Old 01-14-2008, 05:43 PM   #1
P-nut OP
Oddometer: 75
DR650 Shock Rebuild
For those of you that are interested a friend has been developing a shock for the DR650. He is using the body and the spring of the stock shock. Everything else is new. It has compression, rebound, and ride height adjustments. I rode his bike last week and it was a huge improvement. I saw the biggest difference on washboards on gravel roads. I just removed my shock and we are going to rebuild it tomorrow night. He already has a completely new shock for the KLR and some Ducatis. We are going to take pictures of the whole thing. I may need some help posting them.
1996 DR 650
2006 S2R 1000
P-nut is offline   Reply With Quote
Old 01-14-2008, 05:49 PM   #2
neepuk
Such a drag...
neepuk's Avatar
Oddometer: 1,633
Sounds cool. How much do you weigh? How are you using the stock spring with any success? Just seem to me that once a soft spring, always a soft spring... Try your new shock with a new spring too, unless you're very light.
Love to see those pix when you take them.
neepuk is offline   Reply With Quote
Old 01-14-2008, 05:51 PM   #3
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,737
I'm staying tuned to this one.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-14-2008, 06:50 PM   #4
P-nut OP
Oddometer: 75
I weigh 175 lbs and the stock spring rate ( .470 kg/mm) is a little more than what is recommended (0.455 kg/mm)for my weight. I got these numbers from Race Tech's website. Keep in mind, I have already ridden a DR with this shock (using the stock spring). He was previously using the gold valve kit from Race Tech.
1996 DR 650
2006 S2R 1000
Old 01-15-2008, 01:32 AM   #5
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Are you sure that is right ?
They sound like the fork spring rates
BurnieM is offline   Reply With Quote
Old 01-15-2008, 02:10 AM   #6
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
The stock spring rate is 6.5kg/mm for the rear shock.
Most of us in the 180lb range are using 7.6kg/mm rear.
0.47kg/mm is the recommended front spring rate for 180 odd lbs.
NordieBoy is offline   Reply With Quote
Old 01-15-2008, 03:47 AM   #7
P-nut OP
Oddometer: 75
Your absolutely right. I checked again. 5.4 kg/mm is the measured stock and 5.32 kg/mm is the recommended spring.
1996 DR 650
2006 S2R 1000
Old 01-15-2008, 03:50 AM   #8
P-nut OP
Oddometer: 75
Can you direct me to where I can find these numbers. I've been looking at race tech's website.
http://www.racetech.com/evalving/eng...ngname=english
1996 DR 650
2006 S2R 1000
P-nut screwed with this post 01-15-2008 at 03:59 AM
Old 01-15-2008, 11:34 AM   #9
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
This was my e-mail from Jesse and when I went to the RaceTech site it came up with the same numbers.
I also wanted to see what weight you had to be to have them recommend the stock spring weight and it came out at 45kg
They must have changed the site as it now it comes up with your numbers above - Weird...
:EDIT: If you enter a 2001 bike it says it can't do shock springs and if you enter a 2000 year it comes up with my numbers.
Looks like they have different numbers in their database for different years but the actual springs on the bikes didn't change - Weirder and weirder.
Both Jesse Kientz and Norm Kouba recommended the same .47 fork and 7.6 shock springs to me.
NordieBoy screwed with this post 01-15-2008 at 11:47 AM
Old 01-15-2008, 11:54 AM   #10
neepuk
Such a drag...
neepuk's Avatar
Oddometer: 1,633
I'm not trying to rain on your parade in any way. I'm excited to see how this whole thing turns out and I support your idea fully. That said..... You NEED to change the spring. You're gonna valve this thing soooo stiff trying to compensate for lack of spring, then when you get the right spring you'll be starting all over again.....
Hell, I may not know what I'm talking about but I just don't see it working very well with the stocker.
Old 01-15-2008, 05:48 PM   #11
P-nut OP
Oddometer: 75
This is by no means my idea, I'm just the guinea pig lucky enough to try it out. I'll take the spring into consideration. The shock will be in and out of the bike a few more times in the next couple of weeks. We finished assembling the shock tonight. I took alot of pictures and I will try and post them as soon as possible. The plan is to ride it this weekend, then remove it again and get the body hard anodized. While it's out we will make anymore changes or adjustments if needed.
1996 DR 650
2006 S2R 1000
Old 01-15-2008, 05:53 PM   #12
radguzzi
The Journey is the Reward
radguzzi's Avatar
Oddometer: 5,823
Ditto...
________________________
Guzzis and Others...
Member: AMA - USCRA - MGNOC
radguzzi is offline   Reply With Quote
Old 01-15-2008, 08:31 PM   #13
DRinda505
I'm right behind you.
DRinda505's Avatar
Oddometer: 407
05 DR650....Yea I know.... but it was cheap, Couldn't afford the Trail 90 I wanted.
DRinda505 is offline   Reply With Quote
Old 01-15-2008, 09:36 PM   #14
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 666
It's less $$ than a poor condition Trail 90
I want one of those too1
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 01-16-2008, 12:06 AM   #15
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
i'm interested but also thing your spring rate is wrong.
Alaska
Butler Maps website:
http://www.butlermaps.com
Times are GMT -7.   It's 10:14 PM.
