Old 04-03-2011, 09:29 AM   #361
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
if the u-joint caps are different OD's you can source them from a parts store, I had to do that to my jeep cause it has a stock driveshaft/transfer case with a Ford rear end so the back u-joint has two different size caps
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 04-03-2011, 09:52 AM   #362
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Good to know, Alex. Thanks. But I *think* they're the same.
Famous last words.
Old 04-03-2011, 10:01 AM   #363
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,982
There's always this option:
Originally Posted by nowhereman View Post
See this pic?
On http://www.bmwboxersupplies.com , they list it as an 'Adapter 2v gearbox / 11xx driveshaft' - I haven't asked them yet, but does this mean you could install an R1150GS shaft into an airhead paralever unit? Any reason why you'd want to do this, other than the oilhead shafts seem to be a bit cheaper on ebay? Are the oilhead shafts better / stronger / faster or something? Solution in search of a problem? Huh?
Is this something intended for running the whole R11xx rear end ala an HPN bike?
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-03-2011, 10:13 AM   #364
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Hadn't seen that before, Solo. That'd be pretty handy.
But at 285Euros I'm inclined to stick to my plan.
Old 04-03-2011, 01:43 PM   #365
igormortis
igormortis's Avatar
Oddometer: 1,373
So, itll be the 1150 'arm then? Im starting to think along similar lines...
Id like to keep the bike close to the original geometry and seat height. Looks like the 1150 item is only a touch longer than the original paralever.
Whats your plan re. suspension height?
igormortis is offline   Reply With Quote
Old 04-03-2011, 02:05 PM   #366
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Originally Posted by igormortis View Post
So, it’ll be the 1150 'arm then? I’m starting to think along similar lines...
I’d like to keep the bike close to the original geometry and seat height. Looks like the 1150 item is only a touch longer than the original paralever.
What’s your plan re. suspension height?
Once I see the forks (they're still in transit) I'll have a better idea of exactly what's required, but I'll guess the finished bike might be 2" - 3" taller than stock.
Yes, it's an 1150 swingarm and final drive.
If you're not looking to increase your ride height or suspension travel, why are you considering this modification? Are you simply looking for more final drive ratio options?
Old 04-03-2011, 03:51 PM   #367
igormortis
igormortis's Avatar
Oddometer: 1,373
Good question - the ultimate goal is a better braked, more durable rear than what I have with the current paralever. A choice of further rear-end ratios could be a welcome bonus, along with with a wider rear wheel.
The other path for me would be the rebuildable driveshaft for the original 'lever (Or a brand new OE item for that matter) and a disc conversion a-la Phreaky Phil of this forum.
The bike is being used 2up and loaded over varied terrain and will be ridden cross-continent next year.
Old 04-03-2011, 04:07 PM   #368
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,982
Don't forget to take off 19% for VAT we don't pay...
R65LazaruS
Old 04-03-2011, 07:58 PM   #369
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 4,372
Hmmmm....this looks interesting Lornce...wish I had stopped by with Gary today...Does the PD look that bad?
ScottDill is offline   Reply With Quote
Old 04-04-2011, 01:51 AM   #370
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Worse than bad. I was stunned to see the amount of rust that's bloomed over the winter. No worries, one more reason to do this frame up and right.
It's going to be a long process.
Gary didn't make it. Apparently the rain sent him running for home. Look forward to catching up next weekend on the pre-run.
Old 04-04-2011, 04:27 AM   #371
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 592
Yeah, they do that... I've got a NX650 in a similar predicament. Parked it in January when I got the GS going again, and kinda forgot about it what with planning a NZ trip and somewhere in there finding a GF. So I got kinda distracted. :-)
Looked at it again in june or something, and, er. Um. Errr. Yeah. Engine hanger plates half as thick as they were with the rest being on the floor, that kind of thing.
I think the old 2 valves are relatively hardy bikes when it comes to this kind of abuse, though I'm curious what the extent of the damage is. (Aka, where's the pics, man!)
Anyway. Should be a good thread, this.
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 04-04-2011, 07:38 AM   #372
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Looks to be surface rust on all the spots of the frame where the paint's worn off, footpegs, engine through bolts & nuts etc. Anywhere there's bare metal. I'm too ashamed to photograph it. Will have to do some "before" pics at some point, but I'm just not ready.
Old 04-04-2011, 08:07 AM   #373
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 4,372
Yeah - I only just got home before the wet sloppy snow started
Old 04-04-2011, 09:02 AM   #374
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Long term's calling for 10C on Saturday's pre-run. Whooot!
I'll be on the DR with fresh 606's.
Old 04-04-2011, 04:51 PM   #375
97oilhead
97oilhead's Avatar
Oddometer: 189
The short term weather forecasts around here are changing daily. Tomorrow and Thursday were supposed to be half decent yesterday. Now more rain and snow!
Hope they are right about Saturday though.
'05 R1200RT
'00 R1100S
'04 R1200C Montauk
'95 R100R Classic
97oilhead is offline   Reply With Quote
Times are GMT -7.   It's 08:43 AM.
