Old 10-25-2009, 09:41 AM   #1606
Trailryder42
Trailryder42's Avatar
Oddometer: 1,061
Usually I'd point you to Race Techs spring chart, but their website is down. So I would call whoever you buy your springs from, tell them your weight and type riding you'll be doing and go from there.
Or, send the forks and shock off and spend $500 having them setup by a pro. Money well spent on the XR.
Originally Posted by wvridgerider
I bought a 200 xr 400 last month, first bike in 18 years and I like it a lot. However the suspension needs wok. I weigh 255 and I am considering Eibach springs front and rear. Any opinions?
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Trailryder42 is offline   Reply With Quote
Old 10-25-2009, 09:43 AM   #1607
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,895
Originally Posted by ironslede68
just a question and this seemed like the right group to ask. i want to daulsport a xr and i noticed that alot of you have licence plates on yours. what did you have to do to it to make it legal for the road? thanks for any help you can give me. oh yeah, i'm in Alabama.
First, do you have the title to the bike? If so, look on it and see if it says anywhere on there "Off Road use only"..if it does, then you may be out of luck...BUT, what if that title got lost? Then you could do a bonded title on it and chances are that the new title may come back without the "off road use only" on it and if you install what is needed per your state law (turn signals, horn, mirrors etc), put some insurance on it, then maybe you can get it tagged..all that I mentioned is how i tagged my XR, worked for me.
DrLewall is online now   Reply With Quote
Old 10-26-2009, 11:03 AM   #1608
bard
Devilrider
Oddometer: 29
Regarding tank.
I finally decided for an IMS tank, 4 gallons good for 300 km about. Plenty, not too wide not too heavy.
Good size
bard is offline   Reply With Quote
Old 10-27-2009, 01:07 PM   #1609
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,271
jet123 Pm me about winter storage.
here were my thoughts
the tank comes off so easy on the xr and it's plastic (no rust issue), i get all the gas out and drain the carb. since the xr is kick start, good fuel is essential for starting in the spring. if it was electric start, starting in the spring would be easier with old gas.
i drain the oil and put in fresh oil & filter to start using next spring.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-28-2009, 02:00 AM   #1610
Svart
...is swedish for black
Oddometer: 302
Has anyone here tried a fork brace? Trailryder perhaps?
This one is from http://www.rswracing.com/xr400r.htm
According to a couple of riders over on TT this is a great improvement of fork stability.
- More than one cylinder? Then you need more than one bike! -
I used to be Honda but now Im better
Svart is offline   Reply With Quote
Old 10-28-2009, 07:05 AM   #1611
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,895
yes..a fork brace is almost a MUST HAVE mod on any dirt bike! I even have one on the Harley! and it's not a dirt bike!
Old 10-28-2009, 07:11 AM   #1612
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Got one on mine. Works. Get it.
LaOutbackTrail is offline   Reply With Quote
Old 10-28-2009, 07:12 AM   #1613
Rando
Rando's Avatar
Oddometer: 76
I have a RSW fork brace on my XR400 and my XR650R supermoto...it really does help. I like that when I am in heavily rutted areas that the bike will go where it's pointed. For the price, you can't beat them.
1993 R1100RSL
2002 XR650R (Supermoto)
2000 XR400R
Rando is offline   Reply With Quote
Old 10-28-2009, 08:15 AM   #1614
Uneasy Rider
The life of Riley
Uneasy Rider's Avatar
Oddometer: 635
I picked up a SRC fork brace off of Ebay for my XR4. It made a huge difference in the way the bike tracked through sand & rutted trails.
With proper fork springs & a fork brace it will feel like a new bike.
Highly recommended modification.
Uneasy Rider is offline   Reply With Quote
Old 10-28-2009, 02:30 PM   #1615
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,895
are you convinced yet?
Old 10-28-2009, 02:30 PM   #1616
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,271
with that rsw brace,
how well do your fork boots stay attached?
looks like only a small clamping area of the upper fork tube is left exposed (assuming you mount the brace up as high as possible) for the boot to clamp to. OR do you use neoprene boots which might clmap easier.
i like how the superbrace design has an intergrated new lip for the boot.
http://www.superbrace.com/proddetail.asp?prod=2258
the rsw is much cheaper.
got pics???
Alaska
Old 10-28-2009, 02:52 PM   #1617
Svart
Oddometer: 302
hot d***n, now this was a response worth its name!
Yeah Im convinced, Im getting one!
Old 10-28-2009, 04:29 PM   #1618
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,048
Bluhduh Noob question, begin the pile on now!
I bought a '98 3/4th hand. With this joy I ended up with two extra tanks. I have not looked closely at them. They appear in good shape. My question is how can I tell who made them and how much they hold. One tank looks to be about the same size as stock (at least I think the installed tank is stock). The other tank appears to be much larger. Any help that you can provide would be appreciated.
AND YES, after I research these tanks might be for sale. Although, I am temped to install the largest of the tanks. At 6' 6" 250+ lbs, I don't think I will notice if the bike weighs an extra 16 lbs.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is online now   Reply With Quote
Old 10-29-2009, 09:25 AM   #1619
Trailryder42
Oddometer: 1,061
Yeah, I run the SRC brace. Put it on 8 or 9 years ago. Handling difference is amazing. Especially in rocks. A brace is one of the first things I put on all my bikes.
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Old 10-29-2009, 05:27 PM   #1620
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,578
Post some pics to help with that research...
You can also just fill them to see what their capacity is...
I went with the Acerbis (5.2gallon?) as I tend to out ride the stock tank in a day. And I'm not so into performance that the extra weight bothered me (6' and 215lb). If it's a small day, just don't fill it all the way up.
John
http://rerax.net/index.html
jet123 is offline   Reply With Quote
Times are GMT -7.   It's 09:13 PM.
