Old 10-05-2014, 08:13 PM   #1
oldbmw OP
havehandlebarswillrideit
oldbmw's Avatar
Oddometer: 197
Bing rubber tipped float needle?
I was wondering if there is an aftermarket rubber tipped Bing replacement float needle that would seal better than the OEM metal float needle. I rebuild airhead carbs as needed and sometimes the new needles I install still leak and not seat. I have new seats but have not mustered enough courage to try to remove and replace the brass seats yet.
Thanks for any ideas.
Oldbmw
oldbmw is offline   Reply With Quote
Old 10-05-2014, 08:31 PM   #2
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,338
IIRC, the last set I bought were viton tipped from Bing.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 10-05-2014, 08:31 PM   #3
ME 109
ME 109's Avatar
Oddometer: 2,575
Seats don't fail often, but if new meedles won't fix the leak, then a new seat is in order.
Got to tap the seat with a 8mm tap in order to pull the seat out.
Pulling the seat can then be done with a slide hammer or a screw extractor, as someone here uses.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 10-05-2014, 09:08 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
The best tutorial about replacing the needle seats on our Bing carbs was done by inmate _cy_. It is post #892 in the tips and tricks thread. http://www.advrider.com/forums/showt...169507&page=60
There is supposed to be a rubber tipped needle from Amal carbs that fits. I think it was Amal?
---Albert Einstein
Old 10-05-2014, 09:15 PM   #5
oldbmw OP
oldbmw's Avatar
Oddometer: 197
Thanks for the info.
Old 10-05-2014, 10:03 PM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
I found the info about the Amal carb needles. Part # 622/197 for a mono concentric Amal carb found on certain Triumph BSA and Norton bikes.
I haven't tried these yet but they look like a good fit. I found a pair on Ebay for $19.00
---Albert Einstein
Old 10-05-2014, 10:10 PM   #7
robtg
Oddometer: 649
I had meedles once, that was a long time ago.
robtg is offline   Reply With Quote
Old 10-05-2014, 10:34 PM   #8
ME 109
ME 109's Avatar
Oddometer: 2,575
German meedles? They'll work.
Old 10-05-2014, 10:48 PM   #9
robtg
Oddometer: 649
I feel much better now knowing that, thank you.
Old 10-06-2014, 05:40 AM   #10
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,484
German meedles?
Arrrgghhh! Tooo early.
--Bill
'73 R60/5 Toaster
Old 10-06-2014, 07:00 AM   #11
David4
Oddometer: 171
FWIW, new rubber tipped needles alone did halt the leaks from my /2 era Bings.
1966 Triumph TR6R Trophy
1967 Triumph T120R Bonneville
1968 BMW R60/US
1969 Triumph T100R Daytona
David4 is offline   Reply With Quote
Old 10-06-2014, 07:22 AM   #12
oldbmw OP
oldbmw's Avatar
Oddometer: 197
I bought a pair of the Amal Viton tipped float needles and will give it a try.
Old 10-06-2014, 08:04 AM   #13
silverhead
silverhead's Avatar
Oddometer: 522
I've always had success cleaning up brass needle seats using toothpaste applied to the end of a Q-Tip chucked up in a battery powered drill.
Run toothpaste or some sort of mild abrasive like liquid clay bar in there in a circular motion and it will polish up the brass ever so slightly. I've never seen a seat that was worn or had damage. If someone jabbed a steel pick in there, all bets are off :)
silverhead is offline   Reply With Quote
Old 10-06-2014, 09:11 AM   #14
oldbmw OP
oldbmw's Avatar
Oddometer: 197
Good tip!
Old 10-06-2014, 11:21 AM   #15
Bill Harris
Oddometer: 7,484
Toothpaste "polish/abrasive" is good. A slightly more abrasive agent is Bon-Ami cleanser-- contains fine feldspar crystals, which is hard enough to cut, but still very soft. For example, use it with an old (but not grooved) needle to "lap" the seat down if you have pitting. Oderwise, replace the seat...
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 11:11 PM.
