11-10-2010, 12:05 PM
#151 | |
Oddometer: 11
This time I'll replace the Meca tower and fairing with a standard KTM/Husaberg triple clamp mounted bracket. LESS IS ABSOLUTELY MORE! |
11-29-2010, 07:10 AM
#152 | |
Team f5ool
Oddometer: 13,992
Rally navigation towers...
Quote: SafariBerg; Yes in 2009 Safari we went with a smallish triple clamp mounted fairing and nav gear set up. While the riders Annie, David Schwarz & Andrew Coaker said it was ok they all felt it made the steering noticeably heavier ![]() For 2010 Safari I asked the riders, Annie & David again as well as Ze Helio for their preferred set up, options being
![]() This worked well, BUT again at the end of the event all 3 riders commented that they still felt it on the bars compared to the Dakar style stem mounted fairings they had all used a lot before. So for 2011 Safari it will be a hybrid, reduced Mecasystem fairing mount bracket off the head stem with enduro light & mask plus nav gear = light simple cockpit to KISS and mounted off the frame not the steering So far we have tried the 2 set ups above and the more traditional Dakar style, this is the Mecasystem nav mounts & fairing from their KTM530 kit which pretty much bolts on. ![]() So I hink the hybrid will be a best of both worlds hopefully
Quote: Originally Posted by zenjen "It's one of those nuts and uncles deals..." ![]() |
11-29-2010, 07:12 AM
#153 |
Team f5ool
Oddometer: 13,992
Quote: Originally Posted by zenjen "It's one of those nuts and uncles deals..." ![]() troy safari carpente screwed with this post 11-29-2010 at 07:33 AM |
12-01-2010, 11:39 AM
#154 |
Mookish Mook
Oddometer: 4,287
SafariBerg, Troy
How have these rear tanks held up in so far as maintaining their shape in the heat/sun? Any issues with them changing shape/growing/becoming difficult to mount again? It seems to be a quite frequent complaint with various sorts of Aqualine tanks. Just wondering what the experience has been so far with these rear tanks. |
12-01-2010, 10:21 PM
#155 | |
Team f5ool
Oddometer: 13,992
Not an excuse; but more an explanation for this; could be the extremely large volume of the tanks (in relation to motorcycle application) coupled with the fact that they are mounted above the engine, and many been used in very hot desert climate (air temps of 35 degree C +). The combination of wieght, heat and fuel expansion could account perhaps for the excessive "stretch factor". But to be honest... I've seen similar happen with other brand large capacity aftermarket plastic tanks in desert temperatures as well... as far back as the 80's and 90's. I believe that some changes to the early production runs was made to address some of theses issues... what the result (improvement) has been I am not sure. With regards to the REAR tanks you enquire; Safari/Aqualine make rear subframe tanks for the EXC, WRF, CRF and now FE Husa bikes, similar in principle to those pictured above. All are around the 8 to 10 liter mark there abouts and mount away from any direct heat source (an aluminium/carbon slip on sliencer generates nowhere near the heat of an engine). As such there is nowhere near the weight/heat factors placed on these tanks and as yet; I am not aware of any major expansion/fitment problems... but SafariBerg (who has run them on his team bikes at the 2009 and 2010 Australian Safari's) will be able to give some more detail.
12-01-2010, 10:44 PM
#156 | ||
Oz Safari Addict
Oddometer: 2,793
2013 Husaberg FE501 ![]() 2012 Arctic Cat Wildcat 1000 Rallye
12-02-2010, 12:33 AM
#157 |
Oddometer: 356
Some pics of Ronnie Bodingers and Thomas Berglunds lovely Dakar Husabergs. We have helped them out by supplying our navigation brackets and mufflers for these bikes. The fairings are not yet done, but they almost look better like this..
12-02-2010, 01:02 AM
#158 | |
Oz Safari Addict
Oddometer: 2,793
is there 2 fans ? also I can see what appear to be 2 oil coolers ? a 690 style one and a cylinder style behind it ? how much oil does the system now hold ? is it the stock headlight ? I can see the bikes are running a 320mm front disc, we ran a 310mm disc off the KTM 690R on Ze Helio's bike and he found it a very worth while upgrade, so the 320mm should do the trick only the stock rear wheel ? no cush hub ? stock 22mm offset clamps ?
12-02-2010, 01:19 AM
#159 | |
Mookish Mook
Oddometer: 4,287
However, more recently I was reading this : http://www.advrider.com/forums/showp...2&postcount=55 and the same subject cropped up. |
12-02-2010, 01:43 AM
#160 | |
Team f5ool
Oddometer: 13,992
12-02-2010, 12:22 PM
#161 |
Mookish Mook
Oddometer: 4,287
12-02-2010, 07:07 PM
#162 | |
Oz Safari Addict
Oddometer: 2,793
12-03-2010, 04:10 AM
#163 | |
Oddometer: 356
It's an oil cooler and an extra oil filter underneath the nav bracket which also uses the stock light. Can't tell you how much extra oil I'm afraid. |
12-03-2010, 05:26 AM
#164 | |
Safari Scramble!!!!!
Oddometer: 3,197
I think a lot of those cases were where people pulled the tanks off for a fair amount of time and the tanks had a chance to warm up and distort. It could have also been a certain batch of tanks. I've had the tanks off my old adventure for months at a time during the winter and had no realignment issues. But the tanks were resting in such a way as to not be loaded oddly and it was cold and out of the sunlight.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
12-15-2010, 10:43 PM
#165 |
Oddometer: 356
A few pics of the "finished" bike. Wonderfully nimble and purposeful!
