09-17-2009, 04:13 PM
#1531 |
soreass
Oddometer: 57
Just got a cop to come by and do the inspection so now im street legal. i passed with a bicycle bell as a horn and non dot tires thanks to some 150 grit and a razor blade. I love Michigan
I did find my horn signal wire and went out and got a 12v horn. problem is all my electrical is putting out 7v so you can hardley hear the horn. it doesnt matter any more now that i have my inspection but i would be nice to know how to pump that up to 12v so when i get my trail tech i can wire up to 12v if need be.
2003 YZ125 1996 XR400R 1974 Yamaha TX500 cafe/moto gp style project |
09-17-2009, 10:15 PM
#1532 | |
Oddometer: 83
I am shopping for a good used XR400. How can you check the swingarm bolt? Is it something that can be check quickly while inspecting bike, or does it require some disassembly? Anything else to look for when looking at a used bike???? Thanks very much for the information. Pat. Oh, If you are on the Olympic Peninsula or in the Seattle area and have a good use XR400 for sale I'm buying. |
09-18-2009, 05:00 AM
#1533 | |
Talking Dog
Oddometer: 440
Self bump but does anyone have clutch info?
Talk less ride more. |
09-19-2009, 04:54 AM
#1534 |
Ulysses
Oddometer: 1,208
Starting the XR
I'm only 5'6" so starting the girl can be hard work but here is we go.
Turn fuel on, turn choke on full, adjust the idle speed screw 1 turn, bring her up to TDC, pull in decompression lever so engine is just past TDC, Give it a good kick....don't touch the throttle & knock the choke back to 1st step for around a minute & then turn it off altogether. I have a piece of fuel line on the idle screw to make it easier, reduce the idle after 5 to 10 minutes. Only problem I have is my right leg, I broke it 2 years ago & have a pin, hurts like hell when it comes up on compression. I start it cold with my left leg, once warm it's ok with my right. Yes I did break it on the XR ![]()
Triumph Scrambler Blue & White (for fun) Triumph Thruxton Red (for the twisties) Honda XR400R Red (for the dirt) for sale Yamaha XT250s Sliver & white (for the wife) for sale Yamaha TT-R250 for some dirty fun TerryK screwed with this post 09-19-2009 at 05:06 AM |
09-19-2009, 11:10 AM
#1535 | |
GPoET&P
Oddometer: 3,749
To check the swingarm bolt, you have to unscrew the swingarm nut and hit the bolt out with a hammer. Not something a seller is likely to let you do. I've checked five different swingarm bolts, and none were very hard to get out. I wouldn't worry about it. Just have a big hammer and drift available when you go to work on it. General inspection is the same as any other bike. On a stand: check the wheel, steering head and rear suspension bearings for slop or notchyness. Spin the wheels to see if they're not wonky. Make sure control cables operate smoothly. Brakes: check the feel, and look at the rotors, calipers and pads. Check the suspension action. It should be smooth and damped. Fluid leaks: engine, oil lines, forks, shock, brakes. Air filter- take it out and check for gunk in the carb inlet. Electrics. Tires, brake pads, chain, sprockets: They're consumables. Just make sure they're good enough for the test ride and/or ride home. Don't forget tire pressure. Test ride. Does everything feel about right? Do you like the bike? Check for fluid leaks again after the test ride. Engine oil. Dirty is ok, sparkly isn't. The level should be right. Double check anything aftermarket for proper installation. Try to get take-off parts with the bike (especially the carb). Paperwork. Get a bill of sale and a clear title, registration and whatever else WA wants. Oh, and no, mine's not for sale. |
09-19-2009, 04:12 PM
#1536 | |
Butler Maps
Oddometer: 14,431
most importantly above everything else!
if it has a skid plate, remove it and look for a rusted through frame down there. Quote:
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
09-19-2009, 08:40 PM
#1537 |
Oddometer: 83
Luke and eakins, thanks for the info and tips.
If all goes well I will be looking at two or three this upcoming week. Thanks again. |
09-20-2009, 07:52 AM
#1538 | |
soreass
Oddometer: 57
09-20-2009, 03:48 PM
#1539 |
Oddometer: 83
I have another question about used 400's for you XR gurus.
Should the front sprocket be tight on the shaft coming out of the transmission? I looked at a bike last week, the front sprocket wiggled on the shaft, there was also a rusty residue at the area where the sprocket interfaced with the shaft. To me, that did not seem correct. How should the sprocket fit upon the shaft? Thanks for your time. Pat. |
09-20-2009, 04:44 PM
#1540 | |
Oddometer: 143
YMMV
'03 XR400R |
09-20-2009, 05:53 PM
#1541 | |
GPoET&P
Oddometer: 3,749
The sprocket should twist on the shaft, but not rotate very much- if that makes sense. Twisting corrects chain misalignment, rotation is the change from accelerating to engine braking. The shaft will rotate a lot, of course, even with the bike in gear. IMO, the splines should be lubricated, which will prevent the rust. They aren't lubricated at all from the factory. |
09-20-2009, 07:41 PM
#1542 |
Oddometer: 83
Luke,
That makes sense, Thanks for the info. Pat. |
09-21-2009, 05:56 AM
#1543 | |
Ulysses
Oddometer: 1,208
Triumph Scrambler Blue & White (for fun) Triumph Thruxton Red (for the twisties) Honda XR400R Red (for the dirt) for sale Yamaha XT250s Sliver & white (for the wife) for sale Yamaha TT-R250 for some dirty fun |
09-21-2009, 09:14 AM
#1544 | |
Dirt/Street? No Wait Dirt
Oddometer: 555
It's made for soft/med terrain and therefore it handles the sandy/soft extremely well, but has good tractablity on all types of surfaces. I ripped all of the side knobs off the last one running it hard/fast on rocky/hardpack fire roads, (tire still performed for the remainer of the year). Charlie
You can ride further in an hour, then you can walk in a DAY! |
09-24-2009, 04:44 AM
#1545 |
Oddometer: 124
XR400 Electric Start
Save the drama for yo Momma 1990 Transalp 1985 XLV750R 1999 XR400R E-Start 2004 XR400R E-Start |
