Old 10-20-2010, 05:39 PM   #406
madmaximum
She said we're all idiots
Oddometer: 3,955
Originally Posted by PLRider
I was wondering if there is a way to connect this liner to 12v socket.
I have a fuse box and 1 unused sae connector. I would like to connect the liner to it. What i would have to do or if it is possible to do it?
Im planning to get the liner therefore my questions.
Where do you plug 3 (red, black, white) connectors?
thx
That one is for the gloves.
madmaximum is offline   Reply With Quote
Old 10-20-2010, 06:06 PM   #407
PLRider
PLRider's Avatar
Oddometer: 86
Would something like that work:
http://www.warmnsafe.com/index.php?m...roducts_id=209
Originally Posted by HaChayalBoded
It comes with a battery cable, if you however want to use your SAE connector you can buy a converter that converts the SAE connector to coaxial.
PLRider is offline   Reply With Quote
Old 10-21-2010, 07:48 AM   #408
PLRider
PLRider's Avatar
Oddometer: 86
Anyone?
Old 10-21-2010, 08:30 AM   #409
Charleetho
Mr. Zoom Zoom
Charleetho's Avatar
Oddometer: 2,048
I use one of those to connect my battery tender pigtail to my coaxial connector.
I use the heattroller control as well since 3 TM controllers crapped out on me.
Charlie Thompson
Littleton, CO Learn to ride Mile High Harley-Davidson Riding Academy
Charleetho is offline   Reply With Quote
Old 10-21-2010, 09:03 AM   #410
PLRider
PLRider's Avatar
Oddometer: 86
Is that possible to connect that liner with Coax to SAE and then SAE to Cig lighter? or straight Coax to Cig Lighter?
Old 10-21-2010, 09:06 AM   #411
madmaximum
Oddometer: 3,955
You're going to need a controller of some sort in between the battery and the liner.
Old 10-21-2010, 09:07 AM   #412
Charleetho
Mr. Zoom Zoom
Charleetho's Avatar
Oddometer: 2,048
Cigarette lighter sockets are loose and will vibrate apart on a bike. I go from a BMW socket to coaxial on one bike and Battery SAE to Coaxial on the other.
I think you should be able to do what your trying, but be sure not to reverse polarity.
Charlie Thompson
Old 10-29-2010, 07:21 PM   #413
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Yep, that's it.
HaChayalBoded is offline   Reply With Quote
Old 01-14-2011, 07:03 PM   #414
eeore39648
eeore39648's Avatar
Oddometer: 2,019
Which bikes are you guys using the heated liner on?
I pick my jacket up in the morning. I ride a XR650L.
Have any of you had issue's, when used with this bike?
I plan to start the bike, plug in, then turn on. Any objections?
At the end of a ride, I plan to turn off, unplug, turn off bike. Any objections?
Honda CB500X
eeore39648 is offline   Reply With Quote
Old 01-14-2011, 07:14 PM   #415
Jud
Jud's Avatar
Oddometer: 2,541
Your XR650L makes around 185-190 watts at max, lower rpm less. I have a XR650L too and it also has grip heaters. If I run both the vest {vest uses around 20watts less} and the grips on high it will eventually run the battery down. I have actually drawn the battery down to the point where it would not start the bike on my previous DR650 {which has a little bit more current to draw from}. It had heated grips, I was running a vest and it was a night ride so I was using brights alot and I was constantly hitting brakes and lighting up that brake light. After about 4-5hrs of that type riding with the grips and vest on high I shut it off and it didn't have enough to crank the engine.
Long story short, you can't run both the grips and the vest on high. Even if you are not running grips, you have a jacket that uses slightly more current than my vest so I wouldn't run it on high all the time unless you don't mind experimenting on that issue.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 01-14-2011, 07:40 PM   #416
barko1
barko1
barko1's Avatar
Oddometer: 3,405
Might want to add a switch to allow you to turn off the headlight. I wired my DR so I could run with out the lights but I could easily switch to high beam with the stock switch.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 01-14-2011, 08:47 PM   #417
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
Swap all your lights to LED and swap the headlight to HID. HID and LED bulbs are pretty cheap nowadays. You can swap everything for under $100. That should get you an extra 55, maybe 65 watts. Then you can get the 65w heated liner.
Hell, also change the front blinker\running lights to only be blinkers. Should save ya even more.
Old 01-14-2011, 09:05 PM   #418
Jud
Jud's Avatar
Oddometer: 2,541
I'm looking to do exactly that shortly. Gonna run a couple of LED lights as head lights, spot pointed down and right for low beam and an elliptical or whatever they recommend for high. Each one draws 10watts and puts out 900 lumens. Both together will draw 30watts less than just the stock low beam and will put out a heck of alot more than the stock high beam. LEDs are really getting with the program.
Also looking at a V45 stator swap for around 330watts vs the stock 185-190watt but I will wait to see how all the LED stuff works first. I do love my heated gear and would love to be able to run gloves, vest and chaps. We'll see.
Blue Skies Coming
Old 01-14-2011, 09:16 PM   #419
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
What lights did you find that are 10w and put out 900 lumens? Sounds like a fairy tale.
Old 01-14-2011, 09:25 PM   #420
Jud
Jud's Avatar
Oddometer: 2,541
In some spots they are listed as 900 lumens and in some spots 800 lumens.
http://www.visionxusa.com/LED-Solsti..._88/index.html
In our vender's section there is a inmate that also builds 10w LEDs. His put out 450 lumens and a local guy tried them out and said they were plenty bright and were cheaper than those I linked too. Matter of fact, I might buy one of his 450 lumen spots to use as my low beam simply because the 900 lumen might be too bright.
Seems fairy tales do come true!
Blue Skies Coming
Jud screwed with this post 01-14-2011 at 09:33 PM
Times are GMT -7.   It's 02:21 AM.
