing? It's too cold in the garage, so I can only spend a few minutes at a time. Thx
Old 01-16-2008, 08:12 AM   #21
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
On top of the tranny. See where those carb air tubes lead from?
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-16-2008, 10:22 AM   #22
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
Gosh, that's funny! My garage is a refridgerator.
A couple months back I discovered my airbox had been converted to mouse condos!
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 01-16-2008, 11:26 AM   #23
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
So is there a cover or something I need to take off? I guess I need to get a manual. Thx
Old 01-16-2008, 11:51 AM   #24
ricnepalm
Gittin' Along
ricnepalm's Avatar
Oddometer: 85
um, yeah.
why don't you just roll it in the house, next to the pellet stove. just throw down a couple towels on the floor. i'm sure the wife wouldn't mind.
02 DRZ400E - slightly totalled
96 VFR 750
97 BMW F650
78 BMW r60/5
ricnepalm is offline   Reply With Quote
Old 01-16-2008, 12:09 PM   #25
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
Originally Posted by ricnepalm
um, yeah.
What are you laughing at???? Your the one that is going to be helping me convince her that we need to bring it in the house next weekend. Oh yeah, your also going to have to help lift it too
Old 01-16-2008, 05:42 PM   #26
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
OK, am I a dumbass??? Wait, dont answer that. I cannot get the fuel cap off of this thing!!! Lift the handle and the cap will spin 360 degrees. Put the key in and it pretty much does nothing. What gives?
Old 01-16-2008, 05:53 PM   #27
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,011
If no one else chimes in with the correct answer, there is a trick to getting the caps off when the key doesn't engage the little pawl thingies locking the top section to the threaded bottom section. I just can't remember where I read about it.
I'll look through the binders full of tech articles that came with my R80 (which BTW has had the two parts of the cap staked together permanently to eliminate the key function).
Edit: I found the article in said binders - from the Airhead Mailing List. Try this before the next paragraph which is last resort... loop a leather belt or rope through the lift handle and over your neck or shoulders. While pulling up "with more force than you think proper", and turning the cap.
If that doesn't work then.....
Don't rush to do this until better info than mine is posted up, but IIRC one of the last resort methods involves drilling a 1/8" hole through the little BMW emblem cast into the cap and sticking a 1/8 bit or rod in to lock the top and bottom together and unscrew them. If the cap doesn't have the little MBW emblem, then is its an eyeball position somewhere on an imaginary circle concentric with the outer edge of the inner hinge side for the lift handle.
Hopefully it won't come to that.
My cap looks like it may have been drilled on the inside only before the ratcheting mechanism failed, and a crude pin staked in from the inside. I feel no real need to fix the lock on mine, so at most I may clean up the PO's work and put a proper roll pin in place of whatever is stuck in there now.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 screwed with this post 01-16-2008 at 06:07 PM
mark1305 is offline   Reply With Quote
Old 01-16-2008, 07:12 PM   #28
Mukluk25 OP
Mukluk25's Avatar
Oddometer: 736
I'll give it a whirl. Thanks
Old 01-17-2008, 07:14 AM   #29
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,223
Here's some more stuff on the gas caps that might help:
http://www.largiader.com/articles/gascap/
Old 01-17-2008, 07:24 AM   #30
OldBMWMaster
OldBMWMaster's Avatar
Oddometer: 4,185
Nice use of the hitch hauler
I thought I was the only one who overloaded those damned things. gald to see there are others who don't mind loading em up and putting an airhead on it.
So far I have had no problems hauling this way.
I am looking into taking the 39.95 front wheel chock that Harbor Freight sold. It is supposed to be bolted to the floor of a trailer or truck to hold the bike in place while transporting. I am going to try and fit it to a reciever and use it to tow my airhead by jsut sliding it into the receiver on my truck. It would beat trying to load it in the truck whenever I had to take it somewhere.
OldBMWMaster is offline   Reply With Quote
Times are GMT -7.   It's 02:14 AM.
