Old 01-15-2008, 12:13 PM   #1
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,199
My Garage Of Doom.
"Abandon hope, all bikes that enter here..."
Merged Thread Alert:
R100GSPD HPN-esque build!
R90/6 psuedo-restoration!
Buell S2 Thunderbolt restoration!
Buell S3 Thunderbolt touring prep!
Buell S1 Lightning Hooligan Redux!
It's all here under one roof... and more.
Cool stuff happens to a DR650, KLR 650, 640Adv, and Buell Ulysses, too.
But we can't talk about that here.
Okay, I wasn't going to post anything here about it but I'm thinking you guys might prod me to keep going and get it finished before spring arrives.
Basically I'm planning to do a complete motor overhaul on the bike, top and bottom ends. It's been burning oil like crazy since an incident last summer that saw it wallow and drown in a deep mud hole. I'm doing the whole motor because I'm not convinced the damage was limited to the top end. Plus, the bike had a history of a bad oil pump early in it's life during the PO's watch and only the big ends and oil pump were replaced (I've never trusted the bottom end), so I'm doing the whole enchilada.
I've got a good '77 R100S bottom end laying around that I was hoping to use to form the basis of the rebuild/replacement engine. (Anyone know why the '92 timing case shouldn't bolt right up to the '77 block?) This will of course, permit use of the '92's ignition trigger and the post '81-type Andrews cam I've got laying around saying "use me in a cool bike".
Main bearings in the block and main and big end journals on the '77 crank are in top shape and since I've already got the crank out of the block I'll probably have it dynamically balanced. If the '77 block presents "issues" I'll just replace the '92's main brgns and use it.
I've been using this '92 with a modded high compression 1050cc '77 RS top end for the last couple of years and it works quite nicely in the mid range with the stock '92 cam. I'm likely going to stick with that top end combination along with the addition of the Andrews cam which is a high lift short duration type (I'll dig up the numbers as I'm able, unless one of you have them handy?) which should further increase the midrange and top end urge.
Carburation is handled by a pair of modded '77 vintage 40mm Bings. No need to change those as they work well to provide good power, reliable service and reasonable economy.
The plan is to continue using this bike as before for all around riding chores from commuting to quiet evenings in the country to weekend sprints with the sporty-boys to extended camping/touring adventures. ie: It has to remain reliable and maintain it's useful extended fuel range. fwiw, since the high cr 1050cc top end transplant it's gently ridden range went from 550kms to 700kms from it's 35 liter tank. A 25% improvement in economy and power. I was pleased with that result.
I'll post pics of the disassmbly as it begins (in a good friend's heated garage!) in a few days.
D'I miss anything?
Lornce screwed with this post 08-19-2014 at 08:37 AM
Old 01-15-2008, 12:54 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
well, I'm in.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 01-15-2008, 01:03 PM   #3
clevishook
stevedore
clevishook's Avatar
Oddometer: 1,644
I'll be watching the progress of both you and stagehand. Great projects.
clevishook is offline   Reply With Quote
Old 01-15-2008, 01:35 PM   #4
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 6,002
I'd send the trans off for bearing check, shimming, circlip mod and nylon shifter roller replacement with K-Bike steel one.
"If you don't know where you're going, any road will get you there." -Henry Foster
Eurobiker is offline   Reply With Quote
Old 01-15-2008, 01:51 PM   #5
929bladerunner
929bladerunner's Avatar
Oddometer: 37
Nice one Lornce, I'm on the verge of buying an old GS that I will want to strip/re-build (mainly cosmetic). I'll br wathcing and learning.
929bladerunner is offline   Reply With Quote
Old 01-15-2008, 02:59 PM   #6
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
you said overhaul the top end- gonna go all the way?
how many miles on this thing, again?
Are you gonna touch anything aft of the tranny? (scope creep )
Old 01-15-2008, 03:17 PM   #7
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,199
Yes, going all the way: Top and bottom end. Bike has 240k kms and was running just swell before the mud bog debacle. Though I always suspected the mains were a bit wonky (see earlier note re. oil pump).
I *might* pull the tranny apart and have a look at bearing clearances. We'll see how the time goes before spring arrives (mid to late March, weather permitting).
Cosmetics? Maybe I'll spread some red tremclad on the crashbars. They're now almost entirely orange with rust. Plus I'm getting a new-to-me-like-new Corbin. The old one gives me monkey butt when it rains.
Old 01-15-2008, 03:25 PM   #8
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Ya Lornce! Another rebuild thread. That restore/rebuild section of advrider is getting closer everyday. I can almost taste it.
Welcome back from your long x-country ride on the /5. I enjoyed the thread.
datchew is offline   Reply With Quote
Old 01-15-2008, 06:47 PM   #9
moosehead
moosehead's Avatar
Location: south of the checkerboard....Bruce Penninsula
Oddometer: 276
Don't forget a new and improved flag holder....
casa roberto awaits....
moosehead is offline   Reply With Quote
Old 01-15-2008, 07:07 PM   #10
kahoon
who's yer daddy??
kahoon's Avatar
Oddometer: 2,392
Originally Posted by Lornce
[snip]
What about playing in the dirt with your poser buddies around Hockley, and the '08 P2D
Look forward to watching the rebuild I've been thoroughly enjoying of the 9fiddy rebuilds thread in the OC.
kahoon is offline   Reply With Quote
Old 01-15-2008, 07:09 PM   #11
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,767
Hey that bike looks familiar, and properly dirty. Is that a stock screen or did you get fooled by Gustafsson like I did?, Cant wait to hear how it works out, I plan to do push rod seals and rings this winter, much easier task.
'twas ever thus
dfc is offline   Reply With Quote
Old 01-15-2008, 07:49 PM   #12
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,199
Yah know Moosehead, the flag would still be flying if I hadn't broken it while packing up my tent near Winnipeg just a few days from home. Even after that your duct tape mod held the base in place for nearly 11k miles! Red Green would be proud of you. Keep your stick on the ice!
Kahoon, straffing runs around Hockley Valley sideroads are high on the operational "to do" list once things are back together. I'll look forward to them. Though I might go lookin for a nice XR650R for the paris to Dacre!
Not sure about the screen, dfc, it was in the spare parts bag when I got the bike. It was wearing a big touring screen when I first brought it home. Anyone want that? It's still sitting in my basement...
Old 01-15-2008, 08:09 PM   #13
DucatiPete
In denial
DucatiPete's Avatar
Oddometer: 162
how about a wash?
ya gonna bathe her before you operate?
hehe
luv these rennos...
pete
2002 1150GSA (non-ABS) - 21st C Highway Adventures
1982 R100RS - new rolling project
1980 R80G/S - gearbox still needs attention + & etc
1973 R75/5 - Black Beauty - love @ 1st ride
1972 Ducati Sport - must look at the 'ol girl again soon
DucatiPete is offline   Reply With Quote
Old 01-16-2008, 12:51 PM   #14
gonzomup
ChainGang Recidivist
gonzomup's Avatar
Oddometer: 744
Save a seat for me, guys!
I'm cutting my teeth on a "refurb" of my 1150GS (link in my sig' line), but I'm waiting for the day I can do a refurb/restore on an R80.
Bohdan
Gonzomup. Chain-gang recidivist in the making.
In short, don't be put off by F800GS reliability reports on the net, or any reliability reports on the net for that matter - a few posts get cross-referenced and before you know it, your electric toaster will kill us all on 31/12/99...
The plural of "anecdote" is not "data."
gonzomup is offline   Reply With Quote
Old 01-24-2008, 01:55 PM   #15
kahoon
who's yer daddy??
kahoon's Avatar
Oddometer: 2,392
is the show starting soon??
Times are GMT -7.   It's 05:03 AM.
